Question about Canon PIXMA MP780 All-In-One InkJet Printer
Old lexmark paper feeder slips
My paper feeder does not work anymore. I suspect that one of those springs on the "roller" is not in its proper setting. There are two wires from the spring that seem to have moved out of position.
The paper either does not feed, or 2 and 3 sheets feed at the same time.
Is it time to get a new printer -(Lexmark X63 All-in-One)? Or can I fix this myself?
Thanks!
  • johnsondean May 11, 2010
    PS I have a Canon PIXMA MP780 that no longer feeds paper, but sounds very iratating alarm. Thanks
    Where is the IT paper tray Relay and how do you clean it?
  • 28 Answers
Nooooooooooo . Don't buye new Printer
It simple problem IT paper tray Relay has to be cleaned . Pls clean the Relay with the dry cotton cloth and refit it . It will Work fine ..
Thank You
Posted on Feb 19, 2008
Load paper, push bottom to print but you can hear it start to print but paper starts to go down and twist and doesn't go the feeder
Hi, Look at the paper path for any obstruction or loose pickup roller. The paper might be old and have moisture replace with fresh paper and try again. Hope this helps.
Mar 13, 2010 | Lexmark X5470 All-In-One InkJet Printer
The paper keeps jamming during feed I have changed it but it still jams, I think there is a fault with the feed section at the bottom but I cant find a manual that shows technical details for repairs so I...
Did you replace paper feeder with new one? Most paper feeder problem are rubber at paper pick up roller (bottom side) and small spring at bottom paper pick up roller. Check for "something" slip at paper feeder and lubrication at paper feeder mechanic.
Feb 02, 2010 | Epson Office Equipment & Supplies
The paper does not feed properly.
Replace the paper feeder or the rollers on the paper feeder are not rolling ar getting jamed. You need to have this serviced or just get yourself another printer. Lexmark are what I call in my expert advice throw aways the better ones are epson,xerox,HP and so forth. Please leave positive rating and feedback thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Oct 09, 2009 | Lexmark X3480 All-In-One Printer
Paper feeding in crooked
Check that all of the sliders in the feeder tray are snug against the paper. Sometimes they tend to slip out and allow the paper to wiggle in the tray resulting in a crooked feed. Other possibilities are dust buildup on the rollers, or worn rollers causing the paper to slip on its way through the printer.
Jul 17, 2009 | Lexmark X4550 Multifunction Wireless Color...
Lexmark x5435 paper feeder broken
Feeder goes halfway down & stops on Lexmark #5270 & would like free answer
Mar 16, 2009 | Lexmark X5470 All-In-One InkJet Printer
Top feeder won't work properly
hello!
have you tried cleaning the separator pad inside the automatic document feeder?
try to Load one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.
If the problem persists, clean the rollers and separator pad manually
May 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
Paper will not feed
Check for a jam again somewhere in printer unit, rollers, teeth, down back in paper feeder area. I thought i had no jam in my unit either until i got a torch and found the tiniest slip of a shred barely noticeable right in the middle of the teeth/roller. Remeber to turn it off after this, to reset it.
Aug 16, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Canon PIXMA MP780 All-In-One InkJet Printer Logo
78 people viewed this question
old marine
old marine
