Question about Cullmann Cameras
Is there any way I can use my old Cullmann MC30 with a newish Sony Alpha200. I understand that the Cullmann may have a high voltage sync pulse and wonder if there any devices which would allow me to use my flash with the above camera without frying the electronics??? (I'm no expert so words of one syllable would be most welcome!!!)
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cullmann Master
  • 102,366 Answers
Adapters do exist. One is the Wein Safe-Sync, available online from http://www.adorama.com or http://www.bhphotovideo.com
Posted on Feb 02, 2010
Testimonial: "Looks like this may answer my problem, but not 100% sure that it is safe and as one in my dotage, I don't want to wreck my camera."
It won't start. No current from crank sensor to ECM. Wiring diagram checks out.
Hey Bob how's it going ? What engine does it have 2.2 3.5 L ? An how did you test for current ? This is a AC voltage .
The crankshaft position (CKP) sensor is a permanent magnet generator, known as a variable reluctance sensor. The CKP sensor produces an AC voltage of different amplitude and frequency. The frequency depends on the velocity of the crankshaft. The AC voltage output depends on the crankshaft position and the battery voltage. The CKP sensor works in conjunction with a 7X reluctor wheel attached to the crankshaft. The CKP sensor produces seven pulses for each revolution of the crankshaft. The pulse from the 10-degree notch is known as the sync pulse. The sync pulse is used to synchronize the coil firing sequence with the crankshaft position. The CKP sensor is used for ignition timing, the fuel injector timing, misfire diagnostics and tachometer display. The CKP sensor is connected to the ECM by a signal circuit and a low reference circuit.
The best way to test is with a lab scope !
Crankshaft position sensor
Apr 30, 2015 | 2004 Saturn VUE
Mitsubishi VS-55609 top left screen has folded over
chk for any electricity or magnetic interferanc. change the location to the TV. switch of the tv fro 5 min and restart it again back.
Jul 03, 2008 | Mitsubishi VS-55609 55" Rear Projection...
Can i use a Cullmann C28 flash with Canon Eos 400d?
Doubtful. I tried similar with a different brand of flash designed for a 35mm. It worked for about 20 shots then the diodes fried. I've since bought a used Speedlight for my 400D and it works great.
Aug 19, 2014 | Cullmann Cameras
Jvc av32d305 has sync problem rolling vertically and horizantally
You are going to need a schematic---the sync pulse either comes on a line from the high voltage transformer or the Jungle chip---my money would be a open resistor from the Flyback with that pulse for sync.
Nov 07, 2012 | JVC Televison & Video
Where is the cam sensor at
Description & Operation
2.5L Engines
On the 2.5L 4cylinder engine the Camshaft Position (CMP) sensor is located in the distributor.
The sensor contains a Hall effect device called a sync signal generator to generate a fuel sync signal. This sync signal generator detects a rotating pulse ring (shutter) on the distributor shaft. The pulse ring rotates 180 degrees through the sync signal generator. Its signal is used in conjunction with the Crankshaft Position (CKP) sensor to differentiate between fuel injection and spark events. It is also used to synchronize the fuel injectors with their respective cylinders.
When the leading edge of the pulse ring (shutter) enters the sync signal generator, the following occurs: The interruption of magnetic field causes the voltage to switch high resulting in a sync signal of approximately 5 volts. When the trailing edge of the pulse ring (shutter) leaves the sync signal generator, the following occurs: The change of the magnetic field causes the sync signal voltage to switch low to 0 volts. 4.0L
The Camshaft Position Sensor (CMP) on the 4.0L 6cylinder engine is bolted to the top of the oil pump drive shaft assembly. The sensor and drive shaft assembly is located on the right side of the engine near the oil filter.
The CMP sensor contains a Hall effect device called a sync signal generator to generate a fuel sync signal. This sync signal generator detects a rotating pulse ring (shutter) on the oil pump drive shaft. The pulse ring rotates 180 degrees through the sync signal generator. Its signal is used in conjunction with the crankshaft position sensor to differentiate between fuel injection and spark events. It is also used to synchronize the fuel injectors with their respective cylinders.
When the trailing edge of th4.7L
The Camshaft Position Sensor (CMP) on the 4.7L V8 engine is bolted to the front/top of the right cylinder head.
The CMP sensor contains a Hall effect device called a sync signal generator to generate a fuel sync signal. This sync signal generator detects notches located on a tone wheel. The tone wheel is located at the front of the camshaft for the right cylinder head. As the tone wheel rotates, the notches pass through the sync signal generator. The pattern of the notches (viewed counter-clockwise from front of engine) is: 1 notch, 2 notches, 3 notches, 3 notches, 2 notches 1 notch, 3 notches and 1 notch. The signal from 5.7L V8 Engines
The Camshaft Position Sensor (CMP) on the 5.7L V-8 engine is located below the generator on the timing chain / case cover on the right/front side of engine.
Fig.
The CMP sensor is used in conjunction with the crankshaft position sensor to differentiate between fuel injection and spark events. It is also used to synchronize the fuel injectors with their respective cylinders. The sensor generates electrical pulses. These pulses (signals) are sent to the Powertrain Control Module (PCM). The PCM will then determine crankshaft position from both the camshaft position sensor and crankshaft position sensor.
The tone wheel is located at the front of the camshaft (2). As the tone wheel rotates, notches (3) pass through the sync signal generator.
When the cam gear is rotating, the sensor will detect the notches. Input voltage from the sensor to the PCM will then switch from a low (approximately 0.3 volts) to a high (approximately 5 volts). When the sensor detects a notch has passed, the input voltage switches back low to approximately 0.3 voltsthe CMP sensor is used in conjunction with the crankshaft position sensor to differentiate between fuel injection and spark events. It is also used to synchronize the fuel injectors with their respective cylinderse pulse ring (shutter) leaves the sync signal generator, the following occurs: The change of the magnetic field causes the sync signal voltage to switch low to 0 volts
Jun 08, 2012 | 1999 Jeep Grand Cherokee
Toshiba 24af45 horizontal
If rolling in a right to left and not up down it is a sync problem--horizontal sync comes from one of two places in general---a pulse off the high voltage transformer or directly off of what is called in the trade the Jungle IC.
That is not a joke--Most of these sets use a large IC (63 pins or more not unusual) that contains: color, video, vertical drive, ABL and much more---so much is crammed into that chip it decades ago was named the Jungle for clear reasons.
A schematic and or scope may be needed to trace and find what is bad.
if off the high voltage transformer (more common in old sets than new ones) it will be a open resistor.
If at the jungle you would have to go to the pin with the sync and follow it out to see if none at source or if lost somewhere down the stream.
May 29, 2012 | Toshiba 24AF45 24" TV
Where is the camshaft position senor on a 2000 jeep grand cherokee 4 liter
4.0L
This information is available from the Autozone.com websitecheap_repair_3.jpg
Jan 27, 2011 | 2000 Jeep Grand Cherokee
TV Blinks 7 times
The 7 blinks indicate a safety shutdown due to over-voltage in the high voltage section. The high voltage has exceeded 33,000V. This is usually a problem with the power supply regulator. I need to look up the specific part for you. If you are comfortable working inside the set and can solder, you should be able to repair this yourself.
Dan
Jul 03, 2008 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
Cameras Logo
487 people viewed this question
Top Cullmann Cameras Experts
Are you a Cullmann Camera Expert? Answer questions, earn points and help others
