Question about Element Electronics FLX3210 32 in. LCD TV
Black box fills most of screen on certain channels
Black box (with terms about text) fills most of screen on certain channels
    Problem Solver:
  • 13 Answers
In most closed caption CC menus there are options for CC1 - CC4, and Text 1 - Text 4. Try messing with those setting...?
Posted on Jan 31, 2010
  • 476 Answers
THE cc key on your remote control might of been pressed by accident and the close caption was enabled, to correct this all you need to do is press the cc key repeatedly untill the c.c. is turned off, the tv display will go through cc1, cc2, txt1 etc. untill you get to the part that says cc off.
Replaced TY-LA1000 Lamp and now a black box across the picture, TV is PT-50LC14
Check in main menu (set and box if using one) under closed captions--one of the settings is TEXT--black box will appear in middle of screen and certain channels--with the remote turn text off.
Apr 05, 2012 | Panasonic Televison & Video
Having a black screen in the middle of the picture only on a certain channel
Go into the customer menu and select closed captions--there will be an option for CC1 etc--box in middle of the screen means somehow TEXT 1 WAS SELECTED--the idea here was they would have books or written material on certain programs like PBS--select once that you find TEXT is highlighted or select OFF or something else other than TEXT.
Very common problem on a lot of sets---it only appears on some channels because not many ever offered it for use.
If this helps you rate this solution as I do this here for FREE.
SD TECH.
Nov 11, 2009 | Televison & Video
I get a black box that takes up half the screen and it puts random letters and symbols all over the box. it only happens on certain channels also. only on channel 17 and 7 and sometimes on 65
Look for the CC/Text button on the remote. The TV is in the TEXT mode and is showing garbage that is being sent by the broadcaster, You need to turn the CC/TEXT mode off.
Nov 03, 2009 | Emerson EWF2004 20" TV
RCA F26051EM TV menu text is black in a black window can't readto make adjustments
go into menu and look for Closed caption---one of the items will be TEXT---if it is engaged you will have a black box on certain channels in the middle of the screen---switch the text to CC1 for closed captions
Aug 06, 2009 | Televison & Video
Black boxes on a few TV channels - connected to DIRECTV
Turn off closed-captioning. You'll find it's set for "text" right now, probably from hitting a button on the remote without realizing it. The set is blanking the screen for the text which doesn't show up. (In your case sometimes it does. You're the first person who's ever seen anything that I've responded to!) On channels and programs where captioning isn't being sent the box doesn't show up, so you don't know you have the trouble.
Apr 25, 2009 | Televison & Video
Black square box pops up in the middle of tv screen.
turn off the closed captions - you have it in text mode that will have a big black box with video on the sides
thanks
scott
Feb 14, 2009 | Polaroid LCD-1700 17 in. Television
Black box blocks on certain programs
Check your closed-caption settings. You should find it's set for "text" right now. Turn it to "off" (or to "caption 1" if you want the captioning).
In text mode, the TV blanks out a portion of the screen to put up text that never shows up. You only notice on channels or programs where captioned programs are being broadcast. This is a common problem; on many remotes there's a single button to control captions and it's easy to hit it and change settings without realizing it.
Feb 12, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Black box comes up on tv screen
The black box is a text box for closed captioning. Some stations send the signal which turns on the box while not actually broadcasting any text. Go into your setup menu and turn off closed captioning, or at least change it to a different mode. The easiest option is to restore factory presets.
Nov 28, 2008 | Polaroid FLM-3732 Television
Black box covers most of screen some channels, plus gibberish.
it is the closed captions on the tv. it is set to closed caption text. turn it off
Nov 24, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Black mini screen in the middle of screen...
Go to the closed caption menue and turn off "text"... That's a text box and in most areas there is no feed so the black box is all you'll get...
Bill
Dec 09, 2007 | Hitachi 43FDX20B 43" Rear Projection...
Element Electronics FLX3210 32 in. LCD TV Logo
146 people viewed this question
Top Element Electronics Televison & Video Experts
Josh Whitehead
Josh Whitehead
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
