Question about Sharper Image Audio Players & Recorders
I have a 900MHz digital hybrid wireless headphones CT414. I had not used for some time. I charged for more than 24 hours but they are not working. The power blue light goes on the headphones. However, the power indicator blue light on the charger does not light up. What culd be the problem?
5 Suggested Answers
  • 3 Answers
SOURCE: batt. does not charge, even after 24 hours
Call up skullcandy and you'll get a replacement. They are really good at that.
Posted on Mar 31, 2010
  • 3 Answers
SOURCE: the operating instructions say that after 16 hours
I have the MDR-RF970R but I bet the battery is the same. If you have had the headphone for seceral years then I bet you are right, the battery is going. You might try using them till the battery dies and then recharge. This is called deep cycle and may time it will extend the life of rechargables.
If the headphones are new, then just check and make sure that they going all the way into the charge slot.
I will say it is not common for me to see the light off, but I use the headphones all the time.
Good luck.
Posted on Sep 20, 2010
SOURCE: They Won't Charge!
Try to press the power boton in the same time you plug the charger, after this action mine is working and charging perfectly, maybe this is the "reset" solution... Hope this helps you.
Posted on Feb 01, 2011
dancandoit
  • 436 Answers
SOURCE: I need to know how to connect my 900 MHz Digital Hybrid Wireless Headphones Model No. CT411
See if there is any audio output connections on the front or rear, they will be round connectors one red one white otherwise known as Phone or RCA. You may then require a small adaptor to change the two connectors to on 3.5mm jack plug, you can buy these from any electronics shops.
Posted on Nov 21, 2011
My nama is Wilhelmus Bongers, wimpie@nb.sympatico.ca , I recently purchased a RCA 900MHz Wireless Headphone set to be used with and connected to my TV. The batteries are now fully charged after a 17 hr...
I would suggest to double check the audio source that is getting into your RCA 900MHz Wireless transmitter. If you do not hear anything on the headphones it means that there is not audio getting into the transmitter.
Apr 01, 2008 | Televison & Video
Hi. I just purchased the insignia digital wireless headphones for my boyfriend and the headphones won't charge properly. It says to put the on the dock station and the red light will stay on(up to 4 hours)...
If the red light is on for such a short period of time, it probably means that the headphones are charged. The red light will flash for a long time and then turn green only when you charge on the dock headphones that need charging. I suggest to try to use them without charging them and see if the headphones work.
Dec 30, 2014 | Audio Players & Recorders
Nakamichi wireless headphone nw6000 beeps every 5 sec while using in wirelss mode. but when used with a direct audio jack it works fine.
battery is flat and will not re-charge, pries apart headband from body, locate two tiny screws holding battery in and remove by sliding
change battery and allow to charge on base for a full 24 hours
May 22, 2014 | GN Netcom GN 9120 Professional Headset
Charging problem?
The battery in the headphones is most likely not taking a charge anymore and will need to be replaced with an equal value rechargeable battery
Jan 04, 2014 | TekNmotion Airhead 1000 Wireless...
Will not stay on....
I dont have an answer or suggestion to this. I am having the same problems aswell with these damn headphones. I dont know what to do with em. The longest theyll stay on is about 10 minutes. Then they cut off. But it charges the headphones fine?
May 26, 2010 | Acoustic Research 900MHz Wireless Stereo...
Need head phones only for aw772 wireless
try on ebay.com  or just replace the entire unit as these wireless headphones are always getting better and less expensive.
Apr 01, 2009 | Acoustic Research 900MHz Wireless Stereo...
900MHZ CHARGING LIGHT STAYS RED AND DOES NOT GO OFF
Didyou try taking the battery out of the headphone and replacing it? This may act as a reset and allow charging. I'm assuming that these headphones are not brand new, and that you are lining up the arrow on the one side with the arrow on the charging base. This is the only way the inductive charging can occur. Good luck!
Dec 22, 2008 | Sony Camcorder/Audio/Video 900MHz Wireless...
556 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
Tom Chichester
woodzowl307
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
