My 4 speaker Logitech system (PID: A746) does not work
My 4 speaker Logitech system (PID: A746) does not work at all after charging or before. couldn't find a manual. (fresh from the box new)Any suggestions??. Thank You
Everett
eday6 @roadrunner.com
techman
  • 3130 Answers
SOURCE: Logitech x-530 5.1
Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the M3D button on the controller unit (if you own a z-560 or z-540) or use the source selector switch (if you own a z-5300 or x-620). If you do not have any of the models above, you can use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting. Go here to get an operations manual for this setup. http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/fattach_get.php?p_sid=d*11Q7xi&p_accessibility=0&p_tbl=9&p_id=2924&p_created=1126107772&p_olh=0 Good Luck
Posted on Mar 22, 2007
  • 84 Answers
SOURCE: Connect DVD Player to logitech X 540 Surround System
Bad connection on that one speaker, if you have tested the system with other equipment and it works thn you MUST have a bad connection INSIDE you DVD player. If your DVD had a whole channel out on your output amplifier I beleive then 2 speakers would not work so more than likely you have a bad solder joint inside system for DVD output
Posted on Feb 11, 2008
  • 4 Answers
SOURCE: MANUAL
http://www.moultriefeeders.com/ProductInstructions/GameCameras/default.htm
Posted on Dec 01, 2008
ViscamTech
  • 528 Answers
SOURCE: logitech x 540
Following is a diagram showing how to connect the speakers. a1d5e61.jpg This was taken from the logitech x-540 user manual. You can download the manual from http://safemanuals.com/user-guide-instructions-owner-manual/LOGITECH/X-540-_M
Posted on Aug 14, 2009
  • 201 Answers
SOURCE: Please could you obtain Logitech Rechargeable Speaker manual
http://www.retrevo.com/s/Logitech-S315i-Speakers-review-manual/id/23582ci761/t/1-2/
Click on the "Manuals" tab, then the "Get Manual" button.
Posted on Feb 03, 2010
Why have 3 out of 5 speakers on my PC stopped producing sound even after configuring and updating drivers??
Sounds like a configuration problem. See this... http://www.logitech.com/en-us/support/224
Also, visit Control Panel/Sound, select your Default Device, and click "Configure" to verify that the configuration is set correctly.
Jul 15, 2014 | Logitech Z-5500 Speaker System Control...
I need a draiver for Logitech camera for home or office M/N:V-USA14 P/N:861206-0000 PID:LN53381
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Dec 30, 2012 | Logitech Computers & Internet
Battery will not charge
1) Ensure the cradle is plugged into an active AC outlet and the LED light on the cradle is on. There is a switch on the bottom of the cradle to control the brightness of the LED, set it to the highest. Try different outlets if needed. Does the LED light turn on and stay on (does not blink)?
2) Remove the battery. Place the remote on the cradle and check the LCD screen. The LCD screen should display a 'White' screen with possible colors before going off. Try this a few times to confirm behavior. Did the LCD turn on briefly?
if no, contact logitech
3) Reinsert the Battery. Have you charged the battery for at least 3 hours? If no, please recharge the batteries for at least 3 hours.
if yes, contact logitech
4) Did the battery ever boot the remote? If yes, please continue troubleshooting.
if yes or no, contact logitech
5) Remove the battery. Check the 3 gold contacts on the battery to see if there are markings on all the contacts signifying it was connected correctly to the remote. Did the battery have markings on all 3 contacts?
if no contact logitech
if you have determined this is a hardware issue, contact logitech and provide the information below
The PID of the remote:
The P/N of the remote:
The PID of the RF Wireless Extender:
The P/N of the RF Wireless Extender:
Full Name:
Email:
Login ID (Current Login for Harmony Remote Software):
Phone number:
Street:
City/Town:
Country:
Zip/Postal Code:
Please Note: The PID (Product Identification) and P/N (Part Number) for the remote can be found either on the underside of the battery cover, or at the bottom of the battery compartment (the battery might be covering it). Your PID number is a character code with a combination of letters and numbers, starting with either WL, WD, or LZ
Jan 26, 2010 | Logitech Harmony 890 LCD Remote Control
Logitech Webcam M/N: V-UAP9, P/N: 861170-0000, PID: LN54982
I HAVE LOST THE DRIVER FOR MY LOGITECH WEB CAM
M/N: V-UAZ27A
P/N: 861208-0000
SO I AM IN NEED OF A DRIVER
Jun 27, 2009 | Logitech Webcam
Logitech x 540
May 11, 2009 | Logitech Z-2300 Computer Speakers
Logitech THX Z-2300 Speakers Don't work and subwoofer does
Well, just because someone at Logitech said the speakers are definitely broken doesn't necessarily make it so. They told me the same thing, yet when I read on another forum that plugging earphones into the wired remote sometimes seems to make things better, I plugged earphones into the wired remote -- and Voila! All of a sudden the blue light went on and I had sound from all three speakers. The sound continued working properly even after removing the earphone jack. IMO the problem could be with the wired remote rather than with the speakers themselves. My speakers work again!
May 07, 2009 | Logitech Z-2300 Computer Speakers
Logitech mm50 speakers will not charge
Try either eBay, or go to Radio Shack.  You'll find them there.
Jan 15, 2009 | Apple Logitech Inc MM50 Portable Speakers...
DELETEING TRACKS
i have problem with my mp3 walkman sony ,all the time ,,NO DATA BASE FOUND ,, IDONT KNOW WHATS THAT MEAN
Jan 26, 2008 | Audio Players & Recorders
284 people viewed this question
 Grubhead
Grubhead
