Question about GE WCVH6260FWW
I have GE ser#GD145396G and will not drain water but makes sounds like it wants to start. How do I disasemble the top to get inside?
REMOVE THE BOTTOM PANEL AND LOK FOR A ROUND PLUG, UNDO THE PLUG AND CLEAN THE FILTER.
Posted on Aug 02, 2010
  • 619 Answers
You don't remove the bottom panel and there is the pump under the tub not the top.
Posted on Jan 31, 2010
How to disasemble water tubing from GE 7405GFW side by side icemaker?
That isn't a good model number. Look inside the refrigerator section , probably on the upper right wall for your model number.
ge refrigerator leaking water YouTube
Sep 07, 2014 | GE Refrigerators
Whats wrong with our ge washing machine it keeps draining water,it is brand new just arrived.what do you think is the solutions to our problem. everything is being put together, we already install the...
make sure the drain hose is higher than the washer tub sounds dumb i know but if the drain hose is left lying on the floor going into a floor drain or something it will not fill up
Mar 23, 2011 | GE WBSR3140DW Top Load Washer
Unit won't start when you push start on keypad. It does make a buzzing sound. Top of dryer is hot. GE Profile model dpsq475et6ww ser at724827a
Can you turn the dryer easy? Try holding in the door button and starting the machine while giving it a boost by hand. That might free up whatever has it binding.
Jun 09, 2010 | GE Dryers
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
I have a refrigerator that leaks water inside at the top
flush out drain hose in drip tray in back of ref with hot water line is most likely stoped up
Sep 14, 2009 | GE Refrigerators
GE Top Load washing machine not draining
  • to me it sound as if waterpump is not working
Apr 09, 2008 | GE WDSR2080D Top Load Washer
Refridgerator Leaks
I can't find this model number anywhere and am unfamiliar with the "Evolution" series. However, if it is a top/bottom unit (freezer on top, fridge on bottom) it sounds like you have a clogged drain.
If you pull the back panel off inside of the freezer (where the evaporator is housed) you will see a drain hole, usually in the rear center) that is probably full of ice. If this drain is plugged, it will cause the water to back up into the refrigerator, usually onto the top shelf or under the veggie bins, and possibly onto the floor.
You need to clear it out, and make sure that water flows through it freely, to the pan underneath the unit. The best way to do this is with a hair dryer and a copper wire, but be careful not to melt the inside of the freezer with it. When it's clear, you might want to take a hose and blow through it to make sure there's nothing trapped inside.
Please let me know if you need any further help with this issue.
Mar 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag Atlantis top loading Washer
try using compressed air at a low PSI (40-80) blowing through the drain hose backwards. besides that you will have to axcess inside parts to disasemble and clean the pump/hoses...
Jan 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Aug 16, 2007 | GE WPGT9360EPL Top Load Washer
GE Nautilus ...
Does water drains out properly ?
May 02, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE WCVH6260FWW Logo
133 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
