It will pump out, I will check on the price of a timer, the washer is quite a few years old.It will pump out, I will check on the price of a timer, the washer is quite a few years old.
You can't post conmments that contain an email address.
Hello there: When the cycle doesn't advance, or it takes a very long time to complete a cycle. !st, check the timer to see if it is working properly if not replace it ' next make sure that you are getting cold water and it is getting adequate pressure.:here is how to check the timer . if your washing machine fills with
water and begins agitating, but the timer never advances--or if the
washer is in a spin cycle and the timer won't advance. Then you need to
replace the timer. It may be a cold-water supply problem, if the washing
machine fills with water, agitates, drains, and spins, but then doesn't
fill with rinse water. See There's no cold water. Ok? Hope this is very helpful for you Best regards Michael
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Hi! When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
The timer has a motor used to advance it through the cycles. If the machine fills with water and the timer stays in one position no matter where you put it......even in the spin cycle, then replace your timer.
* It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
* It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
