Question about Tascam Dp-02cf Digital 8-track Recorder
Recieves input but no output.
Conected line out from the unit to my speaker but no sound. Do I need to hook it up through an amplifier?
    Brigadier General:
  • 8,546 Answers
YES.
Posted on Feb 01, 2010
Sony XM-GTR4A
contact sony .... or check your head unit is recieving
Mar 29, 2014 | Sony Car Audio & Video
Older telephone amplifier
input line is the line from the wall connection,output is line from phone area to output of amplifier.
Nov 24, 2012 | Audio Players & Recorders
How do i connect a sub wooferto my reciever
I own 2 of these Pioneer VSX-D903S units.
The only way to hook a powered subwoofer up to a VSX-D903S is if your subwoofer is equipped with amplified/speaker level terminals on the back, in addition to the line-level input. If you only have a line-level input, do not attempt to hook it up to this receiver.
If you're lucky, and have speaker-level inputs on your powered subwoofer, you would use the amplified terminals (connect to B-channel on the receiver). DO NOT connect anything to the line-level connection.
Alternatively, you could build two unpowered subwoofers, then set the receiver's Impedance switch to LOW, then connect one enclosure to each of the "B-channel" outputs. Connect your regular left and right speakers to their corresponding "A-channel" outputs. [Impedance range: 4 Ohm minimum, 16 Ohm Maximum]
Jul 20, 2012 | Pioneer VSX-D903S Receiver
Power Acoustik PWM-16 Equalizer Help
You should be able to use your RCA output (Line Out) from your Pioneer to the input of your PWM-16. Then take the PMW output to an amplifier and then to your speakers. Your EQ only uses RCA's so an amplifier after
it would really bring the sound to life. The amp need not be huge as you have an output for subs also. You could try a line converter to change the RCA lines to speaker wire connections. Not sure if the output would be enough to power a speaker but it's worth a try.
Sep 28, 2009 | Power Acoustik PWM-16 Car Audio Amplifier
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
Voltage on subwoofers input
Is the subwoofer a self-powered unit? If yes, it would have a minimal voltage showing on a meter. If the input is a line input, it would not have a problem taking in a line output (not speaker - never!) from your receiver. If the only output you have from your reciever is a speaker out, then purchase an L-Pad type speaker to line matching transformer. You can also take one of the input channels coming from the source and Y out a side to the sub pre receiver, but you then you would need to be able to adjust levels on the subwoofer independently from the receiver.
Jul 24, 2009 | Audio Players & Recorders
Hooking up system to a factory infinity sound system in a jeep grand cherokee.
Tap into a signal wire (rear speaker wire) using a line level converter.
These convert the High level speaker wire output into low level RCA output that is accepted by your amplifier.
c5b61ef.jpg Get a good one Pacific Accessory Corporation (PAC) sni-35 is the best IMO.
The TRUNK-LOC is the SAME as the SNI-35 - but it incorporates a voltage sensing input - so you dont need to run an additional turn-on wire. The voltage is sensed through the speaker wire - and it turns on the amplifier.
Then you will need a fused power wire from the battery,
Ground to chassis, and remote turn on lead (if you use a standard line level adapter).
An amplifier installation kit will give you everything you need to add 1 amplifier (except the converter)
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 22, 2009 | Diamond Audio D5-1200.1 Car Audio...
Kenwood VR6070 speaker/amp problems
unit needs repair. Look at the b speakers. Conect a speaker or two to the B position. If you have no sound than your surrond sound is ok and the unit is bad. Sound comes directly into the b speaker and not threw the surrond system. My 6070 has a cold start up problem. no sound. time to purchase a new one. to costly to repair.
Dec 30, 2008 | Kenwood VR-6070 Receiver
Alpine CDA-7873 (Same as CDA-7876 basically)
the blue line from the radio harness does not have power when the cd or aux are being used and the amp is not turning on-wire the remote line from the amp to the red line and your amp will stay on and you will get sound
Mar 27, 2008 | Alpine CDA-7876RB CD Player
Factory stero to amp
If the amplifier has inputs for a high level signal, you unhook the wires going into the speaker and plug them into the amp, then hook the outputs up to the speakers. If the amp only has rca inputs, you need to also buy a line level converter. Then you unhook the speakers, hook the wires up the the converter, then hook the converter up to the amp, then hook the amp up to the speakers.
Please leave good feedback!
Dec 08, 2007 | Blaupunkt PCA250 Car Audio Amplifier
Tascam Dp-02cf Digital 8-track Recorder Logo
74 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
