Question about Freezers
My freezer of frost free creda fridge freezer is not working. What could be the problem?
  • 111 Answers
Ther is a small fan in the freezer that keeps air moving, that is what makes it frost-free, the fan is probably burned out
Posted on Jan 31, 2010
3 Suggested Answers
  • 11 Answers
SOURCE: frost free fridge/freezer - not cold in fridge
The most common problem with refrigerators not cooling when the freezer cooling is the fan which supplies cold air to the freezer. Not easy to get to in most cases. Another problem is the vent to the fridge part is blocked or not operating with the adjustment control.
Posted on Nov 29, 2008
  • 27 Answers
SOURCE: candy frost free fridge freezer .freezer working ok
The thermostat might be turned up too high or is faulty. It should click when turned up and down from the setpoint.
Posted on May 12, 2009
I wantto buy a new fridge e difference betwun ice diamond frost free and just frost free
""Ice diamond frost free"" sounds better than just plain "Frost free" and I bet they charge lots for the extra letters, simply, it is a way of sucking people in to pay extra for something they think is far superior but infact is no different. Frost free is frost free, you cant change the way it works but you can change the way it sounds!!!! Hope that will save you some hard earned dollars.
Dont forget to vote for the solution I just gave.
Mar 03, 2011 | Freezers
Fridge freezer problem
Sounds like the defrost system of your freezer is not working. It could be either the defrost timer, defrost thermostat or the heater has a problem. The defrost timer turns off the compressor periodically to sent power to the defrost heater via the thermostat. The defrost heater then powers up and heats the evaporator coil to melt the accumulated ice buildup on the cold coils. Most likely issues are that the timer motor is not advancing the timer or the heater itself has burned out.
Jul 14, 2010 | Freezers
Sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
Jul 01, 2009 | Freezers
Candy frost free fridge freezer .freezer working ok
May 12, 2009 | Freezers
Frost build up in a frost free freezer
It could be the door gasket. It could also be that the fridge needs a good defrosting. (especially if it is an older fridge)
When I bought my house I had the same problem with the fridge that came with the house. I assumed the previous owner had been defrosting it regularly, which he had not.
Eventually I decided to try a full defrost, and my fridge now works like new.
Mar 20, 2009 | Kenmore Freezers
Frost free fridge/freezer - not cold in fridge
Nov 27, 2008 | Freezers
Fridge freezer
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Sep 23, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Freezers Logo
692 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
