Question about Toshiba Televison & Video
How do you tune in a VT705 Toshiba video recorder to the Television channels?
We have now disposed of the video recorder in question but thank you for your speedy response to our query. Kind regards.
Posted on Feb 05, 2010
How do i tune the channels on a toshiba rc3910
Hi
Before tuning the set to auto tune mode, make sure the antenna or cable, whatever may, connected to its appropriate sockets at the back of the set firmly. To make it autotune:
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
lost.
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
OK.
Jul 10, 2011 | Toshiba Televison & Video
Toshiba rd-xv47kb auto tune
Check that you have the arial plugged in correct input otherwise it will not tune up.
May 11, 2008 | Televison & Video
I have a Toshiba DVR19DT. I cannot get it to tune in television channels. Any suggestions?
Is the aerial that is plugged into the recorder OK? Check it by using the same aerial on the tv and see what the signal is like.
There is not a lot more it can be, these items don't suffer from many problems with tuning. Check in the menu to see if it is actually tuning.
Hope this helps.
Dec 31, 2010 | Televison & Video
I have a toshiba rdxv60kb dvd recorder,,and can;t tune the programes into my sky box.
I have a toshiba Hdd & DVD / Video Recorder However I can not get it to work with my Sky setr up If I set thimer recording it does not work when I turn it on it will only work pn channels that are not from sky it will not instant record nor will it record programmes prerecoreded of sky HDD it will record everthing other than what I want.
My E-Mail Addres Is fj.gadkey_1@sky .com
My Home hone is uk 01527 545284
Nov 08, 2010 | Toshiba DVR660 DVD Recorder/VCR
How do I hook up my vcr to my dvd recorder so I
You will need one RCA video cable it will have a yellow, red and white plugs. On the back of your VCR locate where the color inputs are find where it says VIDEO OUT hook it up there. On the back of the DVD Recorder look for the same color input jacks NOW find where it says VIDEO IN hook it up there. You may have to turn on your TV,DVD recorder and VCR to get the right channel. your Recorder may have one or more video inputs if it does turn on all three. Use the channel on your TV you use to watch DVDs make sure you see your DVD screen. Now to record to a DVD. Change the channel on the DVD Recorder. Look for the input channels It may be Video 1 Video 2 etc... depends on the inputs you have. ( A great way to tune your DVD Recorder is to play a prerorded VCR tape. Turn the channel on your DVD Recorder unil you see the prereorded tape playing. )
Jul 21, 2009 | Toshiba Audio Players & Recorders
Sony bravia-unable to tune in video channel via dvd
thethe wires have to run out of your cable box into the dvd recorder then back out to the tv,try rehooking it up
May 19, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Wharfedale DVDR24HD250 DVD Recorder When set up will not find any programmes on Automatic Programme Search (APS)
Products such as this will use an internal tuner to tune channels, this tuner will not detect your televisions freeview stations, to record from your television, connect scart out from tv to the scart in on the recorder, then select the scart A/V channel, use the television to select the channel you want to record, you will not be able to record 1 freeview channel and watch another freeview chanel as you only have 1 digital tuner (in the television) the recorder does not have freeview built in.. hope that helps
Mar 24, 2008 | Televison & Video
Unable to record one tv channel while watching another tv channel
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
Mar 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Tune playstation 3 to toshiba television
first try to manuall select your av channell from your tv's remote control,if this won't work try another scart cable or port on your tv set
Dec 26, 2007 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
