Question about RIM BlackBerry Storm 9530 Smartphone
My phone keppad is not working
My phone keypad is not working
Micromax M2 keypad not working
Your Phone Keypad Ic Deafult So Please Change keypad Ic
and keypad Problem Will Solved
Jul 24, 2012 | Cell Phones
The pad on my GE profile microwave won't work. Vent, and lights still work, just can't enter anything on the keppad.
You have a failed membrane keypad.
On some models, the membrane keypad is available as a separate part.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
On other models, you replace the control panel frame, which has a new keypad already attached. It's a pretty simple do it yourself job. Or we can do that for you, too.
Feel free to contact us directly with your full model number from the tag on the oven.
May 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Hi my nokia 3110c...phone whenever...i switch the phone on...the keypad doesnt work..infact it just works a few seconds as the phone is loading..(enough time to unlock the keypad using the security code)...
Hi, when a keypad does not work on a phone, it is usually caused by dirt inside the keypad area of the phone,you can open the phone and clean up the keypad area.
Sometimes too, as the case may be Chips also can affect the keypad and allows the phone keypad not to function.
There is an IC chip inside that controls the function of the keypad.
You can fixed the IC chip inside the phone by replacing the damaged IC inside the phone.
When you replace the damaged IC .i assure soluton tothe problem.
Take care.
Oct 07, 2010 | Nokia 3110 Cellular Phone
The down button the numbers 2, 3 and end call button have stopped working. when i press one of these buttons its shutting the phone down-any ideas or advice please?
Hi, it's the keypad IC or the keypad itself. So you can check the keypad if there is dirts that is stopping the keypad from working. Or the keypad needs to be replaced.
After checking the keypad if the keypad still did not solve the problem,
You will have to replace the keypad IC inside the board of the phone.
Take care. .
Aug 20, 2010 | Sony Ericsson K850i Mobile Phone
Nokia 6670 menu key is not working
keypad not working might be caused by:
the phone keypad is dirty,
or
the I C that control the keypad on the board of the phone is bad.
To check if the keypad is dirty, detach the front casing of the phone where the keypad is, clean with brush or a white cloth to clean of necessary dirt of the phone, then couple it back and test.
If after cleaning the keypad and is still not working, then the key pad I C on the phone board is damaged and it needs to be replaced.
Would advice if you to have the knowledge on how to open the phone, you can take it to a phone repairer to fix for you to prevent further damage on the phone.
Have a nice day.
Mar 23, 2010 | Nokia 6670 Cellular Phone
My Nokia 5200 (Number keypads) will Not Working
u need to change the key pad until then it wont work.
two keypad IC's under the keypad and next to the keypad connector unfortunately all the keypad points are linked to the IC's and so even if one key doesn't work it is related to these IC"s in question UNLESS the keypad connector is dirty or sticky please do service your phone or take it to a reliable technician
Jul 01, 2009 | Nokia 5200 Cellular Phone
Keypad problem of sony ericsson
It could be any number of problems, jhoyz0018: a fault, it has been dropped, or it may just be dirt/dust that has lodged under the membrane and stops the keppad from working properly.
You have three options:
1. If you bought the phone from a store or direct from a manufacturer or Airtime Provider, return it for replacement/repair.
2. If you have Phone or Home Contents Insurance, make a claim for a new phone on that.
3. If you bought the phone second hand, off eBay or similar, then carefully remove the fascia, clean the membrane and keypad with a lint-free cloth or air-brush and re-assemble. If still not working, you will need to return your phone for repair/replacement.
Apr 29, 2009 | Ericsson Lands Phones
Numeric key pad
Whats the model of your laptop?
I know that on some IBM models, there was a button called "Num Lock", and by pressing that on you activate the nemeric keypad under the ordinary letters
Dec 10, 2008 | Computers & Internet
Motorola L7 keppad not working
hi,
Im getting error
switch PTT service on from settings.
Mar 20, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Intermittant Keypad lock up & intermittant antenna reception
You should had let the kid drown , hahahahaha just kidding buddy. Your phone is definately going through a slow death, once it has liquid damage you will encounter these problems and alot more others. Liquid damage is liquid damage, your going to need a new phone my friend. Good luck.
Nov 07, 2007 | Motorola Mobility RAZR V3
RIM BlackBerry Storm 9530 Smartphone Logo
87 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
