Question about Western Digital 320GB MyBook External USB 2.0 Hard Drive
External hard drive is not detected
Hai,
my hard disk is not detected by my pc of if it is connected to pc its hanging and shuting down.if it is connected initially it is not moveing to further step atleast to bias. what to do.
it is maxtor 1 tb hard disk
My Book Essentail Edition does seem to be working fine. the problem is I do not have access to the storage space in "my computer" or anywhere else as far as I can tell.
Posted on Jan 31, 2010
Kya hard drive ki storej disk ko kisi other hard disk me laga ke use kar saktey hai ki nhi
internal hard drives are now SATA connected ( you can get converted cables to connect older units) or external hard drives are usb connected
dless of the make you have , all hard drives will fit
Dec 30, 2016 | Hitachi Computers & Internet
If i connect my external hard drive. the windows can't detect and it will say "USB Not Recognize" and my desktop will hanging.
Good day..you can try replacing the usb cable or but still not working your hard disk was defective..thanks
Aug 16, 2011 | Toshiba Computers & Internet
My pc and laptop not detect my Maxtor OneTouch III Mini External 100GB USB 2.0 Hard Drive R01E100 what can i do please help me soon as possible
Good Day Anantsharma8!
If your PC and Laptop can not detect your external hard drive, I do suggest you check its usb cable. A substitute cable will confirm if your current usb cable is faulty or has an open wire.
Most common reason why the external hard drive is not recognize by PC or Laptop is due to loose connection of the hard disk inside the connectors of the enclosure.
Anantsharma8, if you have a small precision screw, I recommend you open the enclosure of the external hard drive. Remove the front face where usb and power plug connects, then slide it out to expose the hard disk also. You will see two connectors. These are the ones that always loosen. Please disconnect both the connectors and then connect it again properly. Put the hard disk back, close the enclosure and try to connect again with your PC or laptop via usb cable.
Good Luck! I hope that it will soon recognize your external hard drive.
Jun 10, 2011 | Maxtor OneTouch III Mini Edition R01E100...
I have an IMAC and our Maxtor 500G external hard drive is not being detected when we connect. It was previously connected to a windows PC, how do we connect this to the mac to access files. Currently when...
Connect it to a PC. If it still does not work, then it's time to disassemble the enclosure, remove the disk-drive, purchase a compatible replacement disk-drive, install it, to "reconstitute" your external storage device.
Take the model-number and serial-number from the old disk-drive, and check Maxtor's web-site, to see if the warranty is still valid.
If so, then Maxtor will replace the disk-drive, at no cost to you.
Oct 30, 2010 | Apple Computers & Internet
Check Following Instructions:
1. Check your USB cable properly connected to the computer.
2. Go to My computer - right click on property - Hardware - Devices Manager - in below - USB Mass storage device - right click on this - and Uninstall - then again right click - click on Scan - it should be reload your USB drivers
your External Hard Drive will be detected
Apr 25, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
WD external Hard drive 320 GB hangs my computer everytime connect
Try the external hard-drive in some other computer.
If it still causes problems, then it is the external hard-drive, not your laptop, that has the problem.
If the warranty on the external hard-drive is still valid,
exercise the warranty to get a replacement.
If the warranty has expired, you could try to "disassemble" the casing, to remove the "internal" hard-drive that is "inside" the casing.
Then, connect that hard-drive to a desktop computer,
and copy your data to the 'C:' drive (or burn your data to CD/DVD disks), if you can -- it's possible that the "electronics" that convert the USB-interface to the hard-drive interface is the problem, and that your data on the hard-drive is perfectly OK.
Nov 16, 2009 | Western Digital Elements powered by WD 320...
Acer aspire one hard disk cannot read
Check the BIOS configuration for the hard disk, if the BIOS does not detect the hard drive then the hard drive is faulty or the disk controller is faulty.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. This computer should detect the hard drive as an external disk drive. If this computer cannot detect it and/or cannot open the folders etc. the the hard drive is faulty.
Then you need to install a new hard drive in the Acer and install Windows, the device drivers and your programs to get the laptop operational again.
Aug 19, 2009 | Acer Aspire One D150-1587 Netbook
System not detecting my external hard disk
try going onto computer and see if it has removable disk right click and open or try putting usb in another port or if a disk came with it put that in .
Dec 28, 2008 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Some strange ticking sound coming from my external hard disk and is not detected by my pc
that is a failure mode of that hard drive..try shutting down the power and disconnecting the connection cable..then reverse that..you may need to have it serviced. Do you have a backup for that drive?
Nov 21, 2008 | Western Digital 320GB MyBook External USB...
System not detecting hard disk
is that a sata drive or ata?...if ata, try to change the IDE Cable that connected to your Hard drive?..
Feb 26, 2008 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Western Digital 320GB MyBook External USB 2.0 Hard Drive Logo
218 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
