Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
I have a whirlpool ultimate care 2 top load washer no spin
I have a whirlpool ultra care 2 top load washer where the spin cycle runs intermittently, and when it does it doesn't really spin the clothes dry. When I watch it cycle the spin mode (when it does start) seems slower than normal and the clothes are wetter than usual.
  • 619 Answers
Sounds as if the drive hub which the tub is attached to maybe free spinning. Not an expensive part but does require a special tool called a spanner wrench to remove and replace.
Posted on Jan 31, 2010
Testimonial: "The issue turned out to be a worn out clutch. The fix was actually to use a couple of dimes to increase the pressure on the clutch piece so that it would engage the drive hub. 2.5 years later and the thing is still working."
Whirlpool washer ultimate care II sometimes does not spin.
HI It sounds like the spin basket drive is going bad. If it was the lid switch, you would get no sound. Let me know if I can assist you further.
Thanks
Vic
May 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer motor spins but the TUB does not (intermittent)
If the motor is running and the tub is not spinning you must remove the motor and inspect the drive coupling.
One of the 2 plastic pieces could be stripped or cracked.
If the drive coupling is intact, proceed to the clutch on top of the transmission.
Replace the clutch linings.
Mar 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
The spin cycle for my
Dear shelldon39, Fri 2-20-2009 9:24pm EST (USA)
Some machines will shut down during the spin cycle as a precaution to prevent damage!
They will do this if you overload the washer with clothes and/or use too much detergent!
If this doesn't help please get back to me with more details!
jack
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My washer starts to run then trips the house breaker
Probably severe arcing on motor commutator due to worn out carbon brushes
Jan 24, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirl pool washer bangs when in spin cycle
if new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
Dec 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care 2 washer wont spin
Are you in the Delicate Cycle? Do you have spin speed control set for slow?If both answers are no,than what is the model & serial number??
Apr 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care 2 washer will not spin
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
Mar 11, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
489 people viewed this question
Dan Webster
Dan Webster
Sal De
