Question about Samsung Refrigerators
Samsung american fridge freezer, not freezing, clicking noise at the back of the fridge
  • 306 Answers
Your PTC relay is bad and needs to be replaced. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken If the part is way expensive you can replace with a 3 in 1 relay for refrigerators alot cheapier and work just as good.
Posted on Jan 31, 2010
Samsung American fridge freezer SR-S2028CSS keeps beeping and randomly turning the fast freeze on and off.
quite possibly it needs some freon added to the system and only service people can do this
Jan 06, 2016 | Samsung Refrigerators
Fridge/freezer freezing up
common issue on uk samsung rsh1 american style appliances
easy cured - diy repair kits been on the market a few years now
watch this youtube video for some extra help
Jun 10, 2014 | Samsung RSH1DTMH American Style Silver 524...
Hi my Samsung fridge is freezing up? What do i do?
samsung fridge freezer problem click here
hi what model do you have - if its the american style one
fridge freezer up is a common prob with samsung
you could have a look on youtube - there a guy who has a dedicated youtube - samsung fridge freezer repair channel
heres one of the videos >>>>>>ebay links below videos where you can pruchase spares
hope this helps , if you require parts look under youtube videos as there are links you can click onto that will take you to this guys ebay samsung spares shop ..">
Dec 28, 2010 | Samsung Refrigerators
Have samsung american fridge freezer with ice dispenser i bought it second hand the problem is the digital display says the freezer is 20 degrees but its freezing inside also every minute or so we hear a...
If it's American, the temperature probably reads as fahrenheit. If so, 20 degrees F is 12 degrees F below freezing which converts to only -6.67 degrees Celsius.
Domestic freezers should be set to -17 degrees Celsius (= 0 degrees F), so the beeper is warning you that the freezer compartment is far too warm. If it's working correctly and has the temperature control set correctly, then it should achieve the correct temperature if you leave it for 24 hours and do not open the door nor try to use the ice dispenser. If the freezer is full of unfrozen items and so has to cool those down as well, then it may take even longer to reach the correct operating temperature.
Te operating manual for your appliance will tell you how to set the temperature correctly and whether it's possible to select between fahrenheit and Celsius scales. Most models allow you to set an override on the beep alarm as well. I cannot guide you on this without knowing the exact Samsung model.
Please take a moment to rate my reply.
Sep 22, 2010 | Microwave Ovens
We have a samsung american side by side fridge freezer, we had a power cut and when the power went back on the light in the fridge was flashing and making a clicking noise.also the panel on the outer door...
Check your owner's manual. There may be a "reset process" that you can perform in order to restore the refrigerator properly after a power outage. Otherwise, there may be an issue with the "main electronic control board". If this is the case, contact an appliance service company. If within warranty, contact Samsung!
Feb 15, 2010 | Samsung 26.0 Cu. Ft. Side-by-Side...
Constant and fairly loud noise
thats typically an air circulating fan thats either faulty or something is touthing the blade. open up and see.
Jan 09, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Apr 01, 2008 | Refrigerators
Malfunctioning American Fridge Freezer
Is it freezing. Sometimes those led's go out.
Dec 21, 2007 | Freezers
Samsung american fridge sn 188742bp100124K
The freezer temperature ok.
The fridge keeps freezing
Dec 06, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
Refrigerators Logo
329 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
