Question about RCA HD52W59 HDTV Projection Television
Black spots on the convergence board of rca hd52w59. Can I just replace the tiny parts that are bad? What are they exactly for when I order? Location CA010 capacitor? & IA010 black box with 8 legs
  • deidre035 Jan 31, 2010
    My problem is that I have no idea what the parts are called or how to go about ordering them. I don't want to order the wrong thing. Can I email you a pic? Thank you!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and check power resistor for leakage, if values are not exact you have to replace them. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jan 31, 2010
  • Rylee Smith
    Rylee Smith Jan 31, 2010
    Just let them know that you want to replace the STK ICs on the convergence board with the model no# for your TV. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
I have a RCA hd52w59 it will not auto converge so I tried to manually adjust and still has to much blue and red also sometimes when I turn it on the power light blinks and will not power up. Will a...
If you know how to solder ,you need to resolder all the pinns on the FBt flyback transfomer on the deflection board which is the bottom left hand side board.Then see what the TV does.
Convergence Kit will not fix this problem, different chassis from other TVs that have convergence ICs. These sets here were RCAs worse design. they made over 27 different Deflection boards and 32 ssb boards they all look alike but connect differently. They had alot of Bad Tubes ,Yokes, FBT
Poor Solder Connection ect...... Back in 2004-2006 these sets were coming in by the semi truck loads with defective parts at the service center. But when these sets are right and have minor problems they are nice. about the power problem Bad Capacitors will cause this CP150 CP120 CP114. CP 150 2200uf 16v use 25v if you see it swollen or vented on Top then replace all 3 caps other 2 are in same circuit 220uf 35v on the deflection board.
PTS rebuilts boards 1-800-844-7871
Jul 29, 2011 | RCA HD52W59 HDTV Projection Television
I have an RCA HD52W59 HDTV and my kids were watching the other day and all of a sudden the screen went bad. The sound is ok and you can still see the picture however it looks like your watching in 3D...
This is normally an easy fix. I've fixed several of these. When you get the back off of the set, there are 3 small square brown fuses located at the back left corner of the set, if looking at it from the back. They are located next to the right side of the flyback transformer( the large gray or black thing sticking up with the thick red wire coming out of the top). One of those fuses will be open and needs to be replaced, and the pins on the flyback transformer need to be resoldered on the bottom of the board. They will come loose and make the fuse blow. This will fix the problem 95% of the time on this set.
Sep 02, 2010 | RCA HD52W59 HDTV Projection Television
My rca hd52w59 tv looks like its in 3-d. auto covegnence used to solve the problem most of the time but now it does nothing. pic is constantly looks like 3-d now. the colors r all not right. i get it close...
Hi
Thanks for using FixYa. You’ll need to change the convergence chips which are located behind the black heat sink; you can see once you open the back off the TV. You can buy the convergence chips from this link; also if you want you can buy repair kit which comes with complete installation and parts. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 07, 2010 | RCA HD52W59 HDTV Projection Television
Convergenc problems w/ RCA HD52W59 HDTV
sorry but u replace the incorec part , the board which control the convergence voltage on and off is the deflection board , now this board is about $100 - 150 , or if u want to fix it , just solder the flyback , just go to radio shack and get a 25watt solder station and solder rosin , also check for bad fuse , this fuse it dont look like the others , this is a 1/2 watt 250 pico fuse , and is next to the flyback , look like small brow squer little box , there is 3 and the one that is bad is the one in the middle , this 3 pico fuses are togethere u cant miss then , good look
Apr 16, 2010 | RCA HD52W59 HDTV Projection Television
My convergence keep going out, I replaced the convergence twice. I have a rca hd52w59 modle
When you say replaced the convergence twice, are you refering to the convergence boards or the FL231 fuse? If its the FL231 fuse unless you replaced the DL231 and CL230 plus reflowed the solder on the flyback it will continue to keep blowing untill the 3 parts are replaced together and the flyback gets resoldered. If you replaced the convergence boards then try resoldering the flyback.
Nov 27, 2009 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 3d screen colors are seroperated no convergence
i have found the reason for the fl231 fuse blowing is faulty solder connections on the flyback transformer is the main cause. I have came across only one bad signal board that cause this but this was very very rare 1 in 1000. This is a very specific fuse, .400 and it is recomended only to replace with exacte one. consult the fl231 problem in the tips and tricks section.
Jan 02, 2009 | RCA HD52W59 HDTV Projection Television
HD52W59 Convergence Power Supply
you can get the replacement ITC222 convergence power supply board at the following link. They have one at promotional sale price this week also under the sale items category.
http://servicemanuals.vstore.ca/
Sep 07, 2008 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 convergence?
Before you go and buy parts it might be worth your time to check the convergence power supply fuse. It's located in the back of the TV just to the right of a large black component with 2 red wires coming off of the top. This is the flyback transformer. Just to the right of the flyback you should see three fuseable links that look like chicklet's gum. The one that may have fried is the one in the middle, it's a 400mA 125V fuseable link. Hopefully thats all your problem is.
Apr 28, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD Projection TV Model HD52W59
you have a fusible link that has blown. This is what causes the convergence option no be erased from the menu. You will need to locate the blown link and replace it. They are identified by FLpreceeding the location number on the circuit board such FL221 and etc.
Mar 23, 2008 | RCA P61927 61" Rear Projection Television
Convergence Problem
the 271860 is a convergence power supply IC. Exactly what was your problem, and could you please include the chassis number from your set, as rca has to be diagnosed by chassis number.
Mar 14, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
