Question about Intel DG43NB Motherboard
I dont't get display in my moniter my board is intel dg43nb ram 4 gb, core 2 quad processor fan move green led light but n display
I had the same problem sir. but this time when there is no memory it beeps trice. and i think it means no memory install... but when i install memory no display, no beep. what should i do sir... thanks
Posted on Jul 24, 2010
  • asinine Jul 24, 2010
    i had the same problem sir. but this time when there is no memory it beeps trice. and i think it means no memory install... but when i install memory no display, no beep. i try also disable all the peripherals and other devices only the processor and memory left still no beep, no display. what should be the problem sir... thanks
Check the ram to know if it is actually working or sitting properly.......check the VGA port...........try another monitor on your board........lastly try the monitor on another board and if it works you board is bad
Posted on Feb 01, 2010
CPU fan & PSU fan working but No display coming to the screen
There should be some sort of beeps then. No beeps is an indication the CPU or RAM is not seated properly. You need to refer to board manual if there are beeps.
There is also the matter of... Never mind I just noticed the CPU is an 8 core CPU, but the board supports quad core.
Board specs
http://www.gigabyte.com/products/product-page.aspx?pid=3833#sp
CPU Specs
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103960
Double check my findings and go from there. Good Luck
Dec 11, 2012 | Gigabyte Technology gigabyte Ga-78lmt-USB3...
My DG41TX works perfectly with dual core processors, but with core 2 duo not, do 3 beeps and dont show any video, what i must do?? my core 2 duo is E8400 my dual core is E2180 Bios Version:...
The POST beep code - 3 short beeps mean RAM failure.
Try reseating the RAM modules.
If this does not solve your problem then remove all the RAM modules and insert one RAM module at a time into memory slot 0 (1st memory slot) to determine which is the faulty RAM module.
Jul 07, 2011 | Intel DG41TX Motherboard
Mother board
Description: The Asus P5GC-MX is an Intel 945GC Express-based, compact motherboard.Compared to other compact motherboards on the market, it is inexpensive at around $55.This motherboard supports Celeron, Pentium 4, Pentium D, Pentium Dual Core, and Core 2 processors that use the LGA775 interface.This product can support up to 2GB of memory.
Pros: None noted, given available product data.
Cons: None noted, given available product data.
Suitability: A compact motherboard, suited for small computers.
Value: In view of its inexpensive price, this motherboard has great features for the money.
Suggestions: (1) Be sure that you are using a LGA775-compatible processor with this motherboard.(2) If you want to take full advantage of the on-board SATA controller, you will want to consider a hard drive upgrade.Existing IDE hard drives will run on the ATA-133 bus.(3)
XFXg31
General
  • Product type (AE) Motherboard
  • Form factor Micro ATX
  • Width 9.6 in
  • Depth 7.6 in
  • Compatible Processors Pentium Dual Core , Pentium Extreme Edition , Pentium 4 , Celeron , Pentium D , Core 2 Quad , Core 2 Duo , Core 2 Extreme
  • 64-bit Processor Compatibility Yes
  • Mainboard processor socket LGA775 Socket
  • Mainboard / Multi-Core Support Dual-Core / Quad-core
  • Chipset Type Intel G31 Express
  • Data bus speed 1333.0 MHz
  • Storage key information Serial ATA-300 , eSATA port
  • Power connectors 24-pin main power connector , 4-pin ATX12V connector
  • Processor
  • Installed Qty (Max Supported) 0.0 ( 1.0 )
  • Memory
  • Cache Memory Type None
  • Supported RAM Technology DDR2 SDRAM
  • RAM Installed ( Max ) 0.0 MB / 4.0 GB (max)
  • Supported RAM Speed PC2-6400
  • Video
  • Graphics Controller Intel GMA 3100
  • Video Memory Dynamic Video Memory Technology 4.0
  • Audio
  • Audio Output Sound card
  • Sound Output Mode 5.1 channel surround
  • Audio output compliant standards High Definition Audio
  • Telecom / Networking
  • Modem None
  • Networking Network adapter - Ethernet , - Fast Ethernet
  • Features
  • Hardware Features Intel Fast Memory Access Technology
  • Expansion / Connectivity
  • Expansion Slots Total (Free) 2.0 PCI Express x16 - DIMM 240-pin , 1.0 PCI - LGA775 Socket , 2.0 Processor , 1.0 Memory
  • Storage Interfaces Serial ATA-300 - connector(s): 1 x 7pin external SATA - 1.0 device(s) , Serial ATA-300 - connector(s): 4 x 7pin Serial ATA - 4.0 device(s)
  • Interfaces 4.0 x Audio - Input - 6 pin mini-DIN (PS/2 style) , 1.0 x Network - VGA - 4 pin USB Type A , 1.0 x Mouse - Ethernet 10Base-T/100Base-TX - Mini-phone 3.5 mm , 1.0 x Display / video - Line-in - 15 pin HD D-Sub (HD-15) , 1.0 x Hi-Speed USB - Line-out - Mini-phone stereo 3.5 mm , Microphone - Generic - Mini-phone stereo 3.5 mm , Audio - Generic - RJ-45 , Keyboard - 6 pin mini-DIN (PS/2 style)
  • Additional connectors (optional) 4 x Hi-Speed USB
  • Miscellaneous
  • Included Accessories I/O back plate
  • Cables Included 2.0 x Serial ATA cable , 4.0 x Serial ATA power adapter
  • Software Included Drivers & utilities
  • Windows Vista Readiness Certified for Windows Vista
  • The Intel board is a discontinued product but is a better board than asus
    Sep 01, 2009 | Computers & Internet
    Fails to go to "Setup", does not show on Screen.
    1.make sure your monitor is plugged on the video card.
    2.check *********** board manual for videocard slots.
    3.check your videocard if they nid extra power from four(4) pin
    female power cable or six pin female power cable.
    4.try using another monitor.. or TV XD
    May 09, 2008 | ASUS P5N-E SLI Motherboard
    Processor upgrade for my Asus P4V8X-MX motherboard
    ya it has ddr u could beef ram up aint much chip u can get higher in this mobo need new mobo to run quad cores amd ect is am2+ mobo better cheaper ram too get more up to 8 gb 16 sum mobos on new egg
    Feb 04, 2008 | ASUS P4V8X-MX Motherboard
    PC not booting up
    Not 100% sure this MB takes the quad core processor.. Have you tried it with another skt775 one?
    Oct 26, 2007 | Foxconn 975X7AB-8EKRS2H Motherboard
    Intel DG43NB  Motherboard Logo
    181 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    David
    David
    vsri9
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
