Question about Remote Start System
The led light on the vehicle no longer flashes and nothing works onthe remote ie car lock/unlockmsm
  • 344 Answers
The first thing I would do is change the battery in the remote at 12 noon or 12 midnight, this way you don't have to reprogram the time if it has a lcd screen
Posted on Jan 31, 2010
Will not unlock doors. Battery is good and flashes all lights on transmitter and LED inside vehicle. Remote start will start up and shut down vehicle fine. Just does not lock or unlock doors. Locks work...
Have you changed the battery recently? My remote has a bad habot of slightly misaligning the cel switches if I don't close it exactly right. For my Chrysler van the sliding door switch is affected that way. All else works, though. I end up opening the remote again and ensuring it snaps shut all the way around with just one compression. If an edge doesn't close it's try again. The good news is it's virtually always the remote at issue and nothing expensive in the vehicle.
Jun 06, 2017 | 7900 RB 7900 2Way Color LCD Remote Start...
Remote locks and unlock car but it does not start it with remote
Troubleshooting Tips For Your Car Starter
  • If your car is simply not responding when you activate your remote car starter, it is usually due to one of two problems. Either your remote is not working, or your receiver is not functioning properly. Most remotes will have an LED light to indicate that the remote is working. If the LED light is flashing when the remote is engaged, the remote is functional. Check the receiver by ensuring the receiver wire is connected properly.
  • If your car is indicating a response to the remote car starter (i.e. the lights flash or the horn honks briefly) but not starting, you probably have an issue with your hood pin switch or your taillights, or parking lights may be defective. Another possibility is that you have blown fuses in your main power source. If you cannot determine that these are the causes of the malfunction, take your car back to the company or service that performed the installation.
  • If your vehicle is responding to the remote car starter and the engine turns over but will not start, it may be caused by a factory-installed immobilizer system, or OEM. Factory-installed OEMs are activated by a computer chip in your ignition key. In order to test for a problem with you car's OEM, place the key in the ignition and employ the remote car starter. If the car starts, you definitely have a problem with the vehicle's OEM, and you may need to purchase a "transponder" to bypass the OEM.
  • If you lose your remote for your car starter, do not worry. Most remote car starters are equipped with multiple security features to ensure the safety of your vehicle while it is idling. The car simply will not run without the key. And, once you replace the remote and program it into the system, your old remote will no longer function.
Credit goes to:
http://www.carstarters.com/troubleshooting.cfm
Feb 25, 2011 | 2007 Chevrolet Tahoe
My bmw 320d remote wont lock car however does lock the car with the key its a 55 reg
Programming
When
Key batteries completely discharged. Key batteries not replaced within 60 seconds. Key added or replaced. DO NOT press remote control buttons during battery replacement.
How
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button Fig. 1 [1]. Press lock button Fig. 1 [2] briefly 3 times within 10 seconds keeping unlock button [1] depressed. Release unlock button Fig. 1 [1]. Some models: LED Fig. 1 [3] flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Some models: Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously
Later keys with bmw badge on key. Battery can not be replaced
Battery in key charges while driving
Dec 22, 2010 | BMW 3 Series Cars & Trucks
Have had a Dei valet 561r remote on my Honda van for several years. Worked flawlessly. Recently, it began working intermittantly. Did not work for several days. Then worked for about a week. Then nothing....
sounds like your car battery was also replace or it die
believe it or not the remote start needs to be reprogram again
find the valet switch, this what you are going to do
make sure ac radio and any other accesorie are off
start the car with the key within 2 seconds or less press and hold the valet swith, and way until the
led turns on and the parking lights on the vehicle flash about 12 seconds
no turn off the car close the door and start the vehicle with the remote good luck
Nov 19, 2010 | Directed Dei Valet 561r Remote...
My Viper 5701 has been flawless but now on locking/unlocking the car no longer "chirps." Everything else still works perfectly such as the flashing lights. The remote also has changed its noise from the...
Check to make sure that the valet is not engaged. The alarm will notify you by having a constant lit light. If the light flashes like it should open a door and check to see that the light blink on and off as if the alarm were triggered. If this happens the your problem is with the siren, just have it replaced.
Jul 27, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
2002 bmw 530i key does not (remotely) unlock doors or trunk but they work fine manually.
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button. Press lock button briefly 3 times within 10 seconds keeping unlock button depressed. Release unlock button. Some models: LED flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously.
Mar 09, 2010 | 2002 BMW 5 Series
My Porsche Key fob no longer unlocks the doors
Insert key into door barrel or ignition lock and turn key, whilst doing this press the unlock/lock button, the led on the dash should flash to indicate this has initialised the key to the car, then remove key and test operation of remote. If this fails then a new remote plus coding to the car by your dealership is needed
Feb 16, 2010 | 2005 Porsche 911
Astra remote car starter problem
your remote starter is in valet mode, the door lock will still work but no remote start, try pressing the trunk button 3 times, if that doesn't work turn the ignition switch on and off 5 times
Jan 03, 2010 | Astra Car Alarm And Remote Starter,...
Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Jan 20, 2009 | Chamberlain 950CB Remote Control
Remote Start System  Logo
89 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
