Question about Lexmark X5470 All-In-One InkJet Printer
My granddaughter put a toy in printer & a part broke off - thin, translucent piece about 1/4 inch wide by 7 inches long. How do I open up the printer in order to try to put this part back?
  • Official Brand Answer
  • 3,344 Answers
The plastic piece you are talking about it just prevents the paper from bending forward when is inserted in the printer. That plastic piece should not cause any paper jams or printing problems. If you do happen to have paper jams maybe a piece of plastic fell inside where the paper goes. Simply turn off the printer, remove the paper and flip the printer upside down and shake it a little that should remove any debris inside the printer.
Posted on Feb 01, 2010
I need a spacewarp 5000 english instruction manual
I think everything up to step 12 should be pretty self explanatory.
Steps 13 and up are below
13 - Initial ramp
Cut two pieces of wire into 150 cm (59 inches) lengths (may need to be trimmed down once put on track)
Connect one end of each piece to J-3 then thread through the following order
G-7, D-4, C-5, F-6, H-4, I-4
Connect to track separator piece (the piece with the flipper)
14 - Track A (Loop)
Cut two pieces of 270 cm (106 inches) lengths (again, may need to be trimmed down once put on track)
Connect one end to the side nearest G then thread through the following order
E-3, D-1, D-2, C-1, C-2, A-1, B-1, E-2, G-2, I-1, H-1, F-1, E-1, G-1, J-1
Nov 13, 2010 | Bandai Toys
Tip
To open watch case, hold back of watch up with arrow pointer on the back plate...
If you don't have the proper watchmaker's tools (and you'll need several!) I recommend that you not do this yourself. You could scratch the case or damage the movement if you don't know what you're doing. If it's a water resistant watch the gasket also needs to be replaced once it is opened. DO NOT reuse a gasket! For about $8 any watch or jewelry2_bing.gif store can change the battery and renew the gasket for you. Most Sears stores will do it while you shop.
on Jun 05, 2010 | Watches
When I put the cartridge back in the copier, a long thin screen fell off. It is about as long as the cartridge and about a half inch wide. I do not know if it fell off the cartridge or if it came off the...
This screen sounds like the charge corona grid. The grid is about 1 inch wide and a foot or so long. If so then it came out of the drum cartridge. If you look at the top of the drum cartridge, there is kind of a chrome metal bar with plastic "blocks" at either end. This is the charge corona assembly and that is where the grid fell off.
You can try to install it or as you suggested you can just replace the drum cartridge.
Good Luck and Thank You for using Fixya.
Sep 25, 2010 | Sharp AL 1631 Copier
The tape broke. How do I get it reconnected?
is the tape outside the cassette? or inside the case itself (if inside we have to open and connect it to reel) but outside you need the paper thin masking tape 1/2 to 1 inch wide (cellophane is to thick)...now take both ends of tape..the tape on left side cut a 1/8 inch (hold in left hand cut on a diagonal toward the left)..(just FYI this is called splicing) now the right one cut it about 1/8 inch also in the same manner toward the left)..now cut a 1/2 inch of masking place on table...place the right tape on tape leaving at least half for the other part to go on....now take the scissors cut off any excess masking tape on both edges of tape...this should help get your first job at hand done....recording to dvd....have fun
Feb 14, 2010 | Sony P6-120MP 8mm Tape
How to divide 12 11/16 inches into 71 3/8 inches?
you will need 5 full planks = 68 1/4 inches and the last board will need to be 3 7/16 inches wide.
Nov 15, 2009 | Freud FT750T Laminate Trimmer
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
The latch that opens the Trunk (Hatchback - as it is a minivan) is broken. I cannot open the back...
If you still have the broken piece, you can try to use that to try to open the back. Otherwise, you have to open it from the inside.
I changes mine in 2007 so if memory serves me, I had to remove the back panel and pull on the cable to open the door.
Now to see and pull on the cable, and replace the latch, you have to take off the inside liner/panel to get to the latch to replace it. This took about 2 careful hours to replace.
The trick is to get the two side pieces off.
These two plastic pieces are next to the window on the left and right sides. Each piece is about 3 inches wide and 18 inches long. Using a strong grip, or a pry bar or large screwdriver, take off both pieces. There are three clip areas that holds each piece in.
If you are using a tool, be careful to protect the area by wrapping a towel on the screwdriver/tool.
After that the bottom liner piece pulls away and you can see the latch.
There are two screws/bolts that holds the latch.
The two pieces snaps back in pretty easily.
You probably broke the plastic piece shaped like a J.
You can try to glue the pieces back, but note that the piece broke due to age. I changed the whole assembly - good for another 7 yrs. I could not find just the plastic piece.
Aug 29, 2009 | 1999 Toyota Sienna
ADF copy with black streaks?
lift up your adf and locate the thin piece of glass, about an 1' wide, and clean real good with rag and windex. probably white out or some foreign material on that glass.
hth,
razors
Feb 27, 2009 | Brother MultiFunction Center MFC-440CN...
Paper feeds with nothing on it
A common fault on these is the tab on the toner door that actuates the laser shutter breaks off.
On the front door around 3 inches from the right , there should be a thin piece of plastic 1/2 inch x 1/4 inch.
This should go into a corresponding slot on the printer.
If this is the case, fold up a piece of paper and push it into the slot.
Jan 26, 2009 | HP LaserJet 1320 Printer
Printer fell...extra part?
hmm..well..that may not be your only issue..if the printer fell to the floor.
Oct 13, 2008 | Dymo LetraTag QX50 Thermal Label Printer
Lexmark X5470 All-In-One InkJet Printer Logo
69 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
