Malber WD800 not draining the water
Hi, I have a Malber WD800 and it is not draining the water. I suspect the pump has given up and will need to be replaced. Apart from the draining, the machine works great; it washes, it spins, it dryes.
Before I get a pump, do you experts have any suggestions if there could be any another problem? Just thinking about altenative issues ...
Is it hard or difficult to replace the pump? I have to do it myself, can't afford an expensive service tech ...
Thank you for your time!
  • 641 Answers
SOURCE: Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
Posted on Aug 31, 2007
Oceti
  • 51 Answers
SOURCE: Kenmore Washing Machine won't agitate, spin, or drain
The problem sounds like the motor to transmission coupler. If it is not draining or spinning you may find that the lid switch is inop.
Posted on Dec 07, 2007
  • 55 Answers
SOURCE: Malber WD800 - Will not fill
The thing making noise is probably the inlet valve, not the pump. The pump pumps the used water out the drain hose. Anyway, if the noise happens when water is trying to come in, the inlet valve is probably faulty. Onw way to get around this without repair is this: If you are hooking up to the sink, that means you are using only one hose to the machine. The other inlet to machine is probably capped off. Remove the cap, and the hose to the respective inlets, and reverse. You will probably have to change your water temp selectors on the front of the machine. If this makes it run OK, then you can later buy an inlet valve and replace at your leisure. For parts call 718-767-7396 in NY. I hope they will ship to where you are. Good luck and let me know what happens.
Posted on Mar 21, 2008
  • 55 Answers
SOURCE: MALBER WD 800 WASHING MACHINE USER MANUAL
Sorry, I don't know what your question/problem is. If you need a manual, I have one for WD 1000, but not for WD 800.
Posted on May 06, 2008
  • 36 Answers
SOURCE: does not pump water out or spin after first wash
Dear Customer
Please perform the following
The first thing to check is the lid switch. Open the lid and you'll see a recessed spot that a tab on the lid fits into. Put a screwdriver into the spot, press down and see if you hear a click. If you don't, the switch is bad. That's if you're lucky.
It could also be something as serious as the transmission. Try this: In the search box at the top of the page, type in repair (brand, like ur Whirlpool or anyother etc) washer. A list of sites will come up with a bunch of troubleshooting tips and repair instructions. I used this to fix my washer a couple of weeks ago. Good luck.
Please rate this,Thank u
Posted on Dec 17, 2008
Malber WD1000 wont condense the water that is fed through during the drying cycle
Since it drains properly during the wash cycle, we know the drain pump and its impeller (propeller) work, and the coin trap (you called it a filter) and hoses are not clogged. By the way, turning the rightmost knob to "4" will start the pump-out cycle, so you don't have to open that trap-door at the bottom. To condense, the machine needs COLD water (spritzing on an internal screen) during drying. Make sure your cold water hose is connected to the outside (outboard) connection on the back of the machine. As a long shot: If the gray drain hose is pushed too far down into your home's drain pipe (more than 8") there could be a "back-siphon" where dirty water siphons back into the washer. It's a long shot, but it does happen.
Lastly, the controller board (mounted at top of right side) could be bad, and not sending on-off commands to the pump during drying. During drying, the drain pump should cycle on and off constantly, every few minutes. Do you hear it running? If you remove back (about 12 Torx screws), at your lower left you will see the pump. There are only 2 wires (120 VAC) and they can be connected either way. Stick a meter on the terminals and see if power is cycling on and off. If not, the controller board is bad.
You can order one from Malber (in NYC) by calling Nancy at 516-323-5299. Tell her Mike, in Wash. D.C., says hi.
Mar 06, 2015 | Malber WD1000 Front Load Washer/Dryer
How do you get the water to drain in the Malber WD100 washer/dryer combo?
Hi. I''m assuming you are referring to a WD1000.
To initiate the drain cycle: Rotate far right knob CLOCKWISE to Position 4. It may take 30-45 seconds to recognize the knob's new position, but then it will begin an 11 minute Slow Tumble/Pump Out cycle. During this cycle you'll see the internal drum slowly rotate CW for 60 seconds, pause, then rotate CCW for 5 secs - then repeat. All this time the pump will run and you'll hear water running down the drain. When you hear no more water you can rotate same knob to "straight up", and stop the machine. To turn power off, press the rightmost button.
Sep 21, 2014 | Malber WD1000 Front Load Washer/Dryer
Malber wd800
if there is no blockage in the screens at the hose connection then u may need a new water inlet valve
Apr 06, 2014 | Washing Machines
Malber wd800
Water-Melon. Ok? W-A-T-E-R-M-E-L-O-N :D
Sep 09, 2013 | Dryers
I have the Malber WD1000,the wash cycle goes on but no water pumps out, a couple drops come out . How do i fix it?
No water fill
1.water valves closed----turn on valves
2. Hoses kinked---unkink hoses
3. Screen in fill hose clogged----clean out screen
4. No power to fill solenoid---replace solenoid
5. Faulty water level control---replace control
6. Machine did not turn on----check control & power outlet
Water will not drain from machine
1.kinked or clogged hose----clean drain hose
2.pump does not run----readjust & tighten pump-drive mechanism
3.suds lock----remove suds,, add cold water
4.faulty transfer valve---replace
5.defective timer----replace
6.loose belt---adjust belt
Sep 22, 2011 | Malber WD1000 Front Load Washer/Dryer
Hello,I would like to know how to use my malber wd800 washer/dryer. I turn the dial on the right side to the top red and pull it out, but by the time it stops (after the red before the blue) my towels are...
Just in case please try the following- it could be that there is water still left inside the washer which is why the towels do not dry.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 09, 2011 | Malber WD1000 Front Load Washer/Dryer
Our Malber trips our circuit breaker every time we turn it on. Do you know what could be causing this? Thanks.
Sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer ;-0(
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid as primary suspects. Secondary suspects could be main motor, drain motor.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
John C
Aug 13, 2011 | Malber P21 Front Load Washer
May 02, 2008 | Washing Machines
my malber sounds like a jet plane lifting off at various points during the cycle, when it's spinning, I am pretty sure.  Any ideas?
Mar 21, 2008 | Washing Machines
Leaking from the front top of machine immediately when cycle begins...
Not sure if this is the same problem but my old WD800 used to spew water out of the top left corner where the detergent tray is. This occurred at one point in the cycle. It was cured by turning down the incoming water pressure on the external tap under the kitchen sink (in this particular case, the cold water)
Jan 28, 2007 | Malber WD1000 Front Load Washer/Dryer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
