Question about Toshiba Televison & Video
I have a Toshiba 62HM14 HDLP. The television made a "pop" sound, loud enough to hear over the audio. The TV then shut down and tried to restart. I have audio but no picture. Is this a projection light that went out?
  • keiwal51 Jan 31, 2010
    Thank you
  • 476 Answers
Very probable, you can inspect it your self, just locate the access door for the lamp(located on the right side of the tv back) and take the screw that holds it in place, then pull the assembly out by unscrewing the two small screws holding the cage out, you will have a good look at the lamp once you have the assembly out. To install a replacement lamp you can see the following link, can not be explained better than this:
http://www.youtube.com/watch?v=nOM7P_bFfAg.
Posted on Jan 31, 2010
Toshiba pc volume is not loud enough to hear good at all.
In Control Panel go to "Sound". and then "Properties"
depending on your operating system. Try to navagate to a pop up menue that has a number of choices for sound inputs/outputs such as "Speakers" , "Media", "Windows Desktop Gadgets" ect. They will have a up and down volumn bar. I would expect one of them to be at a low setting. Move them all to the top and see if it does not correct the issue.
Jan 14, 2012 | Toshiba Computers & Internet
My LG Plasma television DU-42PX12XC had a loud pop
Your tv contains protection circuitry that would shut down the tv if the ymain was out. If the ymain had blown, you'd have no sound and just a flashing standby light. My gut tells me you need to replace the Power Supply Board (PSB). I've seen this before and after spending too much money trying to diagnose a ymain failure, I was surprised to learn that when you have sound but no picture, the psb is a gonner. Try ebay, shopjimmy.com or discount-merchant.com for a replacement.
Good Luck!
Apr 20, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Philips tv with sound going in and out
Try bypassing the set's speaker by running an external audio amp. I use my bookcase stereo for audio direct from the satellite receiver and turn the volume off on the TV. Sounds better this way! Could be the audio amp in the TV is going bad or the speaker may be bad and the TV's audio amp goes through a shut down cycle.
Feb 10, 2010 | Philips 30PW850H 30" TV
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Sound won't turn down
Change out your audio cables ,if this does not work some where you are missing ground.or its not connected right.ThankYou for using FixYa. Have a Nice Day.
Feb 17, 2008 | Toshiba 51H83 51" Rear Projection...
Toshiba 52hm84 DLP buzzing sound after replace bulb?? no pic
You have bad capacitors in the power supply that took out the regulator, or the ballast circuit is defective. Not really a repair for the novice. Good Luck
Nov 06, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 62hm14 TV turns on with no picture but has sound then green light blinks and it shuts off
This isn't gonna help you, but I have the same problem on my 62HM15A, think we have about the same tv, widescreen DLP,?
My TV does the same thing powers with a blining lite then powers off. First it powered on with sound no pic, then would shut down and power up again with pic and sound , now i gots a nothing just powering on and off until i shut the thing off manually.
thanks, just posted here in case some answers bipea's question and it relates to mine.
Jul 23, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Televison & Video Logo
27 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
