Question about Brother MFC-8220 Fax
Need to clear the memory of Brother MFC-8220 fax
We get spam faxes all the time so we only turn on the fax when we are sending out. In fact we don't even have a working toner cartridge in the machine. So little by little incoming faxes have slipped in and are waiting to print. So many are waiting to print that it has used up all the memory. We don't want these faxes! How do we clear ALL the incoming faxes in memory?
  • jestercat Feb 18, 2008
    Nope. It's been off for weeks at a time. Those faxes are in there still waiting to come out.
  • jestercat Feb 19, 2008
    Nope. That doesn't do a thing but make it beep at me.
Simply pull the plug out of the jacket, and completely disconnect it if Menu 2, 5, 1 does not work.
Posted on Sep 06, 2008
Menu 2, 5, 1
Set fwd/page/store to *OFF
It will then ask if you want to delete all faxes in memory. Say yes.
Posted on Apr 29, 2008
    Scholar:
  • 78 Answers
The easy way to reset the machine is to power it off for a period of time. Say overnight will allow the battery back up on the board to run out and the machine to loose its memory.
Posted on Feb 18, 2008
  • Clint Bowden
    Clint Bowden Feb 18, 2008
    Use user-accessible maintenace mode to reset by -
    Press the Menu and Enlarge/Reduce button in this order.
    Press the 0 key.
    Enter 9 then 1 for reset.
    To make the machine return to the standby state, press the Stop/Exit button.
2 Suggested Answers
  • 159 Answers
SOURCE: I have a Brother MFC 8220 incoming fax problem
Here are a few possibilities:
Does it still say "FAX" on the display? If it says "TEL" it won't answer the phone. Changing it is just a matter of pressing the MODE button, which cycles through four settings. FAX is for dedicated fax lines. If you share the line with a phone, check your manual for info about the other two settings.
In your menu settings is a place where you can set the number of rings before answering. If it's set too high, the sending machine will give up while your machine is still waiting for that 9th ring. I know you wrote that nobody's messed with it, but it's worth checking.
A glitch in the memory may be disabling reception. We can reset it in the Maintenance Mode:
From the Ready state, press these buttons in rapid succession:
Menu
* [the star on the phone dial]
6
If you did all that in under 2 seconds, the display will show MAINTENANCE. If you were too slow, you'll just be in the menus somewhere. Press Stop and try it again. You have to ignore all the error beeps while you do this; it's designed to be nearly impossible to do accidentally.
Once you have MAINTENANCE on the display, simply touch 91 and wait. The machine will clear all its memory, except your stored phone numbers. In a few seconds it will return to MAINTENANCE. Press 99 to exit the mode. The machine will go through it's entire start-up, as if you'd just plugged it in.
You don't need to use another fax for initial testing. Call it from another phone - even a cellphone - and see if it answers. If it squeals horribly in your ear, you've probably fixed it. Now try faxing to it.
If that function 91 didn't help, try something harsher. Go through the same routine above to enter Maintenance Mode, then, instead of touching 91, touch 01. That will clear all memory to the sate where it was when you first unboxed it.
If nothing above helps, it almost certainly needs a new Main Board. Replacing that on a non-warranty machine may not be worth it, but use Brother's website to find your nearest servicer and find out.
Posted on Jan 27, 2010
Clearing fax numbers from my brother mfc 8220 printer
press menu*2864, display will flash, then enter 01 on the keypad,wait 30 seconds and then press 99 on keypad, machine is now returned to factory settings
Nov 20, 2011 | Brother MFC-8220 Fax
Message: POOR LINE CONDITION / OUT OF MEMORY HOW DO I CLEAR THE MEMORY?
press menu *2864, display will flash if entered correctly, then press 91, then 99, memory should be cleared
Aug 16, 2011 | Brother MFC-8220 Fax
I KEEP TRYING TO FAX AND GETTING THE MESSAGE. OUT OF MEMORY. HOW DO I CLEAR OUT THE MEMORY ON MFC-6490CW. PLEASE HELP ASAP IF POSSIBLE. THANKS SO MUCH.
The manual for this printer can be found here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=mfc6490cw_all&dlid=&flang=English&type2=-1
If you get an Out of Memory message while faxing and you do not want to delete your stored faxes to clear the memory, you can send the fax in real time:
You can turn on Real Time TX.
1) Press Fax
2) Press up or down arrows to select Real Time TX.
3) Press left or right arrows to select "On"
4) Press OK.
You can now send faxes real time without having to scan the document into memory.
Hope this helps,
Chris
Mar 10, 2011 | Brother MFC 6490CW InkJet Printer
Brother mfc 8220 will not send faxes to certain numbers
The problem is not with your fax machines. If it sends to any fax number it so OK.
Jun 11, 2010 | Brother MFC-8220 Fax
Why does my brother 8220 turn on but just says please wait?
This could be a memory issue. Try unplugging it for a few minutes.
May 20, 2010 | Brother MFC-8220 Fax
Unable 2 send or recive fax
Make sure the telephone wire is plugged into the line jack (not ext jack) and should go straight to the wall, without splitters or extensions. If you still cannot send a fax, try another wire or jack
Apr 15, 2010 | Brother MFC-8220 Fax
How I clean Drum of Brother MFC 8220 Fax machine
If you mean drum reset
1. Open the front cover, and then press Clear/Back.
2. Press 1 to reset.
Oct 28, 2009 | Brother MFC-8220 Fax
Document to memory before sending
Here's the manual. Look at page 6-8. That tells how to turn on real-time transmission. You just need to do the same thing, except switch it to off when you get to that step. http://www.brother.ca/en/products/pdf/manuals/MFC8220-UG.pdf
Sep 06, 2007 | Brother MFC-8220 Fax
Brother MFC-8220 Fax Logo
3,133 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
