Question about Beverage-Air Refrigerators
Beverage-Air bottle cooler freon leak.
I own a Beverage-Air SF34-B bottle cooler that is 10 years old and have to put freon in it about once a year. I know there is a tiny leak somewhere but can't find it. Should I try and call someone to fix it or replace the entire refrigerator?
    Director Badge:
    Uploaded 100 video answers.
  • Beverage-Air Master
  • 488 Answers
Posted on Oct 10, 2015
SolutionGuy
  • 331 Answers
SOURCE: bev air cooler
Bill, the main reason I've noticed for higher than normal temps in these boxes is filthy condenser coils (this will affect pressures in your sealed system). Remove the front lower panel and inspect your coils. Use a coil brush or a dust broom to thoroughly clean them up, don't use water. You can also pick up some condenser coil cleaner in a spray can from your local appliance parts store, but it's not necessary (the fumes are strong and may be objectionable to your customers... it gets 'em really clean, though!) After cleaning the coils, allow 24 hours for temps to stabilize. If they don't, here is a site for Beverage-Air, contact your local servicer with you exact model and serial number for pressure specifications. http://www.beverage-air.com/technical.service.html Hope this helps! Let us know, will ya?
Posted on Aug 13, 2007
SOURCE: Under counter beverage cooler
It might be ice around the fan. Try defrosting it. This has been happening to mine, even through it is supposed to be 'frost free'
Posted on Feb 22, 2008
  • 172 Answers
SOURCE: Danby Silhouette Wine cooler won't
Hi sooner84,
I really like the Danby wine coolers, they are usually nice products. As far as your problem, I would first try to find out where the main problem area is. To do that first make sure that your compressor is running. If the compressor is running and it is not cooling then you may have a freon charge issue. Thats not to say that you can just put some more freon in and it is fixed, You would have a leak in your sealed system and you would most likely still have warranty coverage for that. Most Danby products carry a 5 year sealed system warranty. That would include your compressor.
If the compressor is not running then you would know that you have a compressor issue. Either the relay overload on the compressor would need to be replaced or the compressor itself was bad. You can buy relay kits for about $30.00 and intall them easily with very little experiance.
Next if the compressor is doing its thing and trying to cool you could have a fan not blowing air properly. either a condenser or evaporator fan may have stopped. If you find one not working then chances are you just need a fan. If the fans are blowing and the compressor is working then you would just have a defrost problem. In that case you would just need to defrost then check for bad parts, either a defrost heater, defrost thermostat or a defrost timer. Most of the Danby products have a defrost control board, that board willl contorl the defrost, the temperature, and the fans. If the board was cheap I would say just put one on and see if it fixed the problem, but they are around $145.00.
The most important thing for you would be to make sure you are not going to do something that would void your warranty. Free service is always the best. Good luck to you and send some wine my way, I make lots of different types. from grapes, strawberrys, muskedyne, etc.... mca0824@aol.com
Posted on May 02, 2008
SOURCE: Sub-Zero 511 Freon Leak
Paul, we have the same problem with a built-in Kitchenaid and the price of replacing the fridge is out of sight for us. Where did you get the equipment to check the freon and replace it?
Posted on Jul 22, 2008
SOURCE: Whirlpool Beverage Center (WBC127BLS) - Won't cool enough
i got it fixed. you have to know a little about wiring to make this happen, but not impossible. took cold control off old refrigerator, and wired it into compressor behind refrigerator. the cold control is no more than a thermostat that acts as an on/off switch, so the hot wire needs to be removed off the compressor and the hot lead on the cold control needs to be wired to constant voltage and the other wire on the cold control plugged into compressor where original hot wire was disconnected. you will have to drill a little hole through refrigerator somewhere to run thermostat wire off cold control into refrigerator. you now control the internal temp by the external cold control switch. if you hook it up this way you will only be bypassing the original cold control on the whirlpool, but will still have your digital readout of internal temp. mine now reads 32 deg. and if the beer is in the back of refrigerator it will have ice in it, just the way i like it.
