Question about Rheem Water Heaters
This a Manufactured house. I am having an issue with having to reset it in order to get the hot water heater to heat the water. This is an electric hot water heater. The info on the water heater is: S/N RH 05981 52556, model 71-40D B, wattage 240volts AC only, upper 4500, lower 4500, total 4500, cap US gallons 40. I am not sure what other info is needed
  • Tom Ludwig Feb 01, 2010
    I may have not described what I was resetting when I reset my water heater. My hot water heater has a reset button on it. The breaker in the electrical box stays on. Sorry for not getting into detail. The reset button is located in the top hole and is centered between 6-8 wires, which are coverd by a plastic shield.
    Thanks
    Tom
  • Rheem Master
  • 43,501 Answers
It looks like from the serial # that this heater is 11 years going on 12 old... It is getting ready for replacement anyway... in my part of the country it would be leaking by now.
Anyway, the problem you have is either that one of the thermostats is not tightly against the metal of the tank, which can happen in a older heater, or that one of the thermostats has gone bad and will not shut off. This causes the reset to pop because the tank is over heating.
Tracking down exactly what is happening cantake a long time. You will need an electric meter and be checking the bottom element to see if it licks the power back up to the top one. Then if that happens you need to see if the top thermostat kicks off at the temperature you want. If the reset pops before the temperature goes over the set point then you have a bad reset/thermostat on the top.
Heatman101
Posted on Feb 02, 2010
    Genius:
  • 1,018 Answers
Good morning,
I'm guessing that you are stressing the "Manufactured" home because it uses full size appliances, correct?
What is the electrical feed to your home, 100 amp 200 amp?
There are several reasons for a breaker to trip. The circuit is demanding more amperage than it is protected for. For example, if your water heater is a 40 amp heater, and it is pulling 45 amps, then the breaker will trip to protect the device.
If someone was doing "decorations" and hammered a nail through the conductors to the heater to the panel. The breaker itself may be bad. The water heater my have a short to ground withing its wiring. And last but not the least, the breaker or the panel could be defective.
I must warn you, if you do not know how to service the Main Panel, call a licensed electrician. May panel mistakes can get you killed or severely burned if you do not know what you are doing.
Does the breaker trip immediately when you reset it? If it does, then you need to shut he main service feed to the panel down. The wires connecting to the main panel will still be live so STAY AWAY FROM THEM!!!!
Remove the panel cover and examine the breaker marked for Water Heater. Carefully remove the breaker and look at the contacts on the bottom of the breaker. They should be clean and smooth. If there are any burn marks or pits, replace the breaker with a breaker that is made for your panel. Take the breaker with you to a Lowe, Home Depot or an electrical supply shop.
With the breaker removed, check the phase bus bars that are under the breaker to make sure they are clean and smooth. If they are pitted or contaminated, the bus bar will need to be replaced. Or in some cases the entire panel will have to go.
While you are in the neighborhood, take a multi meter and set it to 1K Ohms. Place the black probe lead onto the frame of the cabinet. Using the red probe, place it on each lead from the breaker. If either position reads zero (0) then there is a direct short between phase and ground and you may need to replace the cable.
At the water heater, remove each phase conductor and then check if the ground fault is removed. If it does, more than likely, the heater has a ground fault short and should either be serviced b a plumber or electrician. Personally I would just replace the water heater if the ground fault short goes away.
Before you head of to the store for parts, I would turn the main panel back on so that the home has power again. Remember to shut the panel down before doing any work when you return.
Don
Posted on Jan 31, 2010
We're is the fuse located for the electric water heater I have hot water on gas but the electric heater just stopped when I'm plugged in
It is not fused, they don't use fuses and haven't for decades, it is hooked into the house current at the breaker box for the house.
Jul 21, 2016 | Water Water Heaters
Unit stiebel Tempra 24Hot water is running through house but cold water pipe is getting hot. Hot water pipe is not getting hot. When cold water connection is removed and water is turned on hot water is...
follow this steps and fix it. God bless you
If there is no hot water, first push the reset button on the high-temperature cutoff; test the thermostat and replace if faulty (see below). Test the heating elements and replace if faulty (see below).
If there is not enough hot water, adjust the thermostat settings. As needed, reset, test and replace thermostats and heating elements if faulty.
If the water is too hot, adjust the thermostat settings and reset. Test and replace the thermostat or high-limit cutoff (see below).
An electric water heater is a 240-volt appliance that can deliver a fatal shock. Always turn off power to the heater at the electrical panel 585dc480-4881-44a8-afda-7267c0f3de26.jpgbefore beginning work, and verify that power has been shut off. Make sure others in the house know not to restore electricity prematurely. If you have any doubt as to whether electricity has been turned off, seek professional assistance.
Oct 02, 2013 | Stiebel Eltron TEMPRA 24 Tankless Water...
Glowworm economy plus
follow this test and fix it. God bless you
An electric water heater is a 240-volt appliance that can deliver a fatal shock. Always turn off power to the heater at the electric service panel 3eaa58c5-8512-433f-991a-4ed5eb1cf944.jpgbefore beginning work, and verify that power has been shut off. Make sure others in the house know not to restore electricity prematurely. If you have any doubt as to whether electricity has been turned off, seek professional assistance.
Oct 01, 2013 | Water Heaters
Heater element only gets 120volts. Should be 240v, correct? Water does not heat up.
Testing voltage on heater can be tricky since elements can test 120Volt to ground all all times.
This is because thermostats only turn off 1 Hot leg in the 240Volt circuit, while the other hot leg remains live. Each hot leg in 240Volt circuit is 120Volt.
http://waterheatertimer.org/B220C.html#120-240
Troubleshoot electric water heater:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#reset
Try following things in order: Press reset button. Test elements. Replace thermostats.
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Add comment.
Apr 29, 2013 | Water Heaters
Electric GE Water Heater Not Heating Water
One possibility: Push in the reset button located on upper thermostat.
Copy following link for troubleshoot walk-thru, and DIY checks:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#new
Nov 04, 2012 | General Electric Water Heaters
Model 71-52DB 50 gal. water heater stopped heating
Press the reset button located on upper thermostat
Following link has troubleshoot for electric water heater
Gene
Jun 13, 2012 | Rheem Water Heaters
My Powerstar tankless water heater was installed last April and we have a problem that has become a real issue. We can set the temperature where we want it and get in the shower and the water will go from...
Ok, sounds like a flow sensor issue, is your house water pressure steady or does it fluctuate? The sensors on these seem to be a common issue and this model has many issues with heating. take care
Jan 17, 2011 | Bosch PowerStar AE125 AE125 Whole House...
No hot water
If you checked the reset, then the next thing to check would be the breaker in your breaker box. If that doesnt work start checking the elements. The reset, the thermostat and the elements are pretty much all that can go wrong with an electric water heater, short of a leaky tank or faulty t&p valve. Hope this helps.
Sep 24, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water
in and out hooked up right?
May 17, 2009 | Eemax EX280T2T Series 3 Whole House...
Water Heaters Logo
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
