Back to:
Tags:
Multimedia Projector Replacement Lamps
Generic problem for all Multimedia Projector Replacement Lamps
Infocus X2 (by 3 users)
posted by domingjy on Feb 18, 2008
We (school) has a Infocus projector that will not turn on. The red blinking light blinks just once, which should be "lamp and lamp door installation loose connections" I checked it and everything looks good. Could it be that the bulb is out? We've had it less than a year.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by kazoola, posted on Apr 10, 2008
every thing work but fan the fan work with outside current applied
Comment by waspman, posted on Mar 27, 2008
My projector lamp light is on, projector will not turn on. Only 70 hrs on bulb is that common? A hd 6800 optima projector.
Best Solution
posted on Feb 28, 2008
FixYa! (100)
sheridan1952
Rank:Master Master
Rating: 90%, 12 votes
Most likely it is the lamp. That you have had it less than a year is not significant. It is how many hours you have put on it. Those lamps are supposed to be good for about 4000 hours. Some get more, some less.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Infocus X2:
I don't want to Accept this solution
Solution #2
posted on Sep 19, 2008
Not Rated (0)
scottyfixit
Rank:Wiz Wiz
Rating: 85%, 97 votes
I can almost guarantee that your bulb is out. We probably have 20-30 projectors of this model in the school and bulb life averages a little over 100 hours even though they advertise 3000 hours. Infocus has been known most for their poor cooling system to the bulb over the years and most owners won't get the life expectancy of the bulb. If you remove the bulb you will find a small restrictive vent screen on the bulb and commonly it will be filled with collected dust. This model really doesn't have any removable/cleanable filtering system installed - again a cheap and poorer design then many other brands. We have decided not to purchase infocus projectors anymore in the district. They were a seller at one time because they were cheap, but because they don't last they weren't really a deal after all. Sometimes though a ballast for a projector will go out and it will be unable to power up a good bulb. I wouldn't consider fixing it because of their overall poorer reliability.  If your looking for a cheap but more reliable brand of projectors I'd steer towards Epson projectors. They tend to have lower costing projectors and bulbs then most and I have seen in person that they last well above their advertised lamp hours in different models. Their are many good brands out there but InFocus is not really one of them - they have under built projectors and poor phone support.
Hope this helps a little. - Scott
Thank You!
Solution #3
posted on Aug 05, 2008
Not Rated (0)
swatijl
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Contact swati@justalmps.com.sg for all your replacmement projector lamps needs. We supply original lamps with housing. We stock all brands and all brands.
Thank You!
Solution #4
posted on May 22, 2008
Not Rated (0)
CAMERA PART
Rating: 0%, 0 votes
I belive is a power circuit Problem, if the Fan is not runing then is a power circuit problem.check for thermal fuse, or send it to me.
Webster Camera & Repair Inc.
20736 Gulf Freeway, Webster, Tx 77598.
281 332 1222
Thank You!
Solution #5
posted on Mar 03, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
try to open door where lamp is and take lamp out and  just put the lamp back in .
connection might of come loose.
Thank You!
Can you Help with these Multimedia Projector Replacement Lamps problems?
BenQ Projector Lamp for MP610
ha ive got mp610 which i replaced lamp couple of months...
Toshiba Replacement Lamp Projector Lamp for...
Recientemente e cambiado la lampadina y esta se me apaga...
Epson (DHV13H010L15) Projector Lamp for...
After the projector has been on for a while, the pictures...
The set will come on as soon as it is plugged into wall...
ASK Proxima (028922) Projector Lamp for...
Hi, I have a Proxima Pro AV 9320, and when I turn the...
Loading problems.
Repair Service
Find Multimedia Pro. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
