Question about Samsung SyncMaster 914V 19" LCD Monitor
Samsung 914v 19" LCD pixels went out
Samsung 914v 19" Lcd pixels out, i dont know if someone did something to the screen it almost looks like scratches under the screen...
    Scholar:
  • Samsung Expert
  • 113 Answers
your lcd micron tube in the panel had already worn out.
got to replace the panel
Posted on May 10, 2010
Hello my syncmaster 914v is black with the green power light flashing, any suggestions?
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 25, 2011 | Samsung SyncMaster 914V 19" LCD Monitor
What adaptor do i need to connect a new Mac Mini with HDMI input to an older SyncMaster 914v?
I assume you mean HDMI output. You'd need a 'HDMI Female to VGA Male' adapter or a 'HDMI Male to VGA Male' cable.
Such as:
http://www.sourcingmap.com/17m-golden-plated-hdmi-vga-male-adapter-converter-cable-p-61779.html?currency=GBP&utm_source=google&utm_medium=froogle&utm_campaign=ukfroogle
I've no idea if that site is reputable or not, just did a search on Google.
Jan 20, 2011 | Samsung SyncMaster 914V 19" Flat Panel LCD...
Green power light is on....flashes lowly......black screen
It is a hardware problem so pls checked it from service center.
Oct 14, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
Increasing my screen resolution without imediate reinstall. I need faster ajd smaller pixels to hopfully get into my Registry for changes so I can log in with the problems of not logging in because of...
  • Hi, I've read your "Post" I will try to assist you in sloving the problem. "First you want to change' the visual effects of the "Display." 1. Right click on "Desktop,
Jul 07, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
Samsung syncmaster 914v monitor problem. Right side of display is darker image. Can see dots like a newspaper print or looking through a screen. When display is black it almost appears like an image is...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
May 15, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
Samsung syncmaster 914v monitor problem. right side of display is darker image. can see dots like a newspaper print or looking through a screen. when display is black it almost appears like an image is...
This is likely the LCD panel itself - you are describing a left/right image error that can be only created by the left/right division by the LCD driver wrapped around the outside of the LCD panel.
If your monitor uses a separate circuit board to drive the LCD, it could be this driver board.
Either way, it will require an LCD panel - $$$
Mar 29, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
My samsung syncmaster 914v isnt working when i plug it in and turn it on all it does is flicker every like 10 seconds
Ok, a few basic things to check/try.
  1. What colour is the power LED, does it change when the screen flickers?
  2. Is the power cable firmly seated.
  3. Is the monitor cable firmly seated.
  4. Try another power lead.
  5. Take a look at the plugs on the monitor lead, does it look like there are any bent/broken pins.
  6. Again, try another monitor lead.
  7. Try connecting the monitor to another pc.
If none of these have any effect, you'll need to take it in somewhere to get it looked at.
Feb 25, 2010 | Samsung SyncMaster 914V 19" Flat Panel LCD...
My screen just turned yellow for no reason. I tried restarting, shutting down, and system restore but it is still yellow
Screen-colours are "additive" -- mix just 2 of the 3 primary colours, and you could get "yellow" -- mix all 3 or the primary colours, and you will get "white".
In order of "easy" and "cheap" to "difficult" and "expensive":
Check that the "data" cable is tightly connected at both ends,
so that all 3 colours are being transmitted from your computer.
Try a different "data" cable between the computer and the LCD.
Try connecting the LCD to a different computer (laptop or desktop).
Try adding a different video-adapter into your computer.
Nov 17, 2009 | Samsung SyncMaster 914V 19" LCD Monitor
Unlocking Monitor
just hold the menu button on the monitor for 10 sec or more and it will unlock it
Sep 15, 2008 | Samsung SyncMaster 914V 19" Flat Panel LCD...
Samsung SyncMaster 914V 19" LCD Monitor Logo
118 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
