Question about HP LaserJet 3020 All-In-One Printer
Printer not working after firmware update
Printer Model : hp LaserJet 3020 OS : Windows XP(32 bit) Problem : When I did my last firmware update I interrupted by pressing the cancel button on my printer control panel as it showed "Printing Document" in my printer display when there was no paper in my printer tray. As there was no response I restarted my printer by switching it OFF & ON while the firmware update was going on and the problem aroused there. Problem Status : Now when I switch on my printer the display on my printer shows the welcome screen "Hewlett-Packard" and my warning lamp keep on blinking as usual while I turn on my printer. But, it remains in this status and not getting into ready mode(Green Round Light is no getting ON). Can anyone please help me with this complaint?
http://forums13.itrc.hp.com/service/forums/questionanswer.do?threadId=1401599 This link leads you to the hp forum where I have discussed about my problem.
I have had an HP Laserjet printer for some time which worked well with my Windows XP laptop. I now have Windows 7 and the printer will not work as there is no driver for it.
Hi there is available printer driver for HP laserjet 1020. Here is the link and select if it is 32bit or 64 bit. http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4062&lc=en&cc=us&dlc=en&sw_lang=&product=439320#N166.
Also this link http://www.getdriver.com/printer/90/download-driver-hp-laserjet-1020-1022-windows-7-32-bit.html
http://freeallsoftwares.com/2010/08/hp-laserjet-1020-printer/
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 20, 2011 | HP LaserJet 1020 Printer
My hp laserjet M1522nf is showing Firmware corrupt ready 2 download
You need to connect the unit via USB and then run the HP firmware update utility so that the current firmware can be installed. This error is usually caused when a firmware update is interrupted. Current firmware for this unit is 20100902.
Feb 22, 2011 | HP LaserJet M1522nf Multifunction Printer...
I have HP 3020 all in one printer. I am able to install printer drivers successfully, but unable to complete scanner driver software. I am using windows 7. Please suggest suitable driver.
You can find drivers here for your printer model and your operating system:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=378053&
Make sure you download the correct version for your computer; 32-bit vs, 64-bit.
To check your operating system, click on Control Panel; then select System.
View the System type to confirm whether you have 32-bit or 64-bit installed.
Dec 22, 2010 | HP LJ 3020 All-In-One Printer / Scanner /...
I've hp laserjet P2015 which is brand new. My os is windows 7 but the driver which came with it is for Windows Mac. The usb port won't detect it & the printer is not working
here is where you can download the printer, be sure to download 32 bit or 64 bit windows 7 also do not have the printer plugged in to the computer untill you install the software then when it asks for the printer then plugh it in to finish install, notice there are 6 printers with letters on one side of them A,B, C, D,E, andf. be sure you havethe right model number with the correct letter. here is the web page to download from.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1845552&taskId=135&prodTypeId=18972&prodSeriesId=1845551&lang=en&cc=us&submit=Go%20â»
Jun 08, 2010 | HP LaserJet P2015dn Printer
Problems with recognizing the printer.
HP do a basic printer driver for the present XP OS dated Nov 2009. I'm surprised HP support were not aware of it.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=1814094
Mar 08, 2010 | HP LaserJet 1018 Printer
Printer Model : hp LaserJet 3020 OS : Windows XP(32 bit) Problem : When I did my last firmware update I interrupted by pressing the cancel button on my printer control panel as it showed "Printing...
Never ever touch the printer while upgrading the firmware.
You now need to replace the formatter
  • DO NOT power cycle the printer or the PC during this process or the printer may become unstable and or unusable without further attention from HP . The firmware update can take up to 5 minutes to complete. Please be patient.
  • During the printer firmware update, the liquid crystal display (LCD) on the printer control panel will display "Printing Document" and will change to "Erasing". After a short while, the LCD display will change to "Programming". After a short while, the LCD will display "complete : )" and the "Ready" LED on the printer will be flashing. The printer will automatically power cycle to reboot and will make noises similar to power on.
Jan 28, 2010 | HP LaserJet 3020 All-In-One Printer
Does nt work with xp/vista
You probably need to update the drivers for Vista and/or XP to work with this printer. Select the operating system you have and download the drivers.
HP Vista (32-bit) drivers and downloads
HP Vista (64-bit) drivers and downloads
HP XP (standard) drivers and downloads
HP XP (64-bit) drivers and downloads
Link for all other operating systems
HP resources for Laserjet 2550n (troubleshooters, support etc.)
Nov 13, 2009 | HP LaserJet 2550n Printer
Hp deskjet 810c needs driver for windows ultimate 7
windows 7 should be able to provide a generic driver
Sep 22, 2009 | HP DeskJet 810c InkJet Printer
I have a 9320 One Touch Scanner and can not find the drivers for Vista. This is creating much frustration as I had purchased the scanner new and can not use it. If possible please point me on where to...
System Requirements PC Microsoft Windows 98 SE, 2000 Professional, ME, XP:
Pentium Equivalent Processor or Higher
64MB of RAM (128 MB Recommended for Windows XP)
200 MB of Available Hard Disk Space
CD-ROM Drive
USB Port
Color Monitor
I do believe the scanner does not support windows vista as of yet.
Printer / Scanner
HP Deskjet 6940 (via Network, auto driver) (32-bit)
HP Laserjet 5L (32bit)
hp color LaserJet 2550L (32-bit)
HP Officejet 4200 (32-bit)
HP PSC 1401 All-In-One Printer (32-bit)
Lexmark 240N (Native Driver x64).
Microtek Scanmaker 3600 (32-bit)
Samsung ML-2010 monochrome laser printer (32-bit)
Epson R220 (32 bit)
Brother HL 1030 works after adding a printer manualy and installing as a brother 1430 (32bit)
Dell Photo AIO Printer 964 (32-bit)
HP Laserjet 4plus (32bit)(64bit) with HP Jet Direct as LPR on Standard TCPIP Port
HP DeskJet 845c (32 bit)
(supported printers/scanners)
Apr 20, 2008 | Office Equipment & Supplies
HP LaserJet 3020 All-In-One Printer Logo
59 people viewed this question
Seeker5211
Seeker5211
