Question about Sony Playstation 3 (PS3) Console
We had the PS3 hooked up with component cables on TV1, we then moved it to TV2 with HDMI, then when we went back to TV1 with Component, the TV is not recognizing it. Any thoughts?
Hold the power button down to reset the ps2 the reson your screen is black is it is still set to hdmi. hold the power button down, it will reset to default and you can adjust the settings from there
Posted on Jan 31, 2010
Dvr 625 from dish
To whom it may concern,
As a technician whom has been in the field for nearly a decade, my suggestion is to contact Dish Network customer service and set up a technician visit.. I know that there are far too many variables that could influence my answer and how I structure it, likely leading to more issues.
Best of wishes,
Dish Guy
Feb 13, 2014 | DISH Network DVR-625 DTV Receiver /...
I have a Durabrand tv. Model DWT 1304A. How do I get my Dish network to work on it. What do I set my tv. and how do i do it. Thank You
I hope that you have gotten this resolved, but if not, here are some steps to get that working!! I hope this helps!
If you are at TV1, where the receiver box is located, the tv needs to be on channel 3 or 4. Depending on the cable that is running between the receiver and the tv, the tv may need to be on an input, such as video 1 or 2. If you are at the TV2 location, where there is no receiver, then the tv needs to be on channel 60 or 73.
If you are using an HDMI cable, then the TV will need to be on an HDMI input
If you are using Component cables, your TV will need to be on a component input. (Usually Comp 1 or 2)
If you are using RCA cables, then the TV will need to be on a VIDEO input (Usually Video 1 or 2)
If you are using COAX cables, then the tv needs to be on channel 3 or 4 (If you are at TV2, then the TV needs to be on channel 60 or 73)
Becki Barned
DISH Network Customer Service
becki.barned@dishnetwork.com
Aug 07, 2011 | Durabrand DWT1304 13" TV
How do I take my tv off of single mode to dual. And every time the tv1 and tv2 are on diffrent channels, tv1 has the sound from tv2 on it. How does that work?
There are two parts to this, to switch modes just press the mode button on the front right side of the receiver. You are most likely using one of two types of cabling either rca cables these have threecolored tips (red yellow white) or component cables these have five colored tips (red, red, blue, green, white) if this is an HD set up your probably using the component cables. If you look on the back of the receiver all of the cables RCA or component should be connected directly under the green TV1 picture.
Apr 06, 2011 | DISH Network IR Remote Control
Our new vizio tv is hooked up just like our old tv, (satellite provider being dish network) and it says no signal with a blue screen
Hello. This is usually an easy issue to fix. To get the DISH Network back on the screen, i have included a few steps:
Becki Barned
Feb 26, 2011 | Vizio VX32L Television
Can't get my westinghouse tv to recognize dish network
Happy to help get that fixed right away!
You mentioned that your TV is not recognizing the DISH Network signal, since wedo not know how many TV's your receiver is able to support, or whether it's theTV1 or TV2 having the issue I will address them both.
The first thing we want to do is ensure that all connected components arepowered on (VCR, DVD Player, etc.). Check what channel or input your TV iscurrently on by powering the TV off then back on and noting the channel orinput that appears on screen when the TV is powered on.
If TV1:
Check what type of cable is used to connect the TV to the receiver. If you areusing a Coax Cable to connect the receiver to TV1, check the receiver'sback panel for the output name. If your receiver has a "TV CH 3/4Out" (non-ViP Receiver): Tune TV to channel 3 or channel 4,if it has "Home Distribution" output (ViP Receiver): Tune TVto channel 62 or 75. If using non-Coax (RCA, Component, orHDMI) to connect receiver to TV1, cycle through the inputs until pictureappears; most TVs have a "TV/Video", "Input", or"Source" button. If the issue persists, check that theconnections between your DISH receiver and your TV are secure then reset thereceiver by unplugging it from the outlet for 10 seconds then plugging it backin. If not fixed then connect another component (VCR, DVD Player, etc.) to thesame TV, using same cable, same input, and same channel to see if it works. Ifit works with the other component then call us at 1-800-333-DISH (3474) foradditional troubleshooting, if it still doesn't work with the other componentthen the cable should be replaced.
