Barbie idesign ultimate stylist cards will not scan in
I can not get the cards to scan in on the barbie idesign. the led light blinks just 3 times and nothing happens. what do i need to do
  • 22 more comments
  • Anonymous Mar 09, 2008
    cards won't scan either
  • Anonymous Mar 11, 2008
    I've got the same problem. This is the second one we've bought...
  • Anonymous Mar 15, 2008
    We have the Barbie idesign, and can not get the cards to scan, I keep getting USB device not recognized,what shoudl we do??
  • Anonymous Mar 18, 2008
    Same exact problem here, any ideas?
  • Anonymous Mar 28, 2008
    I cannot get my cards to scan also. Is there a resolution to this?
  • monzac98 Apr 06, 2008
    We have the same problem and our USB port did recognize and install. Any solutions?
  • ammc1 Apr 07, 2008
    I have Windows Me and it seems as though the barbie i design installed properly. I can't get the cards to scan. Do you have any suggestions?
  • Anonymous May 15, 2008
    INITIAL SCAN WENT FINE (ABOUT 3 WEEKS AGO). NEW CARDS PACKS ARE NOT SCANNING ALTHOUGH IT LIGHTS UP - IT DOES NOT REGISTER ON SCREEN. WE HAVE SCANNED MULTIPLE TIMES AND IT LIGHTS UP WE WAIT AND NOTHING NEW APPEARS
  • Anonymous Oct 07, 2008
    El lector de tarjetas NO trabaja... (The card reader doesn´t work)
  • eye_o_green Nov 16, 2008
    I am having the same problem. I scan the card, the light blinks 4 times but nothing appears on the screen. I have even uninstalled the program and re-installed it.
  • Anonymous Dec 08, 2008
    Cards won't scan at all.
    I work work witk a HP Pavillion dual cor proc and 4 ghz memory.
    I won't work on my with XP either.
  • kwaka_queen Dec 25, 2008
    game loads ok but cards do not scan. scanner blinks 4 times, yet nothing appears on screen. scanner does not appear as hardware on system, but sound effect is heard when connecting to say it has recognised new hardware being added? have tried scanning cards in every way possible, have reinstalled program, still nothing works
  • pau_af87s Dec 25, 2008
    I instaled the game but a with a clik in the icone but the program don`t opened!!!!
    help please!!!
  • ggsggm96 Dec 25, 2008
    My cards will not scan.
  • parrothead92 Dec 25, 2008
    Cards won't scan
  • Anonymous Dec 25, 2008
    ya everything works. I installed it and it came up i went to the design place and tried scanning in the cards it blinks 4 times yet nothing appears i even waited a few minutes! this game looked cool but its not working as i planned :(
  • kiwilizzie Dec 26, 2008
    I have loaded the cd on the computer works fine but can not load the fashions. Is this a design fault.
    What to do please can someone help.
    Regards,
    Kiwilizzie
  • amauryt Dec 27, 2008
    The program won't run at all. Installed with no error messages at all. I'm using a laptop, administrator privileges, XP home. Could it be the graphics card?, and if so, how do I know the type of 'graphics card' the laptop has?     HELP  PLS or my daughter WILL KILL SANTA!!!!!  (those were her words, not mine .....)
  • tecjvw Dec 28, 2008
    Same problem, installed program, windows xp, works. Cannot scan cards, light blinks, but fashions do not show up on screen. Tried several times. Uninstalled and reinstalled software, same problem. Mattel should know this is a common problem.
  • Anonymous Dec 30, 2008
    no problem loading software...scanner blinks as it should... but no scanned images appear on screen??? All the while, Barbie is peppily encouraging me to scan before I can go to the runaway. I will kill Barbie.
  • Anonymous Jan 01, 2009
    So what do you do when this happens?
  • Naosan Jan 06, 2009
    I downloaded the program but when I click nothing happened. I tried in different pcs and finally I could install it but the cards didn't scant. I was disappointed, and my daughter couldn't play. The best thing was to go to the Store and change the game for something different.SORRY...!!
  • Anonymous Jan 12, 2009
    I have the the same problem and emailed Mattel who said they would get back to me. That was almost a week ago. I think the problem lies with the USB device as it does not display as a removable disk on my pc as the guy at Mattel explained it should.
  • Anonymous Mar 22, 2009
    the game won't show the icon
Not sure if this will help as my cards would scan but I was having problems with the game shutting down when we tried to "photograph" her outfits, fashions not transfering to other sections of the game and not saving the cards we had scanned. I'm running windows xp on a new computer and had to change my daughters user account to administrator (from limited). The game is now working brilliantly and is everything it promised to be. Still it's very frustration that I had to spend 3 hours today solving this myself instead of reading a simple 1 liner on the Mattel website FAQ's!!!
