SOURCE: Samsung home cinema system HT-THX25 Multiregion hacks
Turn on the HT with no DVD. Press the following buttons on the remote: ENTER 8, 4, 2, 6, 9 ENTER
It will turn off. When turned again on it is a region free HT.
SOURCE: Hello I have a Samsung HT-HTX22 home cinema.
ik heb een vestel tv ,en krijg geen geluid via mn 5.1 ht-thx22 speakers omdat hy niet voorkomt op de lijst van het manual dus mijn vraag is ondersteunt hij ook vestel tv ,s of moet ik een samsung tv kopen m.v.g. D.Suverein
SOURCE: Samsung HT-Z310 tries to load disc, but never does
I've had a similar problem where the disc continues spinning in the "loading" mode and then finally goes to "disc error." So, I opened the cover of the player, and noticed that the disc was not spinning as fast as I expected, and there was an extra unpleasant sound when the disc was spinning. Thus, I suspected there was an issue in the drive motor system: either the motor drive board, the motor itself, or the contact to the disc. I saw that there was dust accumulated on the rubber contacts to the disc, so I cleaned them with a q-tip. I then resetted the system, and the disc was the spinning normally again, and everything worked like before! (Other things I have tried in the past were cleaning the lens and updating the firmware, none of which worked) I hope this helps!
SOURCE: my samsung home cinema ht-tz212 wont play discs,
Try resetting the system turn power off then press and hold stop button on Main unit for at least 5 seconds this is main system reset it may well do the trick for you
