Question about Sewing Machines
I have a digital voice recorder, ? VN-6200PC. I need instruction manual to hook up with Windows XP and users manual.
  • 10,515 Answers
You could Download the Manual from :-
http://www.olympusamerica.com/CPG_SECTION/cpg_support_manuals.asp?id=1459
You need to Have Acrobat Reader to View this.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 31, 2010
Need Bernina Record 930 repair manual
There are a whole number of YouTube repair videos on Bernina "how-to" repairs
Bernina Sewing Machine Disassembly
When you launch the above mentioned link, you will see other types of repair videos that may be of help to you in the right pane.
I was unable to locate a repair manual, but for what it's worth, I was able to locate a user's manual
Bernina Record 930 Electronic Manual
Feb 22, 2017 | Bernina Sewing Machines
How do I replace the bobbin hook after cleaning my Brother XL-3030?
you may be able to enlarge the manual page:
Brother XL 3030 User Manual Page 60
The hook (half-moon piece) needs to go in first, but you may need to wiggle it to seat it and then hold it while you fasten the outer retaining ring (hook race). Flip the levers up to hold the ring in place. Then install the bobbin case.
How to Clean and Maintain your Sewing Machine at Home Front Loading Bobbin
FWIW, my machine oiling instructions say to apply a drop of good quality oil on the outer edge of the hook race lip where the hook rubs as it turns. But, your manual should explain where to oil.
Dec 22, 2016 | Brother XL-3030 Electronic Sewing Machine
I need a user-instruction manual where can i download for free
Will any manual suffice, or do you have a particular make and model in mind?
Dec 08, 2012 | Sewing Machines
I need instruction manual for Magnolia 7318
Janome Magnolia 7318 (Sewing-Quilting Machine) user manual, guides and product documentations.
http://janome.imvoi.com/sewing-quilting-machine/magnolia-7318.html
Look under available documents and click on "Janome Magnolia 7318 User Manual".
This opens the user manual in PDF format.
You can save the PDF to your local computer to refer to any time without going online.
Dec 03, 2011 | Janome Magnolia 7318 Sewing Machine
Singer 2263 instruction manual does not show where to lubricate or how to adjust the hook which keep jamming
First make sure that the needle is fully up. Then you need to open the hinged front cover and unscrew the needle plate screws. Remove the bobbin. Brush out any lint now. Remove the bobbin case. Then snap the hook retaining arms outwards. Remove the hook cover and hook. Put no more than 2 drops of sewing machine oil on the the case (center right hand side). Then turn the hand wheel until the hook race is in the left position. Replace the hook and then the hook cover. Snap the hook retaining arms back into position. Replace the bobbin case and bobbin. Then replace the stitch plate.
Test the machine on a piece of waste fabric. If the hook keeps jamming, take the machine in for maintenance. The parts that may need to be replaced are the race or the shuttle hook. However without seeing the unit I do not know if there is not another problem. Some parts for the 2263 are available here: http://www.sewingpartsonline.com/singer-2263-sewing-machine-parts.aspx .
Singer has a second manual available with the oiling instructions for the 2263 here: http://www.singerco.com/uploads/download/1213_oiling-2263.pdf . See the diagrams on this page for where things line up. The rest of the instruction manual is also online here: http://www.singerco.com/uploads/download/1180_2263%28eng_spa_fre%29.pdf .
I hope this helps.
Oct 08, 2011 | Singer 2263 Mechanical Sewing Machine
Please help..I own a prelude singer sewing
Instructions on oiling your hook (the only area suggested for the user to oil) is located on page 40 of your instruction manual.
Nov 19, 2009 | Singer 8280 Mechanical Sewing Machine
What platform (WIndows XP, etc.) can the 9000 digitizer use?
Digitizer 2000? Or Digitizer 10000?
There's a BIG difference.
So far, it doesn't seem that Janome's put out an update to Digitizer 2000 for Vista (though they have for Customizer 2000), but they have for Digitizer 10000.
However, XP should be fine with Digitizer. You may have to go into your "Properties" menu for Digitizer and set the compatibility back to say, "Windows 95" though.
To do this, right-click on the software icon for Digitizer on your desktop. On the contextual menu will appear several choices - select "Properties" and then click on the "Compatibility" tab on the Properties dialog box. This is where you change how your computer (essentially) recognizes the application.
You may need to experiment with the options. Try "Windows 95" first ... and if that doesn't work, select and try another.
Apr 17, 2009 | Janome Memory Craft 9000 Computerized...
Need Windows XP USB driver for Memory Craft 10001
contact me back at dbfm13@aol.com and i will send you all the drivers i have.
when i got mine working, i believe sometimes it is just by LUCK that things work.
Jan 12, 2009 | Janome Memory Craft 10000
Sewing Machines Logo
14 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
