Question about Hitachi 46W500 46 in. TV/DVD Combo
Wavy lines from video HD input
I have a 46" that I used without issue for years on the 1st floor. I recently upgraded it to an LCD, so the old girl was moved to the 3rd floor for video games. After hooking up the Playstation 3 with a AV component cord (5 plugs @ TV to 1 @ Playstation), the picture is just wavy lines.....I disconnected those 5 from the 46" and plugged them into a 19" and it works great.....it seems as though the video inputs have been compromised........the onboard dvd works, and so does the standard cable......
  • Hitachi Master
  • 5,807 Answers
Hi.
There could be many reasons. But, more Often, it would be
on the Circuits Board. You need to Open the TV, unplug the
wires from Circuits Board, pull it out and check it.
More often, you would find either a Loose Solder
connection or Leaked / Bulged / Swelled capacitor. You
need to note down the part number and you could order it
online or go to your Local Electronics shop and
purchase it. Once you solder it, it would be all set.
the Procedure is the same for your Play Station, but try to connect
it, first to your new LCD TV for sure.
If the PS works on your new TV, then you do not need to open it.
One thing the PS did not work out , is the video setting, try checking
as if double-checking again .It is likely not compromised.
Connect video cable , one by one but monitor the audio if it is OK.
Regards,
palaboy
Posted on Jan 31, 2010
Panasonic pt-50lc13 small wavy lines
Look to see if it happens on the rear audio and video inputs--that will narrow down where the problem is.
Be aware this model was RECALLED and all original owners were supposed to have the set replaced a few years ago.
Also rule out the signal---if using a cable box connect the cable without it directly to the coax fitting---box can cause this---stranger things have happened.
May 27, 2012 | Panasonic Televison & Video
Samsung 50 HLN5065WX has wavy lines on analog input
this is an inherit problem of this set - - search 'wavy line' and you'll see many samsung sets have this - there is no cure ! use the set with component or hdmi good luck
Jul 16, 2010 | Samsung SP50L6HX 50" DLP HDTV
MAGNAVOX 51MP392
I have a philips magnavox and had two problems that I recently fixed using kits from www.TvRepairKits.com. I can't say enough about their kits and help. Without them I would have never been able to fix my TV set myself.
The first problem I had was the TV was looking 3D. After doing some homework I found out that this is a convergence problem. I bought a kit, followed the instructions, and to my amazement fixed it myself.
After building my confidence with the 1st repair I decided to get their CRT fluid kit. This kit fixes the dull video,red video, or bright/halo looking video. If you have a magmavox set that is more than 5 years old your tv has this problem already. It happens on every set. As before I bought the kit, followed the instructions, and now my video looks factory new. Once again I wanted to say thanks to the team at Tv Repair Kits for putting together kits that the average joe can use.
ML
Jul 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
Rainbow color effect appears when Samsung LCD plays Wii or DVD
Hello, I have a question which video inputs are you using for your DVD and Wii connections? The reason I ask is because this sounds like video distortion cuased by noise. If possible can you send a picture of the screen when it has this problem and send which video ports are being used? If it is noise in the video you may have a saw filter problem, or a decoupling issue. In any event I'll know more once you send those pictures and which inputs you are using for your DVD and Wii. Thank you, Shuttle83 http://www.electron-age-technologies-llc.com service@electron-age-technologies-llc.com
May 30, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung HLN567W wavy lines
Check to see if your DVD player is outputing a progressive scan and turn it off if you are using the S-Video cable, it does not support progressive scanning.
Apr 18, 2009 | Samsung HLN567W 56" Rear Projection HDTV
Vertical lines in LCD tv screen
Need to check the two things.
1st -- need to exchange T-con Board.
2nd -- need to exchange the cables between T-con & LCD panel or
between T-con & Main(LVDS cable)
Jan 29, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Mitsubishi DLP wd-52725 wavy lines from top left to bottom right
the DM board is going bad and needs to be rebuilt. check out www.tv-techs.com
Jan 02, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Picture not HD quality while watching HD channels
Make sure you are using an HDMI video cable for optimal picture quality. Also, you must be using an HD reciever.
Jun 12, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Hitachi 46W500 46 in. TV/DVD Combo Logo
49 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
