Question about Ovens
Cant turn on oven switch on a Valor classic 2 Si cooker . I push in the knob to turn the oven on but it wont turn , Is there some form of interlock that needs to be operated to turn the knob on other than just push and turn?
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: I have an AEG cooker but the marking around the cooker knobs have
Hi.
You need thermostat knob and main oven control knob.
Posted on Nov 20, 2008
protek480
  • 1714 Answers
SOURCE: Hotpoint cooker, grill doesn't work but top oven does
If the elements 'look' okay, they probably are. The 'infinite control switch' is probably the problem. With out the use of a meter, it's guess work. Unless you can see a connection problem.
Posted on Sep 03, 2009
Testimonial: "very useful thanks"
SOURCE: I have a valor classic 2 si cooker and the door
I have same problem and psoke to valor (now Stoves ) and this item is now obsolete, unfortunately I have had to buy a new cooker.
Posted on Apr 05, 2010
Two large cookers light up but as soon as the knob is released they stop burning
bad igniter switch aka the knob ur pushing is bad can check with a multi meter for continuity
Mar 07, 2015 | Ovens
I have a cooker model venezia FE 8622EX and i dont have a manual for it and cant work out with knob does what as the writing is rubbed off through use...please help!
The 3 knobs each have 6 positions corresponding to clock-face positions 2,4,5,7,8,10 o'clock.
Left - Grill Temperature 1-6. (Note Oven Temp needs to also be turned on before grill will work.)
Centre - Function
1 - Lamp
2 - Defrost (fan only)
3 - Fan Assisted Oven
4 - Grill
5 - Grill with Fan
6 - Fan & Bottom Element
Right - Oven Temp 50,100,150,200,250,Max (celsius)
Sep 12, 2011 | Ovens
I have a valor classic 2 si cooker and the door hinge has broken and also the plastic strip on top of the door where can I purchase a new hinge/plastic strip or door?
Mar 19, 2010 | Miele H378B2 KAT Electric Double Oven
Need to reset my whirlpool 2000+ cooker
Do you have a push button in the centre , between 2 dials and under display? If so, try pushing it twice then turn oven dial
Nov 14, 2009 | Whirlpool RBS275PD Electric Single Oven
Sep 03, 2009 | Ovens
I need a manual for a neb verona ss fe2623exx oven
I have a manual for this oven which I can copy and email to get the grill to work you need to in this order.
Switch oven temp to max
then set function to grill
then set grill temp to what ever.
If you dont do it in that order the grill wont come on for some raeson.
Feb 26, 2009 | Verona Ovens
Hi.
Nov 19, 2008 | Ovens
Electrolux EOG7330 gas cooker - electric timer fails?
Pull off bottom knob of oven shine torch down at 45degrees u will see a red plate turn off power suply and use a small screwdriver to push the plate turn power back on job done.PS Check all vents are clear to stop it over heating good luck.
Jul 18, 2008 | Electrolux EOG7330WN Gas Double Oven
Re: my whirlpool digital oven
The red key sign is a lock against children. To cancel it you have to hold the two buttons at the same time for 5 seconds (you activate it the same way).
The STOP sign appears after the cooker switches of after a power cut. You just have to press the left button, and, using the right knob, set the time.
Jun 24, 2008 | Ovens
How to light our gas cooker
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Feb 23, 2008 | Ovens
Ovens Logo
29 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
