Question about KitchenAid Food Mixers
We have oil leaking from around the rotating part that holds the beaters. How do I stop it?
    President:
  • 1,952 Answers
the beater is simply pushed away from the bowl edge temporarily and stops, as the rubber groove loses contact with the rotating bowl.
Posted on Jan 31, 2010
Mixmaster is leaking oil from the beaters
Here is a link on YouTube. It may not be for your model but it can give you an idea: http://www.youtube.com/watch?v=8eKHVvNX5eY
How to Fix KitchenAid Stand Mixer That Is Leaking Oil
Apr 04, 2014 | Food Mixers
Beater hard to remove...oil leaking out of the place where you insert the beater
The agitater shaft that the beater attaches to is bent and needs to be replaced. It's easy to do . You should replace the shaft , pin, and seal above it. You may also want to replace the part the shaft mount through, to stop oil leak. You can google the model number and find a parts breakdown for the part numbers .
Aug 26, 2011 | KitchenAid 32685 Mixer
The mixer won't release the beater
If lightly tapping the beater to get it to compress the spring does not work then you can drive the pin out that holds the beater on.
Once the pin is out you should be able to wiggle the beater and pull it straight off the shaft without having to push it up and rotate it first. If necessary just tap it lightly and it should slide off. Then you can replace the pin and lubricate the shaft with some olive oil or other cooking oil
Bob
Apr 21, 2010 | KitchenAid K5SS Heavy Duty Commercial...
My kitchenAid stand mixer is leaking oil. How do I
referring to:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%204176924.pdf
You can see that there are 5 screws holding the upper and lower gearcase together. They pinch the gasket number 26 together and prevent the oil and grease from leaking. Remove the chrome ring by prying gently around the ring. You will see the 5 screw heads. Tighten them and the leaking will stop.
If it still leaks then you may have to replace the fiber washers number 29 which will involve disassembling the lower gear case.
Mar 30, 2010 | KitchenAid KSM103 Professional 5 Series...
My wifes Kitchen Aid ksmc50 (rrk90) mixer leaks grease/oil from the rotating plate that the beater/dough hook attatches to.The grease/oil leakes from around the outer edge of the plate as well as from...
the rotating plate needs to be pulled of and clean the grease out and only put two teaspoon dabs on ether end. to pull it of you will need to push the pin in the middle out and just lightly tap it back in.
Feb 15, 2010 | KitchenAid K5SS Heavy Duty Commercial...
I have oil leaking from the beater shaft. a lot
TRY REPLACING GREASE IN GEARBOX AND MAKE SURE YOUR FELT COVER IS IN PLACE (AND CLEAN) THAT SITS UNDER GEARBOX.
**** KENWOODCHEFUSEDMIXERSANDSPARES
Jan 05, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Having trouble removing beater from shaft... HELP
These are held on with a bayonet attachement. You need to rotate the beater to disengage from the shaft.
I would recommmend using a brass pin punch against the tang on the beater and tapping it with a SMALL hammer to rotate the beater.
Once the bayonet is disengaged, it should walk off the pin. If it doesn't you might have to use some penetrating oil like PB Blaster.
IN THE FUTURE put a light coat of mineral oil or food-safe grease on these mating parts to avoid the probllem in the future.
Dec 22, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen aid mixer
take off the chrome ring around the rotator. remove the screws that were hiding under it. pull off the rotator and replace the "O" ring on the shaft.
Mar 08, 2009 | KitchenAid K45SS Classic Stand Mixer
Hobart h600 60qt mixer leak oil
call me. 626-579-3580. Ill fix it.
Mar 25, 2008 | Hobart HL600 Legacy Stand Mixer
Food Mixers Logo
70 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
