Question about Sony Playstation 3 (PS3) Console
I have a error report on my ps3 saying 8013013d what is it and how do I solve it plz
You will need to reconfigure your internet connection through the PS3, if you are using a wifi connection then switch off your router device and switch it back on again. If this doesnt help then you will need to re configure your connection through the network settings on your PS3. I did it to mine and it works fine now... Sometimes just needs a good refresh as all old data was being stored. Hope this helps!
Posted on Feb 23, 2010
What dose error 8013013d mean
8013013d simply means that it cannot find ip address. It is not connected to the network better to connect it again manually to the router.
Jan 24, 2011 | Sony Playstation 3 (PS3) Console
I keep on getting error 8013013D
This is a problem with your router, not the PS3, check if your router has WSK encryption. Try connecting using WEP, that has to work.
Jan 12, 2011 | Sony Playstation 3 (PS3) Console
Error code 8013013D pops up when PS3 is trying to configure internet connection
you solved this problem with the help of this repair guide you can also try this out....... I hope this will help you a lot.......
Click here to download repair guide
Jan 03, 2011 | Sony Playstation 3 (PS3) Console
Error code on playstation 3 8013013D
8013013D - "A connection error has occurred" - May be to do with the SSID of the
Router or signal strength if the conneciton drops Putting the PS3 into
DMZ may help - otherwise check WPA key Ps3 can't handle WPA2 only
WPA or none
Dec 13, 2010 | Video Game Consoles & Games
My wireless connection to my PS3 has failed. The error code I am getting is 8013013D (network error). How do I trouble shoot this?
restart the router if the connection has worked befor other wise it might be the wrong key to the router
Nov 28, 2010 | Sony Playstation 3 (PS3) Console
Saying error code 8013013d when i try to connect my internet
What you are experincing is a DNS (Domain Name Service) error,and this can be rectified by;
* Ensure that everything is plugged in correctly. The Network Adapter must be fit securely to the PS2 and an Ethernet cable must be securely connected to the Network Adapter. You will hear the Ethernet cable click into place when it is inserted properly.
Reconfigure your network settings. Insert the Network Adapter setup disc into your PS2 and run the setup utility. Make sure that all of your settings are correct, such as what type of network you have and what the name of your network is.
turn off your PS3 and modem. Wait a moment, then power on your modem. Once your modem has connected to the Internet, power on your PS3 and try again.
Disable firewall settings. If you have firewall settings on your network, they could be blocking the PS3 from getting a connection. Turn on your PC and go the "Network Connections" option in the control panel to disable any firewalls that are activated.
Disable your antivirus software. If you have antivirus software, this too could be blocking the PS3 from getting a connection. Open up your software and disable it and check your PS3 again
All the best,i hope this solves your network problem..
Jul 03, 2010 | Sony Playstation 3 (PS3) Console
I have connected my PS3 to the internet wirelessly before but I have recently moved into a new home. I consistently get the 8013013d Error code when trying to connect to the internet... But my room mate...
Hello :D
8013013D "A connection error has occurred" - May be to do with the SSID of the Router or signal strength if the conneciton drops Putting the PS3 into DMZ may help - otherwise check WPA key PS3 can't handle WPA2 only WPA or none
May 21, 2010 | Sony Playstation 3 (PS3) Console
8013013d network error everytime i try to get on line code 8013013d appears
This is a problem with your router, not the PS3, check if your router has WSK encryption. Try connecting using WEP, that has to work. Cheers.
May 13, 2010 | Sony Playstation 3 (PS3) Console
Every time i turn on my PS3 it says "system error 8013013d"
something in your ps3 is not making a good connection check your controller and see if still working without the usb cable link your controller with the usb cablee then disconnect it and see if still one light on then check your wireless control board and see if still detecting networks but I can guaranty that this is an error for something that is not working eather the blu tooh or the wireless card both are in the same board
Mar 20, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
342 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
