How to fix the volume on RCA tv..
I can't hear the volume on my TV..I can see it really good, but can't hear anything
  • bonniebeeeee Apr 19, 2008
    STUPID husband accidently plugged the DC jack into the rear speaker outlet on the TV. Now you get a picture, but, no sound.....Please tell me how to fix this ?
  • 5,138 Answers
Look on back of tv see if there is a switch for internal & external speakers see if it is on or off ,if not go to menu in audio see if speakers are turn off or on.If this does not work you may have bad speaker or audio output ic. ThankYou for trying FixYa. Have a Nice Day.
Posted on Feb 19, 2008
I unpluged my tv without turning it off and when i connected it i can see but i cant hear.
Posted on Aug 24, 2009
I have a tv/dvd flatscreen televsion. It is only a year old. The problem is I can not hear anything. My television is displaying the screen and movies/television is working fine, just no volume. Please...
Does the the little bar graph on screen volume display react when you turn the volume up and down or does it say something like TV VOLUME IS FIXED?
Try using your remote to look in your tv's MENU for the AUDIO OPTIONS.
Check to make sure the SPEAKER option is turned ON.
If that doesnt work, try running a cable from your tv's audio out jacks in the back to one of your home stereo's AUX inputs and see if you can hear the tv through your stereo.
Good Luck.
Jan 20, 2011 | Televison & Video
I just bought the Sony MHC-EC99i and I don't know how to connect it to the tv so I can hear the audio from the tv to my speakers
Not knowing anything about your TV...
http://esupport.sony.com/US/perl/model-documents.pl?mdl=MHCEC99I click on "Operating Instructions"
Look at the section: Using Optional Audio Components.
Assuming your TV has an RCA audio output or headphone output, connect to the PC In. You might have to get an adapter. Select PC In to hear it. make sure the TV's internal volume controls are sending a "Fixed" audio output or its volume control will affect the output. Mute the TV or turn its speakers down.
Jan 16, 2011 | Sony Audio Players & Recorders
Hearing my television through my home theater system
Without knowing anything about your TV receiver all I can assume is that the TV has a least an RCA analog audio OUT. Run that to any available analog input on the HTS. make sure the TV's audio controls (hidden in a menu somewhere) is set to Fixed so the TV volume won't affect the HTS volume. Then you can turn the TV speakers off and still listen through the HTS.
You'll only get stereo this way. Ideally, you would have a digital audio source for the TV audio signal.
Jun 07, 2010 | Insignia Digital-to-Analog Converter for...
My TV has audio (left & right) & video jacks (red,white &yellow) can I connect my Kenwood KR-V5580 to it for stereo sound If so what do I connect it to video 1 or 2, phone,etc
Audio can usually go either way to a TV. In or Out. Why someone would want to hear external audio through a TV's marginal audio electronics and speaker(s) is beyond me, but sometimes that is what they want.
Take the audio from the receiver via whatever unused Tape or Video function connectors you like to the TV's Audio L & R IN. Anything the receiver processes will be audible through the TV as long as you DON'T select that function for listening on the receiver.
Listening to TV-related audio through the receiver and its (presumably better) speakers makes much more sense, but again, the TV's marginally audio capabilites place a serious limitation on sound quality expectations. In your case, stereo is as good as it could be.
If your TV has Audio Out jacks, just run them to any convenient Line Level input (NOT Phono). If your TV has internal audio controls for volume, set it to Fixed so the TV's volume control doesn't affect the sound going out to the Kenwood.
A better TV-related audio solution would be to connect the BEST audio of whatever source you're watching directly from that source to the receiver. Cable, DVD/BD, SAT always have 2-channel analog RCA connectors as well as (unusable on the Kenwood) digital audio outputs.
VIDEO from the Kenwood to the TV:
You describe your TV having Composite (3 -RCA-style cables). The Kenwood is limited to Composite (Lower-quality, single Video RCA-style cable). Check your TV for a single Video In connection and run THAT from the Kenwood's Monitor Out so you can pass other video through the receiver.
In its day this receiver was pretty high-end but to really enjoy modern multichannel audio from video sources you might consider an upgrade to a true multichannel Audio Video Receiver. For one thing it would support digital audio and probably Component and HDMI video. You could still use the Kenwood's amplifiers to drive speakers or as a secondary system.
Apr 29, 2010 | Kenwood KR-V5580
No headphone jack on samsung tv,so i got a ,y adapter and plugged in to rca jacks,but volume is low
Headphone output is usually dependent on the source's volume setting and are not a good way to transfer signal between devices. RCA is the way to go as it is independent of the volume control. Many TV's have a setting for the audio output to select variable or fixed (independent of the TV volume setting). Look for it.
May 16, 2009 | Teac DRH300DAB Receiver
Sound quality/ connection to tv/ audio problems
The sound quality from an HDtv could very well be better than from a lesser-quality TV. The sound from the headphones can only be as good as the signal that feeds it.
Apr 26, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
Rca tv model 32v432t
This set is not digital tuning and you would need a converter for off-the-air reception. You can get full specs and manual downloads from RCA's site:
http://tv.rca.com/en-us/productdownloads.html?MN=32V432T
Nov 18, 2008 | RCA 32V420T 32" TV
RCA D52W20 not working
take the repair money and buy another tv.it would be easier and youd start out with a new tv ive seen display models at walmart for about 700.00
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
FPA lock
hi i have a universal remote and my granddaughter pressed a button on the tv and now i need to unlock the fpa can some one please help.
Mar 08, 2008 | RCA 20F420T 20" TV
There is no volume coming from my RCA television
chick the speaker, if the speaker working. try to replace sound ic
Jul 10, 2007 | RCA 32V420T 32" TV
Televison & Video Logo
1,056 people viewed this question
Top Televison & Video Experts
