Question about Samsung SCH-a650
I need the unlock code . this is an old phone and i had a lock code that i put into the phone, i lost the phone bought a new phone now is has stopped working and i can't remember the unlock code.Can you please help me with this?
Samsung unlock code
This is true.. the problem with tracfones is that they are very hard to unlock..
You could try by unlock codes at http://www.unlocksamsungonline.com/samsung-unlock-codes/
however by cable will not work. Before you purchase any unlock by codes service check if you can enter the unlock codes.
Put a different simcard in the phone and turn it on. Then let me know exactly what the phone says..
Feb 12, 2013 | Samsung SGH t340G Straight Talk Cellular...
I have lost my Nokia phone's password how can i
what is Mobile Phone model?You need to reset the old phone password and set new password..To reset the password lock..you can use default code..Try 1234 or 0000 these are default codes...If these code does not works get the master reset code as free of cost from the site Unlocking4free.com/nokia-unlock-tool and reset the Nokia DCT phones from password lock...Then set a new password or security code.
Sep 21, 2012 | Cell Phones
I bought a new Nokia 1661 after dropping my Nokia 1661 and damaging the screen. When I put my T-Mobile SIM into the new phone it says "SIM not valid". But the SIM still works in my old Nokia...
Your new mobile may be locked to some other network that's why it is not accepting your sim.. So you have to unlock it to use with other sim.. You can unlock it by several methods but unlock codes are quite simple way to unlock it.. You can get unlock code at Mobile-unlocker.com very easily...
Sep 27, 2011 | Nokia 1661 Cell Phone
I have bought an second hand e71 and whenever i put my globe simcard the phone shows simcard registration failed.i tried to buy a new simcard but its still the same.how would i fix the poblem?
Make the FixYa experience better for everyone by voting.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave' for today.
As you evaluate my advise.solutions and suggestions, there are a few things you must keep in mind:
• I did not diagnose your problem and am therefore only able to evaluate what you tell me. For example, if you ask me a fuse location, that doesn't mean that I can tell you the reason why the fuse blew. Keep in mind that I'm limited in my analysis to what you tell me.
• A thorough diagnostic approach involves the use of technical equipment, such as voltage meters. scanning equipment and other sophisticated devices.
• Lastly, fixing one problem can very easily reveal a problem with something that you might consider unrelated. If that happens, you might want to view me as being incompetent.
Subject: How to unlock a SIM card
Customer's exact description: I have bought an second hand e71 and whenever i put my globe simcard the phone shows simcard registration failed.i tried to buy a new simcard but its still the same.how would i fix the poblem?
Discussion: Problems of this type can be either Phone Locked, SIM card Locked, or Lost Password. Customer did not provide sufficient detail to narrow the problem.
Solution: Provide instructions on how to deal with all three possibilities.
PUK Codes
A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from AT&T to unlock your SIM card.
Since I don't know the name of you carrier, I'm using AT&T as an example. Most carriers use the same methodology though the wording may be different.
PUK Codes
You can obtain your phone's PUK code from AT&T in one of these ways:
Take the phone into your carrier's retail outlet.
OR
• Log in to myAT&T online
• Use our Technical Support Chat.
• Contact Customer Care
To get your phone's PUK code online:
? Log in to myAT&T.
? From the myAT&T tab at the top of the page, hover over the Wireless link and select Phone/Device under the My Wireless Service heading.
? From the My Phone/Device screen, select the Unblock SIM Card link under the My Make & Model heading.
? The Unblock SIM screen will display your PUK code and will give you instructions for unblocking your SIM Card.
Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code.
Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator."
You can also do it without any assistance from anyone. However, be sure to read the following carefully because there are pitfalls. If you want to try to do it yourself, just click on the following link:
Universal Software Solution for Unlocking a SIM Card
Although most people remember their primary SIM PIN code, those other codes - used for various verification purposes - are never to be found when needed. Below we've included a set of short codes which, when entered on a handset's standby screen, will let you easily change PIN and PUK (short for Pin Unlock Code) codes - but keep in mind, they may not work with all handsets and mobile operators.
More importantly, when changing ones PUK codes there'll be no help to get from the mobile operator if the new codes are forgotten, so make sure to write any changes down alongside the old PUK codes. Also, please note that the codes should be entered without the spaces shown below.
Change SIM Card PIN
** 04 * old PIN * new PIN * new PIN #
Change SIM Card PIN 2 (Write down the new code)
** 042 * old PIN * new PIN * new PIN #
Change SIM Card PUK (Write down the new code)
** 05 * old PUK * new PUK * new PUK #
Change SIM Card PUK 2 (Write down the new code)
** 052 * old PUK * new PUK * new PUK #
Display Handset IMEI
*# 06 #
This was wordy but hopefully it helped you.
Ben
http://download.cnet.com/Universal-Simlock-Remover/3000-2381_4-10380518.html?tag=mncol;2
Aug 19, 2011 | Nokia E71 Smartphone
Hi there,i had purchased htc thunder bolt a month ago from Miami US and since it was a lock piece i also bought unlock code online.Now the biggest challenge i am facing is when i put my local active sim...
Hi, i think your step not correct when entering HTC Thunderbolt unlock code. You must use your old sim card to unlock your phone, don't use new sim card before that phones completely unlocked. That's why your sim card not recognized. If this method not working maybe you get wrong HTC unlock code, since it's little rare for me. Usually if you bought unlock code reputable online store, they usually send unlock code with complete instruction how to insert that unlock code in your phones. The bottom line try my method and if not working get new code. Thanks.
NB: don't enter your wrong code to many times in your phones, it will caused your HTC to hard locked state and you can't use that phone even you put your old sim card.
Jun 03, 2011 | HTC Thunderbolt (8 GB) Smartphone
I bought a pantech c520 AT&T unlocked phone
i think ur phone is not unlocked completely, try codes from http://www.superunlockcodes.com/ to unlock your phone completely
Oct 05, 2009 | AT&T Blackberry Curve 8300 Smartphone
I'm locked out of my new Samsung a737
send it to samsung for 70$ plus shipping for a REFLASH. or do it urself kyletposey@mail.com
Feb 13, 2008 | Cell Phones
Network lock on Siemens A55, need to unlock to insert new sim
You can get the unlock code here http://www.theunlockspot.com/ and also get the unlock instruction in the same site....By using this you can unlock easily....
Jan 30, 2008 | Siemens A55
Samsung SCH-a650 Logo
138 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
