Question about GPS
It sayspressand briefly hold stylus on the cenyer of the target as the target moves around the screen it dose nothing at all
  • 518 Answers
When it says press and hold briefly it means tap and hold briefly, and then follow the target, it is just to align the screen for your map display
Posted on Jan 31, 2010
How do i recalibrate the leapster gs screen stylus and screen
SolutionIf your Leapster system does not respond to the stylus pen, it needs to be calibrated. To calibrate your Leapster system:
  1. Turn the unit on and wait for the sign-in screen to appear.
  2. Hold down the Home, Hint, and B buttons simultaneously.
  3. When the screen changes, press the A button.
  4. Using the Stylus, touch the center of the targets.
Jan 28, 2013 | LeapFrog Toys
Leapster explorer's screen is not responding to the stylus.
The following are instructions for calibrating the Leapster handheld.(1) Insert a cartridge, turn the unit on and wait for the sign-in screen to appear.(2) Hold down the Home, Hint and B buttons simultaneously.(3) When the screen changes, press the A button.(4) Using the Stylus, touch the center of the targets............hope this what u wanted.......DT
Nov 17, 2012 | Video Game Consoles & Games
On the screen of MP826 a message appears it is -touch the center of the target and hold for one second. repeat as the trget moves . i try this but nothing happens .
This is the screen calibration utility. Your screen may of become really bad out of calibration. It may take a few times to get it to fix itself before you can use it. It may also help to use a stylus
if you have large hands.
Apr 27, 2011 | Coby MP826 MP3 Player
My apps libaray on my coby kyros mid7015 isnt working!!! everytime i try to go into the apps libaray it keeps saying that theres been an unexpected problem and that it has to "force close" why is...
Sounds like you need to reset AppsLib.
This fix will wipe all your data, so be sure to back everything up.
Go to Settings.
In settings go to Go to "Privacy".
Select Factory Reset.
Select Reset Device.
Connect the unit to the computer using the USB cable and "Select" Erase Everything" The following will occur: • The screen will display COBY • The screen will display Android • The unit will reboot to the Menu screen
Step 6- The unit will prompt to calibrate. Hold stylus on the center of the target. Repeat as the target moves around on the screen. ****DO NOT *** press Return or Home". The unit will display "calibrate success" and will return to the main /home menu automatically. If for any reason the unit went into standby mode and the touch screen does not respond, reset the unit using a pin.
After the Factory Data Reset, do not launch the Applibs yet until: 1- You have configured your Wi-Fi 2- Check/enable "Unknown Sources"- Go to Settings, Application Setting. Done.
You can now open appslib.
Feb 28, 2011 | Coby Kyros 716829701508 Tablet PC
I reset my main memory when it was done the restart automatically.there is given on the screen "tap the target firmly and accurately at each location on the screen.the target will continue to move until...
you have to update its firmware. it is corrupt. but first ,When Omnia powered off,hold onto the Call and Cancel buttons, press and hold the power button for a approximately 5 seconds until the reset screen shows up. If you do it wrongly, you will hear the samsung jingle and the startup animation.When it is on,hold onto the Call and Cancel buttons,poke the soft reset hole and the reset screen shall show up. otherwise, visit here for upgrade options.
regards
Mar 12, 2010 | Samsung SGH-i900 Omnia Unlocked Cellular...
I have HTC P3450 phone
so just do it carefully click between the cross hairs of the plus sign at five points one after another with a pointed object carefully then it will move on to the next screen for further setup ,
but if u r stuck at this point and u are gettin this alignment screen again and again in a loop then my friend its a hardware fault basically it is a faulty digitizer or touch panel u can say the front screen where u click with ur stylus it became faulty u need to replace it other wise it will stuck on this screen alignment process and will not go past, u need hardware replacement it is around 60 to 70 $ cost to replace just take to the service centre in ur area or find it on www.htc.com or tell me if u have somethin else to ask.........pls lemme know if it helps
Feb 22, 2009 | HTC Touch P3450 Smartphone
The screen seems locked in one mode
im not to sure if this works with what u got but it should. soft reset: pop out the battery from it wait abit ant then pop it back in turn it on if it still does this then..... hard reset: look at the back of the phone for a little round button to push use like a paper clip or pen, hold it down and the power button down as well until the device powers on. u will loose all ur data on the phone but it shouuld work. if it doesnt then its ur hardware not the software. somewhere they repair cell phones like celltek would be able to for good price.
Jan 12, 2009 | Handspring Visor Edge Handheld
Leapfrog leapster hand held console
Had the same problem and no target. Wait after it says touch the center of the target for at least 5 minutes maybe longer and suddenly it will beep and appear. After touching each of the 5 targets as they move from corner to corner and then center the stylus and touch screen once again worked.
Art
Jan 08, 2008 | Video Game Consoles & Games
Palm treo screen freeze
check to see if any buttons or keys are stuck down.
If not, then you may have a damaged screen or cable that needs repair
Dec 05, 2007 | Palm Treo 650 Handheld
GPS Logo
54 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