Posted on Dec 26, 2008
I had the same problem...software loaded fine, scanner light beeped 4 times as it should when running a card thru, but nothing scanned in. Finally, I plugged the scanner into the USB, restarted our laptop (running Vista Home Basic) with the scanner still plugged in. It worked right away after that. So, I suggest turning your computer off, plugging in the USB scanner, and starting your computer back up. I hope this helps!! :)
Posted on Dec 30, 2008
When testing the i-design product for a customer on our work computers I had the same problem. The program loaded fine but when I scanned the cards nothing appeared on the screen even though the LED flashed 4times. However, when I tested the product on a rather new laptop at home it worked fine. I made sure i plugged the scanner in before i turned on the laptop and also checked that I had all the required programs listed on the internet. I think the most important requirements to have is the appropriate program for the scanner and also more than enough space. If you have any more problems the mattel customer number is 1300 135 312 or you can contact me (Alexis) at Mandurah Toyworld.
http://www.freewebs.com/barbie-idesign-manual/index.htm
Posted on Feb 13, 2009
I had the same problem but then i got a new computer and it worked fine. When i downloaded it and put in the CD ROM i clicked the icon and nothing came up! The thing is when you install it, as soon as you put the disc in it should load but if it doesn't you need some more programs on your computer or more memory space. If you look it up in the manual it will tell you what programs you need to install it. If you don't have the programs just search the internet to download them. The link bellow is to a manual and the programs you need to run Barbie i design are highlighted:
Posted on Jul 01, 2008
Where can i get the CD for Barbie idesign please?
http://www.ebay.ca/itm/Mattel-Barbie-Idesign-Interactive-Design-Studio-Ultimate-Stylist-/181443932482
Very hard to get CD Rom as discontinued by mattel in 2009
found a few web sites proclaiming to have a download but require the dwonloading of a smart downloader which I cannot guarantee would be virus free and safe and would result in getting the software .
the software is called Barbie(R) idesign(TM) Ultimate Stylist(TM)
you may google it and have better luck at finding a downloadable version than I had or are willing to risk installing a downloader program which I was not willing to try or risk.
Jan 20, 2015 | Toys
Will Barbie idesign work on vista 64 bit?
I THINK THAT WORK ONLY FOR WINDOWS VISTA 32
Jan 02, 2009 | Computers & Internet
Parts for the barbie cash register
http://kiddirect.com/contact_us.asp
I just called the number in the link above looking for the credit card for the Shop With Me Barbie Cash Register and they indicated to me that they have the price sheets available for that particular toy. I don't know if you have that particular cash register or a different one, but that set sells for $7.00.
Dec 14, 2008 | Kid Designs Barbie Shopping Time Cash...
Barbie iDesign Ultimate Stylist Game not working
Try updating your graphics drivers from the internet for your video card. Since the minimum requirements for this game is a 32 MB video card, your video card should work just fine. Attempt to update the graphics drivers from ATI's website. Also verify that you have direct x compatable sound card, which is also required for this game.
Dec 09, 2008 | Video Game Consoles & Games
Nikon Coolscan 9000 ED can not be recognized by computer
I am having the exact same problem...cannot get the Coolscan 9000 to show up in Device Manager. One thing I did try (to no avail) was to run the regsweeper.exe file that comes with the Nikon scan disk. It clears your registry when you reinstall. It still did not work though so I have a lovely "shoebox" sitting next to my computer that is worthless!
Dec 08, 2008 | Office Equipment & Supplies
Double clicking on the icon and getting an hour glass only was what I encountered this morning. You need to go out and buy a graphic card. I got 128 mb for $50 installed at the store on the spot. I can now load the program. BUT I currently cannot get the fashion cards to register onto the computer. Mattel is sending me a new "swipper".
Jun 16, 2008 | Video Game Consoles & Games
Barbie Idesign computer software
That sounds reasonable. Programs do strange things when they can't display the correct graphics. For example: Portal wouldn't run on my computer because my graphics card was not able to use DirectX 9.0.
Apr 10, 2008 | Computers & Internet
Barbie IDesign Ultimate Stylist Help Needed
The recommended minimum sysytem requirement for the video card is 32MB. When I upgraded my video card to 128MB the problem of the yellow screen is gone and the program works well, problem solved.
Mar 25, 2008 | Video Game Consoles & Games
Computers & Internet Logo
3,265 people viewed this question
Alun Cox
David Payne
David Payne
