Question about Broan-NuTone 679FL Combination Light Fan Exhaust Fan
Replacing old fan with a new broan fan and light kit fan works but light does not come on.the fan has a white and black wire and the light has a blue and a white .i pu the white and the blue to the main black along with the black from the fan and the fan white to the main white still does not work.help
  • 494 Answers
White wires are neutrals and must be tied together to the power lead-in white wire. The black goes to the hot interrupted by the switch. The Blue wire is the hot for the fan but is interrupted by a separate switch. If you want to use one switch then the blue goes to the same black for the motor.
Posted on Feb 12, 2010
Want to attach a harbor breeze light kit to an existing hunter fan. switch housing has 3 white wires hooked together with a blue connector cap and a single black and white wire(labeled for light). there...
White to white ( single white ) & blue from light kit to Black with white stripe. Also make sure the black with white stripe coming out of TOP of fan is connected to the hot wire.
Aug 26, 2013 | Hunter 52" Ceiling Fan With Light And...
I have a 12/2 (black/white/ground) power source to the leviton 1755 switch. And, I have two (2) 12/2's going to a Broan 100hl (vent, light, heater). Please help wiring switch and Broan; on...
The switch that you have works like 3 seperate switches. most of these switches will have gold screws
on one side and silver screws on the other side, lets say that the left is gold and the right is silver, and
the switch may also have a green screw for ground. your 12/2 with ground is your main hot, you may
want to mark it with a piece of tape, so you know it's the incoming hot. the ground off your hot will tie,
to the green screw on switch and continue and tie to your vent light which should also have a ground
the white coming off the hot is your neutral, it will go straight to your white or whites on your heater.
the black hot wire at your switch will go to each gold terminal on one side of the switch,there are two
ways you can do this, go to one side and just run a jumper, or put one wire on each gold screw and
tie in to your hot-black wire with a wire nut. now for the switch legs, you will need to run from your, switch
to your heater either another pair of 12/2s or a 12/3, each side of the switch that has one silver screw,
it's easier with a 12/3 normally a 12/3 will have a red,black,white,and ground.
top switch red to red on heater,black to black on light and the white blue on the vent,so from your switch
to the heater you would have to run a12/2 you would not use the black only the white and ground.
remember the white-neutral coming from the switch will be tied to all the whites at the vent,light,heater
except for the 10/3. the 10/3 is used stricktly for the switch legs. good luck!
Jul 09, 2011 | Leviton 1755 Triple Rocker Switch Decora
I need help wiring my fan. I can't get the fan to work, but I do have the light working. From the ceiling I have a white, black, red and ground wire. How should these wires connect to the White, Black,...
White is your neutral so white goes to white. Blue on the fan is for the light kit you need to wire that to the wire from your switch so it works the lights. Black is the hot wire that is always hot not switched so tie that to the wire that is not on your switch. Green is ground so green to green. white to white / green to green/ black to black/ red to blue/
Nov 06, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Installing Broan exhaust fan/light/night light model QTR070L. Am connecting with a single switch power source. Fixture has three whites, one blue, one black, one red and the ground (green). In what color...
Hi .. with only bone switch for this combo unit, the connections would be like this .. all ahites together with the romex white , all colors, red, black, blue with the romex black, all greens together IF you had more than one switch , then the red, black, blue would be connected separately to one switch eack and separately to a 4 wire romex from the switch to the combo unit.
Apr 17, 2010 | Broan-NuTone Broan 110 CFM Premium Bath...
Can this fan be installed without the light kit? If so, will the upper light work?
most newer ceiling fans have 3 wires, a black, white and blue. The blue is for a light kit which is optional in most cases. All other functions should work.
Dec 11, 2009 | Hampton Bay AC434-NI Ceiling Fan
I am attempting to replace an old bathroom exhaust fan with a Broan 680 fan/light. I am having a problem with the wiring. There are 2 wall switches for the light and fan. The existing wiring has red,...
The red and the black are the hot wires. One will be the fan and one is the light. The white is the 'common' for both fan and light.
It sounds like the new fixture has got one hot for both the light and fan, they will both run all the time from one switch. This is the blue wire. Hook it to the red or the black, which ever one comes from the switch you want to control it. Hook the white to the white on the new fixture.
The green is just a ground. hook it to the new fixture green or ground terminal. Cap or the black or the red that you don't use. It won't be need for the new one. The switch that it comes from will not control anything now.
Jul 25, 2009 | Broan-NuTone FAN CONTROL SWITCH
Wiring problems
The only thing which goes to the house's white wire is the fan's white wire.
Both the black and blue wires from the fan (black for fan motor, blue for light kit) go to the black house wire.
Anything else could result in a fire, a melting of internal parts, or a massive electrical explosion arc. The owner's manual is very clear about how the fan is supposed to be wired, and you voided the warranty by going against it.
You may have blown a fuse or a circuit breaker, or you may have blown something within the fan, or your house may be wired in series (very unlikely) in which case you need a new separate wire run for the light kit.
I hope this helps! If you have any other questions, feel free to ask!
Apr 17, 2008 | Hampton Bay 24002 Ceiling Fan
Replace exhaust fan with fan & light?
Let's say you originally only had one switch (to operate the fan). And at the fan you have only one black, one white, and one ground (bare or green). You can still put in a fan/light combo. but both the light and the fan will always come on together when you flip the switch. To do this you'd connect the black from the switch to the black AND the blue on the fan and connect the white from the switch to both whites on the fan and connect the ground from the switch to either a green or bare wire on the fan or to a green screw on the fan housing somewhere (whatever is available).
Feb 25, 2008 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Broan-NuTone 679FL Combination Light Fan Exhaust Fan Logo
214 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
Craig Dupler
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
