Question about Whirlpool Washing Machines
Excessive water build up in front loader. Pump shows 11 min in timer, runs, at 9 min F, H code come up and unit shuts off
  • 10,515 Answers
Try unplugging it for at least 10 min then try the pause/cancel again after plugging it back in.If that would not help, make sure that the hose is not kinked and the screens in the valve are not clogged.
If you see any Door light lit then, Unplug the washer and remove the lower panel of the washer from the front. On the side the door opens you need to reach up behind the panel and locate the door latch assembly, at the bottom there is a tear drop shaped tab that you need to pull down gently but with some pressure pull down on the tab about a 1/4" you will hear a click. Voila the door can now be opened. Leave the door open and plug the machine back in. Try the cancel button again (2x's).
Unless it is Faulty Pressure Switch.Once replaced, it would fix the problem.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 31, 2010
Tip
How to maintain your Front loader washing machine.
To maintain your front loader washing machine in good working order and to avoid having a service call there are a few simple maintenance tasks to carry out.
1. Every time you carry out a wash before you switch on the unit you should check the door seal for any foreign particles like coins or hair clips and remove them. If they stay there they can then get past the seal and clog up the fluff filter and drain pump which stops the unit from draining.
2. It is also a good idea to wipe the door seal occasionally
3. There is a fluff filter on the front of the unit in the bottom left or right hand corner behind the service flap. Have a small tray, like a baking tray underneath it and open the flap with some sort of flat lever,coin or screw driver. Turn the tap about 1/4 of a turn and collect about a litre of water from the unit. When it has stopped draining unscrew the tap all the way out and clean the fluff filter which is the tap in your hand.
Also have a look in the hole and you will see the drain pump at the back. Make sure this is free of any foreign particles and can turn. Then re-screw the tap back making sure it is tight.
This should be done regularly every 2-3 months to avoid the unit from not draining.
4. Running a cottons 95c wash every 2-3 months kills off any bacteria build up, and cleans out any excess detergent build up. It also stops the unit from smelling.
You can also use a special washing machine cleaner or just white vinegar as a cleaning agent in the detergent tray to help.
5. After every wash keep the door open for about 30 mins to let it dry out as shutting the door is then a perfect environment for bacteria to develop and the door seal to go mouldy and also causing the unit to smell.
6. Lastly take care when removing clothes as zips can catch on the rubber door seal and tear it. This will then leak water at the bottom of the door.
Hope this helps.
on Mar 21, 2010 | Washing Machines
My Affinity front loader works fine but shuts down early at last 6 min no spin soaking wet cloths
Hello James Banks - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit. Thanks for allowing me to help you.
Apr 10, 2013 | Frigidaire Affinity ATF7000E Front Load...
Have an affintiy front loader that wont do its final spin. Passes all the diagnostic tests that comes with the machine but when timer goes from 6 min left it just shuts off and gives the end of cycle...
there may be something blocking the drain pump.if you have standing water in the tub use a wet dry shop vac and attach it to the end of the drain hose to remove the water.
once you remove the water check the drain pump for obstruction the main drain boot the comes from the bottom of the tub to the pump make sure everything is clear.
If you do not find anything then there is a chance that the door lock mechanism is faulty
Jun 02, 2010 | Frigidaire ATF6000ES Front Load Washer
Kenmore HE2 front loader. The discharge pump
This error occurs if the touchpad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
Possible Causes / Procedure
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the touchpad/LED assembly and Central Control Unit (CCU).
4. Plug the unit back into the appropriate socket. If you continue to experience abnormal actions with the pump, replace the (CCU)
Oct 02, 2009 | Kenmore Washing Machines
Frigidaire gltf2940es3 dont go into spin
put in door lock /switch fixed problem the switch sets behind the rubber seal a thin wire clamp around the seal with a spring at the bottom frount holds the seal in place realy is no problem to change
Apr 09, 2009 | Frigidaire GLTF2940E Front Load Washer
Machine won't fill with water
Check that the inlet screens on the water supply are not clogged.
Make sure the water is for certain turned on (assuring nothing has changed).
If those are not found to be the problem, then it could be the fill valve(s) or the timer control.
Reply back what you find, and I can help you further.
Jan 29, 2009 | GE Energy Star WCVH6260F Front Load Washer
Frigidaire front loader wont final spin timer stops at 7 min.
its_me_ac You probably have a faulty timer switch.
You can buy parts at this site , v
Please give me a good rating
Dec 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Crosley Front Load Washing Machine
FL is a flood condition fault, too much water in unit. i would turn off water supply and try to spin water out. select spin button, should put 8 min on timer try startin that water should pump out then if not you got somethin stuck in pump (lint likely)
Feb 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
14 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
