Question about Ovens
''door'' error on display panel - whirlpool oven/microwave
Whirlpool Built-in Oven & Microwave combination double oven. The model # is RM280PXAQ with an integrated microwave & oven control panel. Mfg date 1993.
Set oven to 350, everything normal...temp climbed up to 200 and then, spontaneously, oven BEEP and error message pops up and says ''door'' and nothing else.
Turn off, try to turn on again...same ''door'' error, immediately. It's almost like the oven has shut down.
The microwave is working without problems.
The door is not ajar, there's nothing obstructing the door and there is nothing unusual about the way the door opens and closes.
Feels like something in the electronics. Any suggestions?
  • jessedo Feb 01, 2010
    Thanks for the reply - somehow, miraculously, the unit started working again.
    Under the same heading as "jiggle the handle" I put the thing on "Clean" cycle for about 30 seconds then shut it off. Turned it on again normally, it stayed on for 10 seconds, then shut down with "End" message. Tried to turn it on again...and it has been working normally ever since.
    So - there is probably a part that is at the end of its life. Is this an appliance-repair-guy thing? Anything to do now, before it fails at an inopportune time? It is 17 years old after all.
    Thanks - will do that.
  • 2,926 Answers
Hi, at this point it seems the micro switch on the door mechanism has failed, or failing. unfortunatley this is not any easy task that I can explain on this post.
Posted on Jan 31, 2010
  • GetMeOttaHere Feb 01, 2010
    Due to the age, it may be better to contact a local appliance parts store to see if parts are still available, then decide if it is worth repairing or replacing.
No power on double oven after a storm
I have a RBD275PRS00 built in double oven. Had an electric
www.fixya.com/support/t8971528-rbd275prs00_built
Apr 16, 2011 - Had an electric storm the other night and ever since the oven won't -Whirlpool ... Question about Whirlpool RBD275PR Electric Double Oven ... For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me ... fiest press the on key see if the display comes if not the turn the power off for 5-8 ...
Whirlpool panel buzzing Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > panel buzzing > Ovens
Whirlpool ovens panel buzzing related questions and answers. ... the control panel on my Whirlpool electric double oven Model is RBD305PDS14? ... No power on control panel During self clean cycle the power to the panel went out. ... panel the instrument panel on an oven won't change time because of a storm problem.
Jan 01, 2016 | Whirlpool RBD275PR Electric Double Oven
Error E7 : F1 GMC275PDs07. Microwave works normally but will not heat. Magnetron changed out and still will not heat.
If your microwave is a 220 then reset the breaker by turning it off for 10 seconds and then back on. Then check it. Since you replaced the magnetron, the signal to the mag is interrupted. Did you replace the control panel? If so, then look to see if it is wired back in order. Does the fan operate when you open and close door? If not, then check door switch.
Feb 24, 2013 | Whirlpool GMC275PD Electric Double Oven
I have a Whirlpool double oven GMC305PRS01 when you turn on the oven it appears to me making all the right move IE it goes into pre heat and starts counting down but the elements are not getting hot.
Member Discussion on Whirlpool GMC305PRS01 Microwave Oven
Whirlpool Wall oven/microwave combo unit Door message
Does anyone know where the 15 amp fuse is? I replaced the 20amp fuse and it worked for a minute or two and then I opened the door and I blew my circuit breaker. I reset my circuit breaker, replaced the 20 amp fuse and now all I get is the Door message. I also noticed that it fused the outside switch on the right side of the door so I had to open the switch up and un-fuse it. This is for a whirlpool GMC305PRS01 Wall Oven/microwave combo unit.
Also if anyone could tell me the correct position the wire is supposed to be hooked up on the switches? I had someone help me take the switch out and they unhooked the wires and now we aren't sure how they are supposed to be hooked up. My light on the microwave doesn't work either. Is it possible the bulb blew when the fuse blew?
Nov 22, 2010 | Whirlpool GMC305PRS Stainless Steel...
My daughter did something to the door... when you close the door and set the time and start the display reads 'DOOR' as if it isn't closed and it won't start. Thanks for any assistance. Whirlpool...
i have seen this a few times. the m/w portion has seperate fuses and sometimes the cartridge fuse can be blown. it is located inside the top above oven. hard to get to without pulling the unit and getting the top off of unit.
others have had a failure in the microwave control board.
Jan 10, 2010 | Whirlpool GSC308PRS Stainless Steel...
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Hooked up a new control panel and now the oven only works when the door is open! what did i mess up? microwave works. light is on when door is closed, light turns off when door is open and then oven will...
door switch connections are reversed. will need a model number and make to give better info.
Please take the time to give this solution a fix ya rating and repost with needed info.
clarkco
Mar 19, 2009 | Whirlpool GMC275PD Electric Double Oven
Displaying DOOR
there is two fuses a 15 amp and a 20 amp fuse on the left hand side of the microwave one or both have blown
Jul 08, 2008 | KitchenAid Architect Series KEMC308KSS...
Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Dec 06, 2007 | Whirlpool RBD245PRS Stainless Steel Oven
Ovens Logo
200 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
