Question about GE Refrigerators
Re model PDS20SFSBLSS- profile- bottom freezer- Not making ice and I can't get the new water filter installed per the directions-specifically the direction of having the blade on the end of the cartridge positioned vertically. It was horizontal when I took it out and and that is the only way I can get the new one in-
  • LoisNYC Feb 01, 2010
    Is the reason that ice did not start being made because the filter was inserted and the blade was horizontal & not vertical. Please help me get the icemaker working.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Do you have the bi pass cap that was originly there? put it back on that way u an make sure your icem is working correctly. if so, then this filter should only go in one way. look inside the cavity for alignment pins. good luck. repost if needed.
Posted on Feb 01, 2010
  • 4,066 Answers
Can you turn the filter to lock it in once you get it in in the horizontal postilion?
If not, look in the place you put the filter and see if you can realign the slots the filter fits in.
Posted on Jan 31, 2010
  • Charles T Nevin
    Charles T Nevin Feb 01, 2010
    Normal
    0
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";}
    Try swapping the wires on the dual water inlet valve. It’s
    on the back where the water supply comes in. Then try the water dispenser. The
    water should go to the ice maker. This will tell you weather or not the ice
    maker valve is working and if the line is clear.
    The water inlet valve on the back of unit opens when the ice
    maker needs water. If the valve doesn't seal good because of sediment or wear
    it will continue to drip and when the water reaches the ice maker supply tube
    it will freeze blocking the fill tube..
    You can take the water line off the valve and watch to see if it drips.
What to do after new water filter installed ice stopped being made?
Need to change water head (the part that the filter fits in).
Aug 29, 2014 | Sub-Zero 650 / O Bottom Freezer...
Ge profile fridge side by side makes only 8 ice cubes per day
Good day,
Assuming the temperature in the freezer is normal. 10 degrees or less. then it should be one of the 3 items here.
1. Partially plugged filter.
2. Water valve in the back bottom of the machine failing to open properly.
3. Partially blocked supply line from the house or it's connection fittings which ar more common than the line itself.
As well, if the water fill valve has a small leak on the off cycle, the fill tube running from the outside back of the machine that supplies water to the ice maker cavity may have ice starting to cause a blockage.
Nov 06, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
Ice Maker leaks water inside the freezer
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Apr 19, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
Our ice maker is making 5-10 cubes per day. Ice
OK, Have a look (if you can) and see if one of the water jets might be broken, or if there might be a defect in the tray. I can't help any further i'm afraid.
Apr 14, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
Purchased a GE Profile bottom freezer April 08. Has indoor water dispenser. Changed the water filter 60 days ago. Since then the amount of cold water dispensed has slowly decreased to a trickle. There...
Disconnect the water line where it comes out of the water inlet valve and see how the flow is when you try the dispenser. Disconntct the water line at the bottom of the freezer door where it goes into the door. If it flows good here it may be freezing in the door. Open the door till it thaws.
If it's good at the inlet valve and slow at the door, some models have a way to put a plug in and bypass the filter.
Aug 14, 2009 | GE Profile PFSF6PK Bottom Freezer French...
Reset Filter Indicator Light is on
Look for your model number from the sticker inside the fresh foods section of the refrigerator, usually on the liner near the door opening. Now, go to http://www.geappliances.com/service_and_support/literature/ to download a use and care manual for your model, as the reset procedure may vary by model. The filter is usually located at the very back right upper side of the fresh foods compartment, but again, it may vary by model.
Apr 11, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
Freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
Mar 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
