Question about Sony Playstation 3 (PS3) Console
Problem with udp port
Hi,iv been trying to get online to play a game+iv got connected+then it says verifying connecting or something like that+it then say u could not be connected, can u tell me what i need to do plz!?!?!?
    Novelist:
  • 142 Answers
Check whether the port numbers are opened for that particular game that you are trying to play
if not go to the router manager i.e. the home page of the router that you have and try to open the ports
Also known as port forwarding
if u dont know the ports that you want for a particular game
U can goto www.portforward.com and chek out the ports available for games...
for any further help, plz reply back
Posted on Feb 18, 2008
Why is my online play sputtering
With the limited information you have given me, I do believe it is because you're having connection issues, probably due to something downloading, or your connection is just plain being overused while you play.
Some ways to solve this can be to stop any downloading while playing, check all your computers and see if any torrenting programs are running.
Another is to open your ports on your router, and to initiate UPNP (universal plug and play).
From the official Xbox 360 Port Forwarding help center:
http://support.xbox.com/en-US/xbox-live/connecting/network-ports-used-xbox-live
Xbox Live requires the following ports to be open:
  • Port 88 (UDP)
  • Port 3074 (UDP and TCP)
  • Port 53 (UDP and TCP)
  • Port 80 (TCP)
Note If you cannot chat with someone using Video Kinect, you might need to open port 1863 (UDP and TCP).
The link also contains information on how to find out who manufactures your router, which you will need to know in order to find the proper way to change the settings.
Oct 16, 2013 | Video Game Consoles & Games
Weak connection
improve ur brodband connection
Jun 14, 2008 | Sony Playstation 3 (PS3) Console
I keep getting kicked off during online play (8002AD23). I have a wired, ethernet connection
That error means your PS3 is having trouble connecting to the PS Network. That can be caused either by your internet speed (if you are downloading something for example, it may lower your speed and cause this error) or by a random glitch on the PSN. You should also try forwarding the ports from your router. The PS3 required ports are : TCP 80 TCP 443 TCP 5223 UDP 3478 UDP 3479 UDP 3658
Also keep in mind that it is recommended you set your PS3 to use a Static IP. I hope that helps
Philip
May 27, 2011 | Sony Playstation 3 (PS3) Console
Error code for sony 3 807
"Hey, here is a list and a reason of some of the error codes you may encounter whilst connecting your PS3 online, also the required ports need to be opened in order to play online.
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation 3 Error Code List
0710102 - DNS Error; No DSN server available.
8001050B - Will not play demo hard drive games, when blue-ray disc is inserted - Cause unknown
80010510 - Will not play hard drive games - Cause unknown
8002b241 - DVI has no audio.
80028EA5 - Unknown
80029023 - Exchanging Key Information exchange has timed out
80029024 - The attempt to obtain an IP address has timed out
80029564 - Downloaded Game will not install - Cause unknown
8002F997 - Can not update XMB firmware
8003051E - Game will not Save
80031150 - System Settings Fail to Save - Possible Blue Screen "Setting information is corrupted.Press the x button to repair and restore default"
80130203 - PS3 connects to internet but not to network - Typically means that the required ports are not open to connect to store but PS3 can connect to internet.
80710092 - "An error has occured. you've been signed out from the ps network" - (connection dropped?)
80710102 - PS3 Cannot connect to the router with current IP information - Try rebooting your router
80710541 - The connection to the server timed out.
80710B23 - PS3 Network is Down or PS3 Network is too busy to respond"
http://community.us.playstation.com/thread/2996553?start=0&tstart=0
Apr 17, 2011 | Sony Playstation 3 (PS3) Console
I have a ps3 and an xbox 360...when I have my nat type on moderate then i can sign on both of them no problem but have a time trying to connect to some other of my friends. when I make my nat type open I...
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Jan 06, 2011 | Arris SURFboard SBG900 Wireless Router...
Error 80028e02 cant play online
PS3 error 80028E02 can be caused by different source of network showcase270.jpgblockages. If you happened to be in a filtered network, that's your most probable reason why your PS3 is unable to connect online. For example, if you're in a school campus, there's a high chance that the IT network administrator has placed some restrictions to prevent hackers and other malicious online activities. You can refer to the campus IT department to find out if you need to access their local page for some clearance in order for your PS3 to connect online.
If the modem or router is blocking your connection then it can be fixed by opening some ports
you will have to call your computer vendor to open the ports
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Nov 24, 2010 | Activision Call of Duty Black Ops
I have a PS3 slim console and it is having some internet problems that I cannot figure out. I have a CAT-5 ethernet cable plugged directly into my modem which is directly connected to my PS3. Many times...
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Nov 07, 2010 | Sony PlayStation 3 Slim Black Console
I try to in a game which is online one. but it keep saying cannot connect to server. then i try other online games also they same thing.
1. Check for current anti-virus before doing step below.
2.Check firewall allowances or permission to be sure game is allowed
3. Try "port forwarding
4. Check the game / verify ports need for multiplayer gaming.
5. Please forward all ports UDP/ TCP To gaming computers IP address.\
6. Log in to router and place gaming computer in to DMZ.
7. When done gaming disable the game in the DMZ.
May 17, 2010 | Linksys Wireless-G WRT54G Router
GTA IV multiplayer issues
Yes, you have to search for the TCP and UDP port numbers and open them in the router config not forgeting to bind them to your LAN ip address.
Feb 01, 2010 | Gateway Computers & Internet
Ps3 can only connect to one or two games online playing fifa09
I'm not sure about 3659 but these are the ports I have forwarded
TCP:
  • 80
  • 443
  • 5223
UDP:
  • 3478
  • 3479
  • 3658 should also be opened for voice chat.
Also DMZ would be perfectly fine as long as long as you set a static IP on your PS3
What DMZ allows is that any ports communicating to a specific IP access, so if this IP is alway connected to your PS3 no harm to other computers or devices can be done!
Dec 02, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
43 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