If TV2:
Access "Modulator Setup" from TV1 by pressing the menu button(on the top left of DISH remote) then pressing the numbers 6-1-5. Tune TV2 tothe channel that appears under "TV2 Out" on screen. If stillno picture, verify the mode (air or cable) that TV2 is on. Then change themodulator setup to match this mode (air or cable). After changing modulatorsetup, tune TV2 to the channel that appears under "TV2 Out" onscreen. Check that the connections between your DISH receiver and your TV aresecure then reset the receiver by unplugging it from the outlet for 10 secondsthen plugging it back in. If not fixed then connect another component (VCR, DVDPlayer, etc.) to the same TV, using same cable, same input, and same channel tosee if it works. If it works with the other component then call us at1-800-333-DISH (3474) for additional troubleshooting, if it still doesn't workwith the other component then the cable should be replaced.
Phillip Chang
DISH Network Customer Service Representative
Feb 06, 2011 | Westinghouse SK-32H240S Television
I have dish network and am trying to watch tv on my gateway plasma. how do i connect my satelite cable to plasma to get picture?
We would like to guide you through the connection process,but depending on what kind of receiver and TV you have this process may vary.Visit our "How to connect receiver" page here:http://www.dishnetwork.com/SupportSection/setup-receiver.
Once we have everything connected correctly, check what channel or input yourTV is currently on by powering the TV off then back on and noting the channelor input that appears on screen when the TV is powered on.
Steps for getting picture on TV1:
If you are using a Coax Cable to connect the receiver to TV1, check thereceiver's back panel for the output name. If your receiver has a "TVCH 3/4 out" (non-ViP Receiver): Tune TV to channel 3 or channel4, if it has "Home Distribution" output (ViP Receiver):Tune TV to channel 62 or 75. If using non-Coax (RCA,Component, or HDMI) to connect receiver to TV1, cycle through the inputs untilpicture appears (this information may appear on the remote sticker), mostTVs have a "TV/Video", "Input", or "Source" button.
Steps for getting picture on TV2:
Access "Modulator Setup" from TV1 by pressing "menu"then 6-1-5. Tune TV2 to the channel that appears under "TV2 Out" onscreen. If still no picture, change the "TV2 Out" mode fromAir to Cable, or if it's already on Cable, change it to Air. Then change thechannel of TV2 to what is now displayed under "TV2 Out".
If the issue is only on ONE receiver, unplug the DISH receiver for10 seconds and plug back in. It may take up to 5 minutes for the reset processto be completed. If you still are not getting a picture, connect anothercomponent (VCR, DVD Player, etc.) to the same TV, using same cable, same input,and same channel to see if it works. If it works give us a call at1-800-333-DISH (3474) for additional troubleshooting, if you don't get apicture with the other component, replace the cable.
Hope this steps help, and thank you for being a valued DISH Network customer!
Phillip Chang DISH Network Customer Service Representative
Dec 02, 2010 | Gateway GTW-P42M303 42 in. Plasma...
Ive had my PS3 hooked up using HDMI for years now but i bought a component cable because i have just bought a PVR and it can only record using component and not HDMI. The problem im getting is that when i...
Hook it up with the component cable and then hold the power button on the console until something comes up on screen. Make sure you have selected the component input on your tv or else you wont get anything anyway.
What holding the power button does is it resets the video settings to the lowest common denominator and then you can reconfigure it for the optimal picture quality of the component cables.
If that doesn't work double check the component connections on the back of the TV and just make sure they are where they should be and that no accidents were made while hooking it up.
Please post the results from these steps here so that I know what happened.
Jun 09, 2009 | Sony Playstation 3 (PS3) Console
Ps3?
Check the couplings at either end of the cable. Sometimes these will loosen and can cause a lack of signal strength.
but its probably not the cable, its probably the ps3. HDMI cables don't really break because they are just wires, they don't have moving parts. Try connecting your PS3 to your TV with the regular cable red, white, and yellow connectors that you got when you bough the PS3. If the PS3 doesn't work with the original red, white, and yellow connectors then you know its the PS3. If the PS3 does work fine, you know its either the HDMI cable (still unlikely) or the HDMI connection on your TV or PS3 (more likely
Oct 12, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
55 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
