Question about HP PSC 1315 All-In-One InkJet Printer
My HP 1315 all in one will not print, I have installed new ink both black and color. Paper balls up when the printer takes in the paper or it just does not print anything.
Pro 8500 printer. Just installed new color ink cartridges. Why isn't color printing on printed material?
Hello, Take the ink cartridge out and dab on a wet paper towel until the ink start flowing or the ink cartridge is bad or the print head needs to be cleaned on the printer.
Nov 21, 2015 | HP OfficeJet Office Equipment & Supplies
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
My printer states "paper jam" although I don't see any paper. I bought new ink cartridges & it doesn't print the multi-color, only the black.
Paper jam means just that. Look for paper or a piece of paper jammed into a gear or stuck between a roller or even in your ink cartridge . When you put in your new ink did you take off the protective seal and run the HP software to check if it is reading the Cartridge ,You might want to read the instruction on how to install an ink cartridge. It might also help you ?
Nov 03, 2014 | HP Deskjet 3052A
My hp 1315 check paper is blinking
un clip the back door there might b a jam of paper that u cant see but printer can detect once u have done that u must !! pres enter 2 reset it after u have replaced the rear door of course
Sep 28, 2012 | HP PSC 1315 All-In-One InkJet Printer
My brother gave me hos psc 1315 he had.The printer wasn't workin 1 year and i tried now to work and it doesn't print! The black ink is new (it prints 1 time when it wants not so clearly and then...
the printing cartridge are probably dry out. you can try to take them out and touch bottom side with soft paper to see if any ink will leak out. you can try to shake them rapidly while holding in hand, keeping the paper on the bottom side (because if theres ink you will get dirty :)
Sep 18, 2011 | HP PSC 1315 All-In-One InkJet Printer
My printer is not printing out any black ink onto paper. Only the color is printing out onto paper. I put two brand new cartridges in for the black ink and color ink, and it says that the ink levels are...
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It’s best to do this each time you install a new cartridge. for more information….... http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Sep 03, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
It will only scan not print
If you refill you Ink Cartage on this Please make sure the Ink is primed. If you touch a paper towel to the bottom of the ink cartage and the tale stays dry It is the cartage.
If that is ok Make sure that the door and the contact(If you can see it) Is closed and in good shape
Jun 24, 2010 | HP PSC 1315 All-In-One InkJet Printer
Problem after refil
check here
http://www.youtube.com/watch?v=sOriLrbuBao
Apr 28, 2009 | HP PSC 1315 All-In-One InkJet Printer
Trouble shooting my printer all in one 1315 series
You need to clean the rollers in the back panel of the printer.
Unplug the printer while it is powered on and remove the back panel. Get a damp cloth (not too wet) and wipe off the rubber rollers in the printer as well as on the panel. Replace the panel and plug printer back in. It should come on by itself and initialize.
Print a page from your computer. It should now only feed a single sheet at a time.
Jul 31, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Print Cartridge Error
Hello -
Did you perhaps not mean to post under the 1315? I am not sure if you have this printer or another model. The 1315 normally takes a different number ink cartridge.
Meanwhile - gotta tell you that the 1315 is the buggiest printer I ever had. If you purchased it recently and can find your receipt, I'd take it back! Since they've pretty much done away with the 1315, if it was a recent purchase, it was likely a clearance item from some place.
Try taking all the ink cartridges out, uninstall the printer entirely, and reinstall it (the entire printer, not just the cartridges). Blow your printer out with canned air as well - dust, pet hair, people hair, fuzz and general paper fibers can build up more than we think, and cause error messages and other printing problems.
That should help, if it was the 1315 model.
That being said, note that if it still doesn't work, and you have the 1315, save yourself a lot of grief and toss it in the trash and buy another cheap printer! 1315 is Bug City!
Jun 07, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
67 people viewed this question
Seeker5211
Seeker5211
