Question about Durabrand DWT1304 13" TV
Menu options auto channel, not in english
Kimminc5- just wondering if all your menu is in a different language,if so you will have to go to your menu and change it.This may be a little fun but you really cant mess up too badly even if you have to guess the language.I have done this lots,just try and maybe I can help. cooltek Feb18/08
Posted on Feb 18, 2008
How do I run a channel auto scan?
There are many different ways, because each TV manufacturer calls each menu option something different. In your TV menu there should be an option that says Set Up, or Channels, or something similar. Your TV should be, Menu, pan right to Channel, select whether you are using Air (air meaning antenna, picking up channels that are broadcast free over the air) or Cable (only if you use cable with no box). Then the option below should be auto scan. Allow to run completely. Sanyo DP42D24 User Manual Channel
Apr 06, 2015 | Sanyo DP55D44 55" 1080p 60Hz LED HDTV
How do I get digital channels instead RF channels on my TV DWM32H1G1
Have you hot a digital receiver connected to the TV.....Sky or Cable?
Jan 02, 2015 | Televison & Video
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I want to change languag to english
Pl. select menu option with remote,search for language option with the help of channel and volume plus and minus buttons,open the option find the list of language,select the required language,come out of menu by pressing menu button.
Jan 15, 2011 | Televison & Video
On my main 'menu' the option to Autotune my TV is greyed out an unaccessable. I've tried to auto scan for new channels but have lost all itv channels in the meantime. I've tried to reset the tv but still...
It sounds silly , but press the input button on your remote controll untill TV is hilighted . press 3 on the remote , then go back into the menu and see if the auto tune option can be selected.
Jan 12, 2011 | Televison & Video
I have remote control no. RM-C754. I can always get Ch. 34, except for last eve. When I push the Menu button, it is all in Spanish. How do I get it changed to English, and then how can I get Ch. 34?
On Menu Look for Lanuage change it to English and then Look for Auto program for channels reprogram so it will lock on channels that it can pick up
Feb 15, 2010 | JVC Televison & Video
I have a LXI series 13''tv,no manual-can't program channels
in menu switch the language to english, then find the channel setup feture under that there should be an auto search option run that and it should setup ypur channels
Sep 10, 2009 | Televison & Video
NEED TO KNOW WERE ON THE REMOTE DO I GO TO SEARCH FOR CHANNELS
To search for channels (this is called a channel scan, auto program, or auto scan) you need to go into the TV's menu. There should be a menu button or setup button on your TV's remote that will bring the menu up on the screen.
The TV's menu actually has more than one menu in it. Each menu has a different set of options. The first one you'll likely see is the one that has the picture options such as brightness, color, tint, etc. You need to find the one that has the channel setup options. On this screen you'll see what you're looking for.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jul 11, 2009 | Televison & Video
Purchased a Zenith TV (model #Z20LCD1 Serial #609TPAE12392} the directions nor a remote was in the package. I am unable to change channels and it is on Channel 11 an ETV channel. When I go to the menue,...
For changing language you need to go to the Special Menu Options. While on the menu select the one on the far right (past audio, picture menu options). Second line in special menu is the one to select Language, you can change it to english there.
https://www.manualslib.com/manual/376266/Zenith-Z15lcd1-15-Lcd-Hdtv.html?page=19#manual
Jan 18, 2018 | Zenith Televison & Video
Auto Tuning Channels on LC20B2MA Aquos TV
 Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
set.
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
Aug 07, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
Durabrand DWT1304 13" TV Logo
42 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
