Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
I took my bike apart to paint now it wont turnover not sure that the battery cabel is hooked up right where does the ground go to frame and motoror on starter? its a 1984 sporster
  • 116 Answers
Solid mounted motor should ground to motor or frame did you maybe for get the smaller wire to positive term it goes to the main fuse you didnt say whether you had lights or not but theres too many possibilities if you got a book i'm geussing no but they'll have the complete wireing diagrams my advice get a mechanic down there it'll be reasonable cause if he knows his stuff it'll be pretty quick and do keep in mind paintjobs have bred lots of basket cases
Posted on Feb 15, 2010
Motorcycle will not start
My first question is did the bike work OK before it was stripped and painted?
It is possible paint has got onto the main earthing (ground) point on the chassis/frame. I would first check that there is a good earth connection from battery to frame and all light units. Other than the turn signals coming on do any other lights show when you turn the ignition on? If no I would try checking the battery. Remove the battery from the bike AND THIS IS MOST IMPORTANT remove the negative lead first then the positive.
Check the battery has voltage approx 12.5 to 13.2 volts is OK, next connect a 21 watt bulb to the terminals and see if the light dims over 1 minute. If OK get a dedicated motorcycle battery charger (a charger for a car is no good) with an output of less than 1 amp. Charge the battery for a few hours. Refit battery into your bike AND THIS IS MOST IMPORTANT TOO re-connect the positive lead first then the negative.
WARNING never try to jump start your bike from a car/van etc. The more powerful batteries in these vehicles will fry your bikes electrics.
ALWAYS use a dedicated motorcycle battery charger.
ALWAYS remove and refit your battery as stated above.
Good luck and hope this helps.
Apr 08, 2014 | 2006 Harley Davidson FLTRI Road Glide
Powerwheels wont move
even these have a fuse on them.. usually close to the battery..check it to see if it fell out or is blown..check all the connectors also some get dirty and wont connect..
Mar 15, 2014 | Toys
HOW TO GET MY BIKE STARTED
First thing to check is that you have cleaned fresh paint off any ground connections for the electrical system. All grounds must have a good clean metal to metal contact. It's usually either the battery earth, or the engine to frame.
Dec 17, 2013 | 2008 Honda CBR 600 RR
Wont start bike
Some thing to do with your wiring
Oct 07, 2013 | 2004 kawasaki VN 1600 Mean Streak
Bike wont start
check all wiring connections and connectors. check/replace all fuses! remove gas tank... trace all wires...look at all connections that were disconnected for the paint job! (LOOKS GREAT) .make sure the larger ground wire is connected to the battery and connected to the bike frame. (disconnect the positive terminal at the battery.)...use a multimeter to check the battey (-) ground to the frame.. -( 0 ohms resistance). next... reconnect the positive wires to the + battery terminal. . The ignition switch and/or the handlebar on/off switch are probably the source....... if none of the above solves your problem. AFTER EVERYTHING ABOVE Using the multimeter set to read 12+ volts trace the + wires After ALL this...make another post with this info!
Jun 11, 2013 | Motorcycles
Does the coil have to grounded to the engine block or just the engine bolted to frame ok for 47 cc pocket bike
coil needs to be grounded and make sure theres no paint at mounting points of motor to frame
Feb 22, 2011 | RTO 47cc / 49cc Pocket Dirt Bike Atv...
JL 500/1 loses power after 15 seconds
I would check either the remote wire or the ground. Better yet check both
Apr 02, 2009 | Jl Audio 500/1 Car Audio Amplifier
Ground wire
make sure that the wire is grounded to your frame, or any other unpainted metal surface. if no unpainted surface is available, get some sandpaper, and 2 gold, copper, or silver washers (in order from best connection to worst) from your local hardware store. find a bolt near the amp, that wont make something fall apart. take the bolt out, and sand the paint off underneath it. make sure to get all the paint and primer off. put the 2 washers on the bolt, and put the ground wire between the washers. then tighten the bolt nice and tight. this will give you the best possible ground connection, without running the ground to the neg of the battery. if this still doesnt work, try running the ground to the neg of the battery. if that doesnt work, then you should have your amp looked at. hope this helps
Oct 23, 2008 | Kicker 05C104 Car Subwoofer
No sound
if tghelight is green the power is there...but themost common problem s power return..meaning that you might have a bad ground. i wouldsuggest inspecting your ground cable..it should be 6awg minimum and make sure that its grounded to either the frame or negative battery terminal. nothing painted and nothing that doesnt eventually connect to the frame.
Sep 03, 2007 | Jl Audio 500/1 Car Audio Amplifier
Lands Phones Logo
69 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
