Question about Whirlpool AWM8000 Front Load Washer
I need a replacement drain pump for a AWM8000 Dreamspace
I need a replacement drain pump But the pictures on other sites dont look the same. Can you help
Ricky is correct I found the best place to get them is on Ebay.
If the motor is bad you can by just that 3 screws. Boom! your finished.
Posted on Jan 07, 2013
  • 619 Answers
Part # 280187
Posted on Jan 31, 2010
How do I replace the drain pump for my Bosch WFMC530 Nexxt 500 Plus Series Washer drain pump?
the best way to change a pump is to do the following.
make sure the machine is fully disconnected and pulled clear.
remove the lid and using folded cardboard or old carpet, jam it down the side of the drum on the opposite side to the drain pump.
very carefully tilt the machine over onto its side (again cardboard or carpet on the floor to reduce damage to the side.
this should now give you access to the underneath of the machine with a good view of the pump with all the hose connections and wiring.
disconnect the wiring connector (usually held in place my a tag so may need a bit of a wiggle to get it out. it only fits one way, but just in case, take a picture to make sure.
using pliers or mole wrench, remove the clips from the inlet and outlet of the pump. leave the clips on the hoses so you dont loose or mix them up.
the pump can now be removed by unscrewing the unit from the front of the machine using a crossheaded screwdriver (normally a PZ2)
then its a simple case of reversing the procedure.
Dont forget to remove the packing in the washing machine and make sure all the connections are on correctly and secure.
Good luck
May 15, 2014 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Whirlpool awm8000 will not start
tengo una lavadora wirpool modelo AWM 8000 la pongo en funcionamiento y se enciende y apaga sola con lo cual el programa no camina
Nov 03, 2012 | Whirlpool AWM8000 Front Load Washer
How do clamps attach to machine and drain pump?
i would need to see a picture of what ur talking about but sounds easy i was an appliance tech
Jun 08, 2012 | Whirlpool Washing Machines
I cleared my outlet pump (Whirlpool AWM8000) area of coins, etc. Since as it was come up with error FP (drain fault). It drains during wash, but the last part of wash (last 5 min) it make a noise and error...
I would still suggest you go through the whole action all over again JUST to make sure that something hasn't been 'released' into the filter or the pump area. As the pump is managing to drain most of the water I wouldn't think that it is at fault. I would be interested to know if the 'error' is the same- 'FP'(?).
Here are my pre-typed complete (sorry!) guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
Mar 30, 2011 | Whirlpool AWM8000 Front Load Washer
My Whirlpool Washing Machine 6th Sense 10kg Dreamspace has stopped washing mid-cycle and has a F09 warning flashing
my whirlpool 6th sense dreamspace has a red ligth lit indicating water tap closed can anyone explain why?
Mar 15, 2010 | Whirlpool Washing Machines
I have an F 02 error on my Kenmore elite. The
Accessing the Drain Pump on Kenmore Elite and Whirlpool Duet Front Load Washers
  1. Safety first. Unplug the machine.
  2. Put a blanket over the top rear edge of the machine to cushion it and lean it against the wall.
  3. There are three screws located right at the bottom front edge of the machine securing the toe panel. Remove the screws and the toe panel will fall off.
  4. Open the door covering the wiring harness connector and disconnect the wiring harness from the terminals of the pump motor.
  5. Remove the screw securing the pump assembly to the frame of the machine.
  6. Remove the drain hose and tub outlet hose from the drain pump assembly.
  7. Put a small pan or bucket under the pump and turn the large knob counterclockwise to remove and clean the large item filter.
  8. Unscrew the drain pump from the pump housing and check the impeller for any obstruction or damage.
  9. Replace the drain pump if the impeller is damaged or if no obstruction is found in the drain hose, tub outlet hose, and the large item filter.
  10. Install the new drain pump in reverse of the removal steps above.
Jan 24, 2010 | Kenmore Elite 45986 Front Load Washer
AWM8000 push button for door has snapped off can I get a replacement?
There should be no problem getting the part you require for your washer.
Go to:
www.whirlpool.co.uk.
You should be able to get what you want there.
Hope this helps solve your problem
Dec 12, 2009 | Whirlpool AWM8000 Front Load Washer
AWM8000 AF flashing and machine cut out, very
WHEN I PRESS START - HAS ALARM ON DISPLAY F AND H FLASHING AND TAP OPEN POSTER HAS THE FLASHING LED TOO. HO TO REPAIR IT.
MY NAME XUAN
Sep 29, 2009 | Whirlpool AWM8000 Front Load Washer
Whirlpool AWM8000 Front Load Washer Logo
176 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