Posted on Mar 02, 2009
Adding freon to a commercial beverage air mm14ge cooler
If it needs gas it has a leak. These coolers generally don't come with gauge access ports and need to be silver brazed into place. These systems have a critical charge and will not operate right unless the exact ounces of refrigerant are in the system. The temperature controls measure coil temperature instead of cabinet temperature. The wrong charge makes them run and run and they cant control temperature. Hope this helped.
May 25, 2014 | Beverage-Air Refrigerators
Need beverage cooler to be colder
it probably has a leak & needs freon. in most cases there are no ports to check the freon level. you will have to add them. if you dont know how to do this it will be cheaper for you to go buy a new one vs. paying somone to fix it.
Oct 15, 2013 | Haier HC125FVS Wine Cooler Beverage Cooler
MT27- 3-4 years old ordered from the manufacture. I'm on my third recharge of the air compressor. Second Repair guy says I need a new compressor. Are there any recalls or can i have the Bev-air replace...
not sure why you would need a new compressor unless it actually has a freon leak on one of the seams during the building process. This is extremely rare. I've only seen one in over 25 years. Some manufacturers have 5 year warrenty on the compressor but do not cover the labor and freon and such to replace the compressor. Either one of the repair guys should have checked into this for you as part of their service. Try contacting Beverage Air and give them your model and serial numbers to see if you still have a warranty on your unit. It's worth a shot.
Now, in order for you to need freon added, it has to have a leak somewhere in the system. It is a sealed system and should never need freon added unless it either has a leak or someone put the improper amount in the system. I would try to find a repair man that has been recommended to you and has good ratings. Check better business outfits or the net.
Let me know if there is anything else I can do for you.
Jan 22, 2011 | Beverage-Air MT27 Beverage Cooler...
My Bev Air UR30G runs, but only warm air comes out...how can I fix?
make sure the compressor is running if not check the thermostat. or could have leak and lost coolant
Sep 27, 2010 | Carrier Beverage-Air UR30GEFD Beverage...
Unit powers up, lights work, motor is running but it is not getting cold. The unit was given to me. It is only 1 year old and it worked when I put it on the truck.
Beverage-Air are very good about helping the customer. Just be sure you don't leave out your serial number. The seem to get lost without that. Thanks, Sea Breeze
Nov 25, 2009 | Beverage-Air MT45 Beverage Cooler...
Beverage air dd58 kegerator won't stay cold
The unit is probably low on gas again. If it lasts a month the leak may be difficult to find, as it may be a small leak. Those units don't hold a lot of gas. Have someone do a nitrogen leak check and fix the leak. If no leak is found, have them install a UV dye to help find the leak. :)
Jan 12, 2009 | Beverage-Air DD58 Beverage Cooler
Clogged drain in a beverage aire mod# dw49
I like to use compressed air, sometimes a wire may work to clear the drain line. It will require some dissassembly of the unit to gain good access to the drain. Clean everything once dissassembled, it will save you trouble later. Hope this helps.
Dec 24, 2008 | Beverage-Air Beverage Air DW49-S...
Looking for age on Beverage Air Horizontal Bottle Cooler
Call Beverage-Air and provide both model and serial # to the parts department and they should be able to identify the year the unit was manufactured - 800-845-9800
Matt - coolergaskets.com
Dec 09, 2008 | Beverage-Air Beverage Air DW49-S...
Freon
With an A/C system that is functioning properly with no leaks you should never have to replace or recharge the freon in your system. If your A/C isn't as cold as it once was you need to get to the root of the problem which could be one of three things, a leak some where in the system, a fouling compressor, or the freon control orfice. Don't waste your money by continually putting freon in, if its just going to leak out in a month or two. Do your homework and find out where the real problem is, once fixed properly you should be worry free for years to come.
Aug 11, 2008 | 2005 Toyota Corolla
Refrigerators Logo
205 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
