Question about Cuisinart Grind and Brew DGB-300BK 10-Cup Coffee Maker
Coffee maker did not heat - Cuisinart Grind and Brew DGB-300BK 10-Cup Coffee Maker
  • 34 Answers
Why don't you try to bring it to the expert. like an electronic technician.
or maybe your coffee maker needs to be replaced with a new one.
try this link.
hope it'll help you with your problem.
http://www.coffeemakerwizard.com/4-cup-coffee-makers.html
Posted on Feb 01, 2010
  • dr_smilee
    dr_smilee Jul 11, 2012
    What wrong with wanting to fix a coffee maker? I would rather replace a 10 cent part then pay for a whole new coffee maker and send the "broken" one to the dump!
  • dr_smilee
    Or why not replace the cheap 10 cent part that cuisinart uses knowing it will break in a few years!!
    President:
  • 1,952 Answers
An electric coffee maker has an electric flow-through brewing water heater with a heating resistor controlled by a temperature dependent regulating switch responsive to the temperature of the heating resistor, and a warming plate heated by the heating resistor for maintaining the prepared coffee at a desired drinking temperature. Apparatus for adjustably prolonging the interruption of heating current 2 to 5 times the normal cooling time of the regulating switch is connected in circuit with the heating resistor and the regulating switch, and a manually actuated small quantity control means connects the heating current interruption prolonging apparatus in circuit with the heating resistor and the regulating switch. The prolonging apparatus may be an adjustable auxiliary electric heater in parallel with the regulating switch and thermally coupled thereto or an adjustable timer in series with the heating resistor and regulation switch and triggered by the opening of the regulating switch
Posted on Jan 31, 2010
Coffee maker
This model of coffee maker has an adjustable heating element beneath the carafe - ensure the temperature setting for the carafe is high enough to keep the coffee hot.
If the coffee is not brewing hot, the initial heating element/coil may have failed. Removal of the heating element is somewhat problematic and will require disassembly of the water container and base of the coffeemaker, and will likely need to replace the heating coil contained in a plastic sheath. Ensure you take a look at: http://home.howstuffworks.com/coffee-maker2.htm
for further detail.
Apr 07, 2014 | Cuisinart Dcc-2600 14-Cup Coffee Maker
Keurig B60 coffee maker won't draw or heat and "not ready" stays on
Handel not in positive position to start brew process.
Jan 26, 2013 | Keurig B60 Coffee Maker
I have had the machine for two years and it just died. None of the dials or toggle switches work, the digital clock display is dead, the coffee maker will not receive power. I have tried different...
The thermal fuse is probably open, it is usually welded to the heating element and tied into the on/off switch, and usually involves the replacement of the bottom section. The thermal fuse prevents the coffee machine from over heating.
May 04, 2011 | Cuisinart DCC-1200 Coffee Maker
My spacemaker coffee maker heats up but does not brew
try a de-scale with 'scalecleen' available from most coffee retailers
Sep 21, 2009 | Coffee Makers & Espresso Machines
Coffee maker water does not heat
unless you have a real expensive coffee maker, it is cheaper to just replace it at this point. chances are the heating element has burned in two.
Jun 20, 2009 | Braun Coffee Makers & Espresso Machines
Water wont come out of my bunn coffee maker
The first pot of water you put in the coffee maker just fills the water tank which is then heated up , once it gets to temperature you then pour second pot of water this pushes the hot water out of the tank through the coffee grounds into the waiting pot. This way you can make coffee faster than a regular coffee maker.
Jun 02, 2009 | Bunn GR10 Coffee Maker
Coffee perks luke warm
Your heating element is toast! If you want to risk taking it apart, there is a fuse inside that can be replaced and if the fuse is still in working order, (test it using a meter), the heating element is dying.
There is nothing else to do, but buy a new coffee maker.
Feb 27, 2009 | Hamilton Beach BrewStation 47224 Coffee...
Delonghi Coffee Maker
You need to take the unit to an authorized repair shop and have the heating element replaced
Sep 01, 2007 | DeLonghi DCM485 Coffee Maker
Cuisinart Grind and Brew DGB-300BK 10-Cup Coffee Maker Logo
450 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
