Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
My printer is saying error 30 how do I fix this
  • bwedhorn Jan 31, 2010
    I asked for help with a Brother MFC 665CW printer I dont know where 240C come from so this soltions was no help for me at all my printer has ink cartiages you take out . Does anyone know how to fix error message 30 on a BROTHER MFC 665CW PRINTER 7 IN1
  • 4,041 Answers
Hi I have found this for you.
What is Machine Error 30, 33, 34 or 35 and how can I clear it?
Description: Several conditions may cause the error message Machine Error 30, 33, 34 or 35 to be displayed on the LCD. This error may be the result of one of the following:
  • The print head carriage is failing to return to its home position to the far right of the unit.
  • Both of the springs located on each side of the carriage is out of place.
  • The cartridge covers may not be locked securely in place.
Please follow the instructions listed below to correct this problem:
  1. Press the INK button on the Control Panel.
  2. Using the dial pad, press 2 (Replace Ink). The display will prompt you PLS OPEN COVER.
  3. Pull the Scanner Cover release lever located under the Control Panel and lift the Scanner cover. The carriage should move to the left in order to replace the ink. If the carriage does not move to the left, your machine will require service.
    If your machine is still within warranty, click here to locate a Brother Authorized Service Center in your area or click here to obtain contact information for the appropriate Brother Customer Service Center. If you are out of warranty, use the link to locate a Brother Authorized Service Center in your area.
  4. After the carriage moves to the left, press down each cartridge cover and remove all ink cartridges from the machine. There are 2 springs located on each side of the carriage that hold the print head against the carriage assembly. They are thin silver springs approximately 2 1/2 inches, set at an angle.
  5. If the spring is out of place, press the spring back into place. You can use the spring on the opposite side of the carriage as a guide as to the correct position.
  6. If the spring is not out of place, reinstall each ink cartridge.
  7. After installing the ink cartridges, close the covers and verify they are securely locked into place. Your machine then prepares for a head cleaning and goes online. The LCD screen prompts you to verify if a new ink cartridge was inserted for each color you removed. For example, DID YOU CHANGE BLCK 1. YES 2. NO.
  8. Press 2 (No).
Note If you decided to place a new ink cartridge in for any of the colors when uninstalling and reinstalling the cartridges in the above process, press 1 (Yes). The machine will automatically go through a cleaning cycle.
Also this might be handy for you. To reset purge counter
1) Enter machine maintenance mode (on MFC240C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine’s log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Please call back and gave us a vote. All The Best: Pineworks
Posted on Jan 31, 2010
HOW DO I FIX THE ACCESS DOOR ERROR CODE 3501?
The Kodak support site says:
To resolve this error, close the printer access door. The printer will not operate while the door/cover is open.
If the error continues even after you close the printer access door, power cycle the printer:
  1. Turn off the power (press the On/Off button on the printer).
  2. Unplug the printer power cord from the back of the printer.
  3. Wait approximately 30 seconds.
  4. Plug the printer power cord into the back of the printer.
  5. Turn on the power to the printer.
If the error continues, contact Kodak at:
http://www.kodak.com/go/contact
May 18, 2014 | Kodak Office Hero 6.1
Wont let me print
The error code "EC5" indicates a short in one of your cartridges. Please follow the steps below to identify and fix the problem:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Jan 07, 2012 | Lexmark X2670 All-In-One Printer
Screen displays message saying "cover
It could be that the cover sensor is stuck or could also be due to the cartridges in the printer. Please follow the steps below on how to identify and fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Open the printer cover and remove the cartridges.
  3. Close the printer cover.
  4. Re-brick your printer by pulling out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  5. When the printer turns on, reinsert one cartridge first.
  6. Close the printer cover and check for any errors.
  7. Reinsert the other cartridge.
  8. Replace whichever cartridge is causing the error to appear.
  9. If no error appears, reload some sheets of paper and try to print a document again to verify that problem is fixed.
If the problem continues, please contact the Lexmark Technical Support Center for additional assistance.
Sep 12, 2011 | Lexmark X3470 All-In-One InkJet Printer
Printer is saying that one of the cartridges has a problem
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Nov 12, 2010 | Office Equipment & Supplies
Won't print. says no magenta cartridge installed. replaced w/oem magenta. still says no cartridge installed.
Oct 31, 2010 | Brother MFC-3240C All-In-One InkJet...
Error 30
I have the MFC 465CN - I was receiving two error codes:
Unable To Clean - Error 30
Unable to initialize
To fix, I first cleared the memory by unplugging the printer, then holding down the red stop/exit button, keep it held, power up the printer, and dont let up the button until it finishes the start up.
I then pressed the "ink" button and performed a cleaning, alignment, and quality check. After this, everything worked fine.
DO NOT try to print anything from your computer or have any pending print jobs while doing this - it appears that pending print jobs, or anything in the printers memory was interferring with the initilization and cleaning cycle it performs.
Hope this helps...
Jan 10, 2009 | Brother Multi-Function Center MFC-240C...
Hp6180 all in one has an error 30
Here is a list of all HP service error codes. Hope it helps :)
Oct 06, 2008 | HP Photosmart C6180 All-In-One InkJet...
Unable to print code 50
what error code do you receive? Is it 30 only or does it toggle between 30 and 50 (watch some more 5 minutes!).
Anyway, two solution for this named errors:
1. Only error 30:
There IS some paper piece left inside the printer. Mostly could this be found on the very very left side (seeing from front as in normal use). Open scanner and have a good look into the edges. You will find a small piece of paper left there.
2. 30 and 50 (toggling)
See here same issue:
http://www.fixya.com/support/t211210-brother_mfc845cw
(enlarge browser window to see pic some what better).
Aug 21, 2008 | Brother MultiFunction Center MFC-440CN...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
341 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
