Does my TV need a NTSC tuner to watch dish network if it is NOT hooked up directly to a receiver?
  • 1 more comment
  • pazer22 Feb 01, 2010
    By default, my Dish Network receiver is set to "home distribution" on Cable channel 73, yet when I go to 73 on my second TV (19" DigitalLabs HDTV/DVD combo Model: DT496SA), I get "no signal". In fact i've done an autoscan for all cable channels ... NOTHING. Any ideas?
    There is definitely a splitter. But why when I plug a different TV into the same wire, it works fine?
    Thanks for your help, the TV was purchased in 2009. I've come to the conclusion that some HDTVs simply will not work on Dish's standard transmission .... I sold the TV today and will purchase a better one this week.
  • 8,197 Answers
No your tv does not need a tuner if you are not hooked up to the reciver. If you have one of the recivers that does two tvs then you just need to find the right chanel to put the tv on. It can be any where from 56 on up to 166.
Posted on Feb 01, 2010
  • Jyackle5
    Jyackle5 Feb 01, 2010
    Sounds like there is a splitter between the receiver and the 2nd tv. You can not have a splitter anywhere on that line. You need a direct line to the 2nd tv.
  • Jyackle5
    How old is the tv if it is older than 2004 then you will need the Tuner. I woul try the tuner to see if it will work.
How to hook up Dish Network Receiver
which Dish Receiver do u have. if it is a Dual Tuner (322,625,622, 722) u run a RG6 Coax from the Dish to the back of the Receiver. on back of the receiver there should be two ports (Dish 1,, and Dish2) u will need two short pieces of coax and a Separator ,(which should have come with the Receiver. u hook the coax from the outside Dish to the single port of the Separator , now u run a coax (or RCA or what ever) to the TV. Turn on TV and Receiver.
on the Dish remote u hit the Menu button and hit #6 then #1 and #1 again (wait for each screen to change ) u should see a signal bar at the bottom. U will need to get someone to turn the dish a little at a time till u get a signal. once u get a strong signal u hit the Check Switch and let it program.
Sep 23, 2014 | DISH Network Televison & Video
Added a 322 reciever to my lake house to be able to watch tv in 3rd room i had 2 standard recievers before. i installed a dish pro quad lnb & reciever had a separator w/it says dp plus 123254 tuner 2...
Is TV 2 off the 322 receiver being back fed from the receiver or do you have a direct connection to the 3rd room? If it is a direct connection, you would screw the coax from the 3rd bedroom directly to the TV 2 Home Distribution channel 21-69 out port.
If you are back feeding, you need 2 diplexers that connect 1) by the receiver and 2) between the receiver and the 3rd TV. The back feeding will use the same cable coming from the dish to the receiver.
If you have any other questions, please don't hesitate to ask.
Jun 26, 2011 | DISH Network 322 DTV Receiver
We cannot watch a show on another channel on other
Hello! Dan Busa here with DISH Network customer service. This is actually how your DVR is supposed to function. A 622 is a dual tuner reciever meaning it's capable of watching or recording two live shows at a time. When you record a show you tie up one tuner, there are two work arounds. You can get an additional dvr receiver or you can set up record preferences and have everything automatically record to tv2.
Jul 20, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Get dish network to work with hp SR5505F COMPAQ PRESARIO COMPUTER
You can not change channels on Satellite with your TV tuner card. The satellite box decodes the sat signal (it is sent encrypted) you can run S-Video/RCA/HDMI depending on the video card input, but you will be required to change the channel on the Dish box. The TV card can only change channels on broadcast (over the air) channels, you can attach an antenna and it will use the NTSC tuner to change analog channels (if they are still available) and the ATSC tuner to change digital/HD broadcast channels. This card (from your description can ONLY deal with broadcast TV, You will need a TV card with a QAM tuner for unscrambled digital cable. There is no solution for directly interfacing with Satellite on a PC or Mac (DirectTV or Dish) the signal from the satellite is encrypted and requires (at least for DirectTV, a fairly complicated decryption setup to function, this is handled by the tuner box/card combination. Sorry your setup will not support changing the channel on the PC, you may be able to find some kind of software that can utilize an IR transmitter to change the channels on your satellite box, similar to the way a Tivo or other DVR can talk to cable boxes, but that is the best you will be able to do as far as channel changing.
Jan 09, 2010 | HP Computers & Internet
So you are telling me I need a digital converter for this TV to g
Who was not watching the months of public service announcements? You need a Digital-to-Analog (ATSC-to-NTSC) converter box to receive over-the-air (OTA) signals in most parts of the country. You do not need one for most cable and satellite box outputs--they are NTSC or HDMI. Some low-power, typically religious, stations are still analog. Note OTA may be high definition (HD) or standard resolution (SD) but will be digital.
To get HD on your HD set you must have OTA (HD TV tuner, not converter), cable (QAM TV receiver), satellite (HDMI or 5-wire RCA),or Blu-Ray with HDMI or RCA.
-Ken
Aug 18, 2009 | Hitachi 46F510 46" Projection HDTV
Philips flat tv. Can't get it to hook up to dish network. The room where the tv is there isn't a dish box. We have to watch what is on in the other room. It only has one coax cable to hook up. Don't know...
I should be channel 3 or 4. This assumes that this coax cable is coming out as a TV R.F. connection of a Dish Network Box (Satellite Receiver) intended for direct connection to an old fashioned NTSC (channels 2-13, 14-83, possibly even has cable channels depending on how old?) TV.
If this coax is the output of a coax going directly to the Satellite Dish or through what might might look to you like some kind of fancy splitter (called a Multi-Switch) the you WOULD NOT want to hook that to your old NTSC tv. The frequency is too high ... etc. etc... you would need Dish Box (as you call it) a.k.a. a Satellite receiver - with a good and active satellite card from your provider.
Jul 07, 2009 | Televison & Video
Hooking Up Panasonic sc-ht670 home theater to Dish DVR 625 and Panasonic TH-42PHD7UY Plasma TV
You will need to run a set of audio cables from the TV1 output on the rear of the 625 directly to one of the three audio inputs on the surround system. Thanks for using Fix Ya.
May 13, 2009 | DISH Network DVR-625 DTV Receiver /...
Is this model 32A33 digital ready?
Not if you have Cable TV or Satellite TV. The converter is only needed to receive broadcast TV from an antenna. The signal from the Dish box will be fine as that is the tuner.
Cheers
Jan 04, 2009 | Toshiba 32A33 32" TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
