Question about Sanyo DP26746 26 in. LCD Television
When i turn on the tv , it shuts itself off in 2
I have a sanyo dp 26746-00 26 lcd tv. when i turn on the tv , it shuts itself off in 2 to 3 seconds. why would this happen
  • Anonymous Mar 12, 2014
    26" vizio pc monitor turns on for 2 seconds then shut off
  • 608 Answers
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
Keeps reseting itself
Dude check your A/V or HDMI cables or whatever you use. HDMI cables can be tricky. Make sure that the different shades of color are matched up exactly. Ex: make sure light blue isn't plugged into the dark blue slot. it may not appear as if it matters but trust me it does.
Jan 01, 2014 | Sanyo Dp32640
Sanyo DP 42849 42'' lcd tv no audio no video
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 03, 2017 | Sanyo DP42849 42 in. HDTV
Sanyo DP 47460
check for any bulging capacitor at the power supply board and check for leak or shorted FET transistor and regulator.
Aug 30, 2012 | Televison & Video
Hello, I'm having an issue with my Sanyo DP42848 LCD TV. When you power it on the LCD panel turns on for about 2-3 seconds then immediately turns off. You can power cycle the TV over and over and every...
It only tells us that the inverter cable needs to be reseated or replaced. It's not an expensive repair so fortunately you can consult any local certified technician and have them work on this.
Aug 30, 2011 | Sanyo DP42848 LCD TV
3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Dec 13, 2009 | Sanyo DP32746 32 in. LCD Television
Will not come on /nothing happens
you have a power supply problem, i will check the power supply first. maybe it is only a fuse.
May 19, 2009 | Sanyo DP32746 32 in. LCD Television
TV shuts itself off
I took Sanyo's advice and bought a new TV
Nov 21, 2008 | Sanyo AVM-1906 TV
Sanyo LCD HDTV Model #DP26746
I am missing the stand to my Sanyo LCD TV. (DP 32647). I dont know where to buy a replacement one.
May 04, 2008 | Televison & Video
Sanyo DP26746 26 in. LCD Television Logo
251 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
